Olympus PEN E-P5: problems with touchscreen
Started Jul 15, 2015 | Questions
Pixel Tracker
Pixel Tracker New Member • Posts: 9
Hi, a few days ago a problem came up with the touchscreen on my Olympus PEN E-P5: it stopped working. I mean, after switching on the camera, any touchscreen functionality is gone. I can't touch anything, neither on-screen options nor touch-focussing. It seems that the touchscreen functionality is turned off, but it is not (I checked the settings).
After several turning on and off the camera the touchscreen functionality comes back. But when I turn the camera off or the camera goes into sleep mode after 30min the touchscreen-failure occurs again. It doesn't matter if I tilt the camera into different angels when I turn the camera on- and off; actually the camera can lie undisturbed on a table, and after the 3rd oder 4th on- and off-turning the touchscreen works again.
I already tried the following:
  • I switched the camera off, tilted the touchscreen into a different position, turned the camera on again: no effect, for any tilting-angle.
  • I took the battery out, switched the camera on in order to discharge any remaining current, I replaced the battery and switched the camera on again: no effect
  • when the touchscreen was working, I turned it manually off via settings-menu, switched the camera off and on again, and the touchscreen failure occurs again
  • when the touchscreen was not working, I turned it manually off and on via settings-menu: no effect
  • I applied a firmware update (version 1.5 to 1.6) AFTER this touchscreen failure occurred for the first time: no effect
  • I applied a reset to factory settings: no effect, the touchscreen failure still occurs
For sure, I can still use the camera even without the touchscreen. But focussing via the touchscreen is so comfortable and even quicker than using the option-wheel. And for a such precious thing I would not expect such failures after two years (I bought the camera exactly two years ago).
Does any one have the same problems? Any further advices? During the last days I searched in the web for that failure, but I couldn't find any solution or other PEN-users, who have the same problem.
Olympus PEN E-P5
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Olympus PEN E-P5: problems with touchscreen
Sounds like a real fault, cracked ribbon cable or something deeper. Send for repair is the only option.
My two E-P5 are fine, no problems like that, but then they are much younger. Only fault so far on one of them was the front/rear dials failing early, fixed under warranty. The second one works fine, no sign of dial failure at all (touch wood).
Regards.... Guy
Pixel Tracker
OP Pixel Tracker New Member • Posts: 9
Thanks Guy! I'm not sure, whether it is a hardware damage or rather a software failure. When the touchscreen works, the failure never occurs during the operating camera/shooting process. Only after turning on the camera. And as I mentioned before, tilting the camera or the touchscreen has, so far, no effect on that misbehavior.
I don't not, if this is a real workaround: Yesterday evening, before turning off the camera, I switched from focussing-mode by touch-selection to the camera's auto-focus-detection mode. Doing that several times, the touchscreen showed up no failure!
What I noticed: Without that workaround, that means letting the camera turning off with touchscreen-focus selection activated, turning it on again and the touchscreen again doesn't work, the camera doesn't show an initial focus-peaking. I mean, normally when I turn on the camera, the camera directly focusses right at that part of the image/display, where it has been set to in the previous state. This is indicated by the green rectangle on the screen, which flashes up for 1 or 2 seconds when you turn on the camera. When I turn on the camera and that green focus-rectangle does not appear, I already know, that the touchscreen won't work. So, perhaps there is a link between touchscreen-failure and initial focussing during the start-process of the camera?!
Guy Parsons
Curious. When I turn on there is never any initial green focus rectangle showing for that one or two seconds as you describe. What mode, what lens and what settings? If I can copy them and see what happens here.
But weirdness like that points to firmware corruption or a memory fault, still sounds like a back to repair job. But the fault needs to 100% repeatable and carefully described or documented or a YouTube video made of what you see for them to find the fault at all.
Regards.... Guy
Pixel Tracker
I always shoot in manually Mode (M), metering is set to ESP and focussing to Single-AF (S-AF). ISO manually, while AWB set to auto. I'm still using the kit-lens, M.ZUIKO DIGITAL 14-42mm 1:3.5-5.6 II R. Here is a screenshot of the settings/touchscreen (if you need more setting-info, just tell me):
Current settings
And as I told in the beginning: I've upgrade the firmware from v1.5 to v1.6 AFTER the failure occurred for the first time and it didn't solve the problem.
I'm thinking about to bring the camera to a repair shop (i.e., the shop where I bought it). But I'm afraid of the costs: My 2-years-warranty expired just at the beginning of this month Plus: I guess a lot of time will pass until I get my camera back. For the moment, I intend to wait for possible other users who experience that touchscreen-failure. Maybe I'm among the very first who have this problem - I bought the camera right after it was available in mid 2013
Guy Parsons
Settings seem "normal" to me and would not explain touch screen faults.
I'm not sure but a firmware upgrade does not necessarily re-write the whole code, maybe only a small part is updated and other errors may stay. If some sort of memory error then that stays in the hardware anyway.
I really think the repair shop visit is the best idea, if it is unusual they will recognise that and should help. In some countries "reasonable product life" considerations over-ride warranty periods so there may be some leeway if close over the limit.
Regards.... Guy
LeeS Contributing Member • Posts: 889
Could a myset be the problem?
Do you have a myset assigned to a mode dial position? Perhaps if the touchscreen was turned off when the myset was defined, you are turning it off each time you power up with the mode dial in that position.
Lee
 LeeS's gear list:LeeS's gear list
Olympus PEN-F OM-1
Pixel Tracker
Re: Could a myset be the problem?
Lee
Nope, I don't use mysets. All myset-setting are empty/in default.
Pixel Tracker
Update: I brought my PEN to my retailer, who send it to Olympus. After one week Olympus told me, that they have to replace the entire touch screen, for ~160 Euros. I will let them do that.
Sorry to hear that my MySet hypothesis was not the explanation. Had it been correct, it would cost you 160 Euros less to fix.
Lee
Olympus PEN-F OM-1
Guy Parsons
Good to hear that it was a real fault and not something that you had done.
Bad to hear that it costs €160, but then, the E-P5 is so good, it's worth it.
That will be my policy, to keep repairing until something really better comes along, and I see better as being the global shutter. Could be a long wait.
Regards...... Guy
Pixel Tracker
Thanks to all of you for all your comments and advices. As soon as I get my PEN back I will report, how good (or bad) the new touch screen works.
Pontcarre New Member • Posts: 2
I have the same problem with my E-P5 and I found a website where they explained how to downgrade my camera but firmware files are no longer available from Olympus but the latest, so I dont know what to do next.
https://lightsnowdev.com/Olympus/PEN/PEN-E-P5.html
 Pontcarre's gear list:Pontcarre's gear list
Fujifilm X100F Fujifilm X-E2 Panasonic Lumix DMC-GM1 Olympus E-M5 II Panasonic Leica Summilux DG 25mm F1.4 +6 more
Guy Parsons
The question is - why do you need to downgrade? Please explain your problem that makes you think a downgrade is needed.
Usually a camera problem means that there is something wrong with the camera and it needs repair if the usual full reset does not fix it.
Regards...... Guy
