Urgent bounce flash question 760D owners
Started Jul 12, 2015 | Discussions
tr573 Senior Member • Posts: 1,329
Re: Thanks
walkaround wrote:
tr573 wrote:
walkaround wrote:
tr573 wrote:
"to meter the subject" - important part there. It knows how much flash it sent out, and how much it got back. Isn't that the whole point of autoflash? "get back less than expected, increase power. get back more than expected, decrease power"
If I stand the same distance away, it's a completely different scene, which potentially would have a greater metering impact than 4 feet of distance (unless you are at the edge of your flash range), don't you think?
I'm suggesting the same distance and framing, so 187mm on the 70D, 300mm on the 6D.
I will happily do this when I have some more time.
It sure isn't a problem on the 6D, regardless of whether it's a problem on other bodies besides the 70D.
I don't think one photo proves it isn't a problem on the 6D. It certainly is a problem on the 5D and 1D series, as I linked several times.
People complaining about their photos being a bit too dark, sounds like what I am showing on my 6D slightly underexposing. Not the unusable results the 70D is producing.
Mmm, no, people were complaining that they were 1 to 2 stops underexposed, and your 70D shot is exactly in that range.
Here are a few more relevant historical posts, just for fun. Deja vu?
"It's funny that when one uses FEL it generally gives a good exposure. I would have thought that the preflash in E-TTL II would have given similary consistent results. When shooting candid moments in rapid succession it is often not possible to spend time doing FEL and also makng FEC compensations etc." [Dec 26, 2006]
"I have noticed that when taking indoor shots with my 5D Mark II and a 580EX II flash that the pictures seem to always come out underexposed. I am using the P mode on the camera. If I set the FEC to +2/3 or +1 the exposure seems to be correct. Is this normal? It seems that the camera should be able to better meter the light in order to produce a shot with correct exposure without having to compensate for it. I am fine with making adjustments to get the correct exposure, but just wanted to make sure that something wasn't wacky with my camera/flash." [Feb 01, 2009]
"Anyway, the key words in E-TTL are in the initials: through the lens. The camera looks through the lens at the pre-flash and, in the case of a Canon camera, decides to underexpose by 2/3 to 1 stops." [same link as above]
Sooo, my 6D is a big ole awesome teddy bear then?  Great.  It works awesome, and gets auto flash exposures within spitting distance reliably, which is exactly what I want from my camera when using auto flash.  It's not quite as good as my X100T, but it's leaps and bounds better than my 70D.
RSCPA Forum Member • Posts: 67
Re: Thanks
The quote above regarding the 5D Mark II doesn't mention using bounce or diffused flash and using FEC seems to correct that particular exposure problem. On my 70D, the FEC does absolutely nothing to increase the exposure on the photos in question which are much more under exposed than 1 stop. Even setting FEC to +3 has no effect whatsoever on the photo. It's the same as if FEC were still set to zero.
 RSCPA's gear list:RSCPA's gear list
Panasonic FZ1000 Nikon D3300 Canon EOS Rebel T7i Nikon D7500 Canon EF-S 18-200mm f/3.5-5.6 IS +9 more
WilbaW
WilbaW Forum Pro • Posts: 11,643
Re: You are wrong
walkaround wrote:
WilbaW wrote:
walkaround wrote:
WilbaW wrote:
How do you explain this? - "If I flash exposure lock on the subject before snapping the bounce flash picture with the 70D, all the photos are exposed perfectly. If I don't FEL before snapping the photo, they are all very underexposed."
Because FEL uses an entirely different method of metering the subject.
It's metering the subject off the center zone, I hope everyone realizes that.
Which words say that, and what else do I need to know to interpret them that way?
"Aim the viewfinder center over the subject where you want to lock the flash exposure, then press the <*> button."
Wow, you're not joking, are you? That is simply invalid logic.
"To make an FEL reading you bring a mid-tone subject area to the centre of the viewfinder and press either the exposure lock or flash exposure lock button (varies with camera)."
If FEL always used Evaluative, where would Canon want you to put the mid-tone subject area in the viewfinder?
Or to put it another way, if FEL doesn't change the metering mode (so if the flash is in Evaluative FEL will meter in Evaluative and if the flash is in Average FEL will meter in Average) - how would we have to revise the two instructions quoted above for them to make sense?
And if we look at the Troubleshooting section of the 430EX II manual, we see the very first point about underexposure mentions reflective objects. (also warns about HSS and range decrease)
Err... you think that the problems reported with the 70D are because they have a mirror in the shot?
Err... I'm explaining why using FEL gives a different result than not using it.
So what do reflective objects have to do with that? In the absence of reflective objects, why should FEL give a different result?
There are no "problems" reported that are unique to the 70D.
You are missing the point that this is a problem that is unique to some 70Ds. Generic underexposure with bounce just needs a bit of FEC. This problem with some 70Ds is drastic underexposure that is avoided by using FEL. Big difference.
The same "problems" were reported by 5D2 and 5D3 owners as well (among other models, as noted). You don't find that to have any bearing on this discussion?
I think your desire to defend the 70D is clouding your logic and judgement.
I can't explain (yet) why it seems to work differently in Rebels. They use E-TTL II also, and should behave the same, although they could be using a different algorithm and we would never know. It's entirely possible that, as an entry-level camera, it is making assumptions about flash output that are not deemed appropriate for the enthusiast and pro models.
Sure, but what evidence do we have that they do behave differently? What differences are observed?
Every thread has a common theme: "my Rebel took perfectly exposed bounce photos... my 5D2, 5D3, 6D, 1D2, 1D3, 50D, 60D, 70D shots are always underexposed, when using bounce flash (with a sto-fen... lightsphere... etc)."
That's not what I see, so until I see some evidence - like, here's a test that shows the Rebels behave differently - I'm going to continue assuming there isn't a fundamental difference.
I haven't specifically tested this lately, but in my experience you get similar brightness with or without FEL, in evaluative or CWA, with the flash is direct or bounced. Not "very underexposed" without FEL as reported for some 70Ds. That's not normal.
Do you see a single example photo in this thread, or any other on this topic?
Not in this thread but I've seen enough in the 7D forum to be convinced that some 70Ds have a problem that goes way beyond needing +2/3 or +1 FEC when bouncing, and goes away with FEL. The difference between normal and FEL shots is not explained by different metering modes.
Do you see detailed steps to reproduce?
Yes.
Why assume that your shooting conditions are representative of all use cases?
Not.
I don't see this "problem" either, but I'm bouncing in a normal sized white room, without modifiers, in Manual exposure mode, with a subject only a few feet away (usually).
Your 70D doesn't have this problem. That doesn't mean nobody does.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
walkaround Senior Member • Posts: 2,551
Re: You are wrong
This is my last reply to you on this subject.
FEL uses center spot metering. Period. I posted links to the Canon website explaining all of this, which you have ignored.
WilbaW
Re: You are wrong
I knew you wouldn't answer the above question because it reveals the error in your logic.
I checked out your links and I can't see any evidence to support your conclusion. Even if it was valid, it doesn't explain the problems some owners have with their 70Ds.
