Ring Flash Fuji XT10
Started Jul 9, 2015 | Questions
Szobod New Member • Posts: 4
Hi
I,m looking for a ring flash lamp which will work along with fuji macro fujinon 60 mm makro lens. It would be perfect if the lamp will work in TTL mode.
Any idea ?
Thanks for answers.
Maciek
Fujifilm XF 60mm F2.4 R Macro Fujifilm X-T1 Fujifilm X-T10
KVI08106
KVI08106 Regular Member • Posts: 100
Re: Ring Flash Fuji XT10
I use a Bolt VM-110 LED ring flash on my XF-60 here. They also make the VM-160 which has a higher guide number. It is manual flash and I don't know of any that do TTL.  The ring flash comes with a variety of adapters but none that are as small as 39 so you'll need a step up ring to attach.
It's an okay flash- not great, not horrible. I wish it had more than +/- 1.5 stop control.
 KVI08106's gear list:KVI08106's gear list
Fujifilm X-E2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Dcnight2002 New Member • Posts: 1
I purchased the Bolt VM-160 ring flash to be used for my gears (Canon and Fuji).  While the ring flash works great (in flash mode) with Canon.  It, however, does not work with Fuji XT-2, despite the fact that I set the flash mode to M in Fujifilm unit.  I am wondering if others have experienced the same issue.  Thanks.
D de Fridge New Member • Posts: 2
Same for me on the xt20, no flash
