Oly 12-40 Pro 'out'..Panny 14-45 'in'..well maybe.
Started Jul 12, 2015 | Discussions
Dave in Wales
Dave in Wales Contributing Member • Posts: 901
I'm considering letting the Oly go and replacing it with a Panasonic 14-45mm f3.5-5.6.
Why, because the 12-40 is just TOOOO BIG AND HEAVY.
I don't really need f2.8.
I've had the the Panny 14-45 before, years ago, beautiful little lens.
'Little'...isn't that what M4/3 is supposed to be all about?
Panasonic Lumix G 14mm F2.5 II ASPH
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: Oly 12-40 Pro 'out'..Panny 14-45 'in'..well maybe.
Fair point, Dave. I have the Panny 12-35 for my pro work and the 12-32 to lurking about (and taking a pro work picture if it happens to come along).
I'm a fool for that 12mm FOV!
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
addlightness Veteran Member • Posts: 3,641
Or the Oly 14-42mm IIR kit lens which I have.  I don't have the Pany 12-32mm though I've heard only good things about it.
'Little' - absolutely agree.  That's why I'm here with 4 primes - 14mmf2.5, 17mmf2.8, 25mmf1.8 and 45mmf1.8.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
OzRay
OzRay Forum Pro • Posts: 19,428
15
My E-M1 with RRS grip and 14-35mm f2 has a combined weight of 1.65kg. I can carry this around with me all day long, anywhere, and not raise a sweat. I just handed it to my wife and asked her if this is heavy and would she be able to carry it around. She didn't think it heavy at all.
And no, 'little' isn't what m4/3 is all about. It's about providing options to meet all manner of requirements. Yes, it does provide smaller and lighter lenses than equivalent FF/APS-C systems, but the intent is not to be a Nikon 1 or Pentax Q.
The 12-40mm f2.8 is just over a third of the weight of the 14-35mm f2 and way smaller. My 35-100mm f2 is much bigger and heavier and I'll carry that around with me all day as well. But for crying out loud, 380g isn't heavy. That's a can of Coke.
My work boots weigh nearly 1kg each.
Thoughts, Musings, Ideas and Images from South Gippsland
http://australianimage.com.au/wordpress/
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Size is all relative, compared to other formats.
5
Go to camerasize.com and see where you are coming from. I just did that for me, having moved from a Canon 450D with 17-55 f/2.8 to the E-M5 with 12-40 and it is clear how much the size was reduced (weight too).
Illustration of my camera setup size reduction.
I keep this in mind when considering that maybe the 7-14 + 12-40 + 40-150 + TC is still a large setup. It really isn't compared to any equivalent APS-C or FF setup.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
AdamT
AdamT Forum Pro • Posts: 62,285
it`s OK - however the newer 14-42-IIHD is better at the edges, is faster focussing, is smaller and doesn`t extend much, has better OIS and nicest of all, better colour and contrast ....... none of this is night and day (we`re not talking about the 12-35 Pro here) but it`s a better bet .
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Reverse here.
9
I went the other way, replaced the 14-45mm with the way better and more useful 12-40mm.
A weak 73 year old and I find the weight stuck on an E-P5 to be a just perfect heft.
I have found f/2.8 to be essential when on holidays, makes those shots inside dim cathedrals work properly and helps me keep to lower ISO settings. Flash never used any more because of the combination of f/2.8 and good high ISO perfromance.
Agree, but it has not seen a shot since the 12-40mm came into my life.
No, it's all about sensible size and good quality results.
Compact pocket cameras and smartphones are all about "little".
Regards........ Guy
peppermonkey Veteran Member • Posts: 5,204
It may not be too big or too heavy..
But it could certainly be more larger than he wants or more heavier than he wants to carry around.
It just depends on how he wants to use it.
Hubert
My non-digital gear: Agfa Isolette, Ricoh Ricohflex VII, Voigtlander Bessa R, Voigtlander Bessa L, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, Pentax K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
I would get the Panasonic 12-32mm...
If you think the 12-40mm is too large or heavy for what you want to carry around, I would get the 12-32mm. I have the 14-45mm.. And it's a great lens but if you want small, the 12-32 is way smaller and lighter while optically is also a pretty good lens. It may not be optically better than the 14-45mm but I would think it's also not that much different and probably wouldn't notice the difference in the real world (unless you pixel peep all the time).
Hubert
OzRay
Re: It may not be too big or too heavy..
Indeed, but as with many posts on this forum, why carry on about such things if they are nothing but a personal choice? It simply invites push back.
Yes, and there will be those without sin who are the first to cast stones (not you in this case) that if you don't like it, why read it or say anything?
I choose to question, not to blindly agree.
Martin.au
Martin.au Forum Pro • Posts: 14,339
I'd have said "versatile" is what M4/3s is all about.
And I suspect Olympus and Panasonic would agree with me.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Colin K. Work Veteran Member • Posts: 3,699
As has been said, 'little' is a relative term. Don't know about Panny, but Olympus doesn't use the words "small" or "little"; rather they go for "compact", or more often "perfect sized" when promoting m43, OM range and of course the comparison is with DSLRs.
So perhaps "smaller than DSLR" is what m43 is all about for Oly (for the OM cameras), and in that they have been consistent.
Personally, I like a little heft in the lenses - I find it easier to hold them steady. As for the weight ... well I still feel like I'm walking on air after years of Canon! (Which lenses should I bring today? Oh yeah, now I can bring everything!).
Of course "perfect size" is totally meaningless but I do enjoy the fact that the EM-1 feels very similar in size and weight to the SLRs I started out with many years ago.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
Hen3ry
They breed you blokes tough in Gippsland! Back in the day, I used to run up the hill at Plenty with two fence posts on my shoulders after spending a day splitting same down the paddock.
Now I look at the difference in weight between the Panny 12-35 and 12-32 and go for the 12-32 for lightness, LOL.
And here in the tropics, I can sweat that out in an hour but I prefer GoGo, the local product (less sugary).
Perhaps, but they are on the ground, not on your shoulders. Unless …
Geoffrey Heard
OzRay
I'm still going out in the paddocks, cutting, splitting and filling an 8'x5' tandem trailer load of wood all year round to stay warm in winter.
The only thing that really gets to my back is the bending over with a chainsaw for a couple of hours. Splitting wood with my axe I could do all day long.
The thing is, the moment that you start thinking and acting like you're old, that's when you become old and start going downhill.
jalywol
jalywol Forum Pro • Posts: 12,302
I had the 12-40mm with my EM1, and I found I never used it, even though it is a fabulous lens.  I ended up using the 12-32mm on the cameras instead.
Interestingly enough, when I went to the Sony A7 with the 24-70mm, the total weight of the EM1/12-40mm combo was within 10 grams of the A7/24-70mm combo...but the Sony felt lighter in hand simply because of how the lens was weighted in terms of its length and center of gravity.  I think that may actually be what you are having an issue with as much as anything else.
I'd also recommend you take a look at the 12-32mm.  I liked it better than the 14-45mm, myself, and it's really tiny, also.  It does have a fair bit more barrel distortion wide open than the more expensive lenses, but that's fixable in PP, and it has a nicer color rendition than the 14-45, to my eyes anyway.
-J
joelakeland
joelakeland Contributing Member • Posts: 531
I was using the E M1 with the 12-40 and that combo give great output at the cost of DSLRish size and weight. You're right on the class and underappreciated 14-45 too.
My approach with M43 on my return is a priority on keeping it small with lenses like Pany 12-32 and primes.
Joe
 joelakeland's gear list:joelakeland's gear list
Sony RX1
alcelc
alcelc Forum Pro • Posts: 19,003
2nd to Hen3ry (Geoff)'s suggestion of 12-32. Similar IQ, smaller and lighter plus wider coverage than 14-45. The only advantage of 14-45 is of its lower cost.
However, 14-42 M2 could also be considered in economic terms, similar IQ (slightly better than 14-45), smaller and lighter than 14-45.
LMNCT Veteran Member • Posts: 4,908
They may not say "little" but they do say "compact" and "lightweight".  M4/3 was designed to be smaller and lighter than the huge and heavy alternate.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
Steve2015 Contributing Member • Posts: 516
No, it's about choice. If you want "little", buy a compact point and shoot.
It's about technology which isn't seen in other formats.
It's about value for money.
Going from a Pro lens to a kit lens, you will regret it.
It's not weather sealled, if your using a weather sealled body, it doesn't make sense to downgrade and risk water ingress.
Continuous shooting fps will be greatly reduced, especially if used on the EM1.
Which it is - have you felt the weight of a FF 24-70 2.8?
Colin K. Work
www.ckwphoto.com
www.pixstel.com
