Filters for the Olympus M.Zuiko ED 7-14mm f/2.8 Pro lens
Started Jul 13, 2015 | Questions
PhilnPhoto New Member • Posts: 6
Re: Filters for the Olympus M.Zuiko ED 7-14mm f/2.8 Pro lens
Knoxis wrote:
HI,
I want to know if the large filter adaptors such as the LEE SW150 system or Fotodiox WonderPana systems work on this lens?
Are there certain lenses that these systems have built adaptors for that have the same size barrels as the M.Zuiko 7-14mm f/2.8 Pro and thus allow this lens to use their filter holders?
Has anyone even received this lens yet and attempted to use filters?
Thanks!
Yi Fan Chin
Try this out:
http://www.philnortonphotography.co.uk/olympus-714-adapter.html
vasilpro
vasilpro New Member • Posts: 5
I made my adapter for mzd 7-14/2.8 pro lens with a cheap plastic funnel and Serk 1000mm filter holder
 vasilpro's gear list:vasilpro's gear list
Panasonic Lumix DMC-LX5 Olympus E-M1 Olympus OM-D E-M10 II Olympus PEN-F Nikon Z6 +9 more
vasilpro
vasilpro wrote:
I made my adapter for mzd 7-14/2.8 pro lens with a cheap plastic funnel and Serk 100mm filter holder
azjsb Forum Member • Posts: 54
Zbynek Hromek wrote:
JDCamera wrote:
Brilliant idea. Thanks for sharing. Could you please list of the brand of the parts you have used. The pictures don't show the company name.
JD
holder: http://www.ebay.com/itm/371431519421?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
lenshood: http://www.ebay.com/itm/251291414791?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
screws: http://www.ebay.com/itm/251783785579?_trksid=p2060353.m2749.l2649&var=550706948328&ssPageName=STRK%3AMEBIDX%3AIT
With this setup did you have vignetting at 7mm?  If so, at what focal length did it not occur?  So, am I correct that all that is needed it the parts from these three links and the fliters, themselves.  Thanks, in advance, for answers.
theSelf New Member • Posts: 2
JD
Thank you for this info- may I ask what is the length of the M4 screws you got please (as there are multiple M4 options in the link you shared)? If I am not mistaken the filter holder you listed on ebay holds rounded filters- I can't tell but will my circular 77mm variable ND filter fit and be big enough (I'm considering getting the 7-14mm f2.8 PRO lens but haven't got it yet until I figuire out a filter mounting solution) - thanks in advance for any feedback
icu4dk New Member • Posts: 16
I know the original post is old, but it shows up high in the list of responses of a Google search, and was of great help to me in finding a CP for the 7-14mm f2.8 PRO. Luckily there is a Haida distributor in my city, and the Haida 150 Series Filter Holder (Set) for Olympus M. ZUIKO DIGITAL ED 7-14mm 2.8 PRO Lens and Haida CPL Optical Glass Circular Polarizer C-POL Filter 150mm Lee Compatible combination was very affordable and at f22 there is absolutely no discernible vignetting. The construction is all aluminum, it came with three sets of gaskets to block light, and it also came with the screws and rails to extend it to a three filter system (which I have not tried yet).
Richard
 icu4dk's gear list:icu4dk's gear list
Nikon D7000 Olympus E-M1 II Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro +6 more
stevez Junior Member • Posts: 43
You can modify a standard P series filter holder to fit the 7-14. You need to carefully shave the inner circular portion of the holder to match the 79mm diameter of the hood. You'll also need to shave off some material (on about a 45º angle) from the front of the holder to reduce the slight vignetting. The only downside is that when pushing the holder onto the hood it changes the finish slightly. I've found that even though the filter touches the end of the hood, repositioning the filter leaves no marks on the filter. This is one case where I'm thankful for a plastic hood.
 stevez's gear list:stevez's gear list
Olympus PEN E-PL2 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II Olympus E-M1 II +17 more
Texan_2 New Member • Posts: 1
Cheap solution for M.Zuiko 7-14/2.8
- filter holder with 86mm adapter for 100mm filters (16 USD)
- lens hood 82mm ... front screw 86mm (3 USD)
- plastic screw M4 (1 USD)
Very elegant solution. Thanks!
Any comment about vignette?
avalvo Senior Member • Posts: 1,079
This turns out to be an excellent solution.
https://www.shapeways.com/product/9TDZZ7E6K/adapter-kit-pro-m-zuiko-7-14mm-lee-filter-holder?optionId=58133228&li=marketplace
They also make adapters for the 12-40 and 40-150 pros that work nicely.
