Olympus E-P5 dial malfunction and warranty questions
Started Jul 9, 2015 | Questions
traveler_101 Senior Member • Posts: 2,203
My E-P5 dials are now beginning to malfunction. Most of the time they work, but they also skip a click or two from time to time.
Can anyone recommend a quick fix so i can bring the camera on my vacation next week?
Does anyone know at what point the global guarantee expires. I found this on their website: "Please kindly be informed that Worldwide warranty will not be provided with most of our Micro Four Thirds System and compact digital camera products shipped after September of 2014." Does anyone know whether that means shipped after September 1 or shipped after September 30?
I purchased mine on September 9, 2015 from Korea shipped to the USA, where I picked it up when over there. I am hoping to have it repaired here in Europe.
Anyone have any experience with this? Thanks in advance for any info/advice.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Olympus PEN E-P5
43Shooter Regular Member • Posts: 101
Re: Olympus E-P5 dial malfunction and warranty questions
I've found that the dial will skip less often if you apply some pressure in the direction of the camera as you use it (i.e. toward you for the front dial, away from you for the rear dial).
 43Shooter's gear list:43Shooter's gear list
Olympus PEN E-P5 Olympus PEN E-PL6 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +5 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
E-P5 #1 failed (gradually) early in its life and was later fixed under Oly Oz warranty, backup E-P5 #2 still showing no signs of problems after over 5,000 clicks and a couple of months of use
My fix was to treat the E-P5 like I did the E-PL1 where a back button dance made the aperture/exp comp changes, that got me through a 3 week holiday where it was gradually getting to total failure.
Usually that means you have to pay for the fix. Only shipping it back to source may provide a "free" fix.
I purchased mine on September 9, 2015 [2014] from Korea shipped to the USA, where I picked it up when over there. I am hoping to have it repaired here in Europe.
You will have to pay, email your Europe service with the facts and see what they say.
"Global" warranties are just bits of paper and usually mean nothing outside their source country. Each country seems to run independently and does not want to pick up foreign repair costs. I know Oly Australia (even though an Oly Japan subsidiary) got burnt doing that so they refuse foreign warranty fixes unless a true traveller in distress and then only on a case by case basis.
That is exactly why I buy complex bodies at home, so I get the Oly Oz 2 year body warranty that works perfectly for me now twice, once with an E-PL1 very nearly at 2 years, and then with the few months old E-P5.
Regards.... Guy
Anders W
Anders W Forum Pro • Posts: 22,144
Just look at your warranty slip. It should tell you whether your particular body has a worldwide or a geographically restricted warranty. Which kind of warranty you got should depend on what slip was in the box rather than on the date of purchase.
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Day Hiker Forum Pro • Posts: 10,829
It will only get worse
I had two repairs for this problem: One to fix the original faulty dial, the second to repair the faulty repair after only two weeks use.
My experience is that the problem will only get worse; it will not stabilize or go away. The only solution is a proper fix or, in my case, a demand for a different body from Olympus. With your travels so close, the best advice right now might be:
  • Live with the frustration until you get back and pray that you don't progress to total failure
  • Immediately purchase another body while you arrange for repairs on the current one
I know, neither choice seems optimal, but I make these suggestions due to the short time frame you have to arrange for a repair/replacement.
Jim Pilcher
Summit County, Colorado, USA
OP traveler_101 Senior Member • Posts: 2,203
Re: It will only get worse
Jim Pilcher
Thanks Jim, Guy, Anders and everyone for your advice. Well, the first thing I have done is to adjust my use of the camera as per Guy's suggestion. I was vaguely aware of the back button access to exposure compensation and f-stop, but never used it. I located the button and find that the arrangement - where both f-stop and exposure compensation are accessed at the same time and controlled by pressing the dial, up/down or left/right - to be quite workable, actually. I have started to use the camera that way now. As for the dials, I simply set the dial function selector in the 2 position. Now the dials control ISO and white balance. As these settings are changed less frequently, the dials should last longer. And if the dials start to really fail then I can access these functions through the SCP as I generally have done anyway. So I think the camera will be useable even if the dials become completely unreliable.
After the vacation, I will investigate the repair issue. Anders, I do have a global warranty and my proof of purchase. We shall see if this is accepted by Olympus Norway or if Guy is correct and the warranty is "just a piece of worthless paper" outside the country of issue. If they won't pay for the repair, I will have to decide whether to pay for it myself or just limp along with this E-P5 for a while and then buy another camera in the near future.
The worst thing about repairing a camera is the time you are without it (not to speak of the ultimate nightmare of having a repair that does not solve the problem). Stupidly, I listened to a certain voice telling me "you have too many cameras in the house" and sold off a perfectly good E-PM2 recently. Now I wish I had it as backup. However, I also have film cameras and can simply shift 100% to film as needed.
Anders W
Jim Pilcher
If you have a slip for global warranty, I am sure you'll have no issues. A considerable part of my own gear (Oly as well as Pany) was bought in the US rather than here in Sweden. In two cases (40-150/4-5.6 and 12-40/2.8), I have had them repaired under the Oly global warranty. No problems and no questions asked. And I am sure Oly's sad decision to let go of the global warranty doesn't apply to anything that had already left the factory with a global warranty slip. The warranty you get is the one that the warranty slip in the package says that you get. Anything else would be unreasonable and probably illegal as well.
Guy Parsons
Warranties
The global warranty had exceptions. Some countries did not honour it.
In Australia they used to honour it but after Japan failed to recompense the local group for repairs done (though a true subsidiary) they had to stick to only honouring local warranties where the likely repair cost was built into the sales structure of goods imported by the subsidiary.
Just like film days in USA where Nikon had a USA warranty and B&H also sold cheaper grey market Nikon with a global warranty. Guess which one Nikon USA would honour? But if I bought B&H grey market and brought it back to Australia I was covered by that global warranty, but would not have been covered in Australia if I had bought the USA version with the USA warranty only.
Summary: The only way to know what will happen is to ask the local repair facility.
Regards.... Guy.
Anders W
Re: Warranties
OK. I am sure you have the story right about Australia. Here in Europe though, I know through personal experience that there is no problem with the global warranty.
Re: Warranties
I am encouraged enough by Anders' experience to give it a try. I used the camera extensively yesterday without relying on the dials and it was o.k., though it would be nice to have it fixed, obviously.
Rich K
Rich K Senior Member • Posts: 1,006
Miraculous recovery
Although I'm not recommending to anyone that they simply ignore a problem, sometime it works!  The rear dial on my EP-5 started to skip about two months ago, about two weeks before we were to leave on a 5 week trip to Europe.  No time to send it in for repair, so I familiarized myself with the "push the buttons" method and left for the trip.  After a couple of weeks in cold and rainy Ireland I happened to start using the rear dial and remarkably, no problems.  Three more weeks in hot and sunny Provence, and the camera was still going strong.  Perhaps some dust or grit in the mechanism worked its way out?  Wish I knew what the "fix" was - taking a long trip to Europe seems like a fairly expensive camera repair!
 Rich K's gear list:Rich K's gear list
Sony RX100 III Olympus PEN E-P5 Olympus E-M5 II Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +5 more
Re: Miraculous recovery
I love the story! Yeah wouldn't it be nice if the thing could correct itself.
Update
Jim Pilcher
Just an update on this story. I wrote Olympus Europe and was referred to Olympus Norway Service. I do have a global warranty, but was informed that it doesn't matter:
"If you bought it in Europe, you have 2 years warranty. If you bought it outside Europe, the warranty cannot be applied in Europe."
Looks like I will have to decide whether to live with a camera without effective dials or pay for the repair myself. If the latter, I think I will do it in the U.S. where costs are generally lower.
Anders W
Re: Update
Jim Pilcher
I would take issue with Olympus Norway about that. I think you just happened to come across someone who does not know how this actually works. It was a while since I looked at the warranty slip of any of my Olympus lenses, but I am pretty sure that the one for the international warranty that you have says that it is valid for one year and entitles you to warranty repair at the closest available Olympus service station no matter where the gear was originally bought. Am I wrong about that?
Note: The warranty provided for cameras bought in Europe is and was a bit special in that EU consumer law gives the consumer some protection for at least two years no matter what the manufacturer thinks about it (although this protection may be somewhat weaker in some respects than that typically offered by the manufacturer). However, this does not mean that the one-year international warranty previously provided by Olympus for gear bought anywhere in the world is not valid for repair in Europe.
cptobvious Contributing Member • Posts: 850
Even if it came with a worldwide warranty (I'm guessing it does because the E-P5 is one of Oly's lowest selling cameras, and there's probably plenty of 1+ year old inventory sitting on shelves out there), I believe it has to be purchased from an overseas seller who is an authorized dealer.  I doubt many of the sellers on eBay/Amazon are.
My E-P5 had to be serviced under warranty for the same issue. None of the dial-turning solutions mentioned fixed it. Then it failed again a few months later. After that experience, I'm afraid to buy a gray market Olympus body even if they are 2/3 the price.
dv312
dv312 Veteran Member • Posts: 9,215
Re: Update
Sounds like a mechanical contact issue but I wonder if it's worthwhile to:
1) update the firmware (if not already done)
2) reset camera to the manufacturer's settings
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
Guy Parsons
Re: Update
No, it's the dials at fault.
The repair is to replace the top board which replaces the two dials and anything else on top such as the mode dial.
Mine was bought and warranty repaired in Australia. One E-P5 died early, the second one is OK and the repaired one seems good now.
The problem is that the dials may fail again in the future (unknown) so even I will need repairs out of warranty at some stage.
Each country has its own warranty arrangement and the "world wide warranties" do not apply to this world. They are useless.
Regards..... Guy
Warranty case closed
I looked up the warranty - soon to expire by the way (purchase was made 6 September 2014). All it says is "This worldwide warranty must be presented at an Olympus authorised repair service station dealer before any repair can be made under the conditions of the warranty. This warranty is valid if the Warranty Certificate and proof of purchase are presented." There are two strips with bar codes neatly pasted onto the warranty.
I thought perhaps to take my case to Olympus corporate in Japan. . .
BUT just now as I leafed through the papers the Korean seller sent with the camera, I can find NO PROOF OF PURCHASE! Yes, there is a Customs Declaration from the seller, in triplicate no less, but no where on that declaration does it specify which camera has been shipped!
So this is the greyest of the grey market . . . (lol). Buyers be forewarned of what can happen when you purchase outside of your own country.
In this case, I can live with it - and well, I have to. I got the camera at an unbelievable bargain price and except for this occasional problem with the dials it works perfectly. When the problem gets worse (as I have been assured it will), I can live with pushing buttons to adjust aperture and exposure OR I can send it in for repair at my expense. Read on a different site that three months ago someone paid $175 for Olympus America to repair his E-P5. That's not too bad.
Thanks for everyone's insights.
Anders W
Re: Warranty case closed
That suffices. There is no mention that you have to use a repair service station in the country of purchase.
Not sure that will help much. I'd try other alternatives first. A second talk with Olympus Norway, first of all.
That's a pity. Olympus does want to see the receipt and we can all understand why. Otherwise, you could keep claiming warranty forever.
But don't you have any record of the transaction from the on-line services you were using at the time of purchase (ebay, PayPal, etc.)?
As I mentioned, I have had no trouble with this at all. I have had three pieces of Olympus gear repaired or replaced under warranty. Two of them were bought in the U.S. The third was bought in Sweden but was used rather than new, in which case I don't really think the warranty is valid any more. IIRC, the warranty is personal and not transferable. In all three cases, Olympus Sweden honored the warranty without questions.
get it repaired, even if you must pay
I'm not trying to spend your money, but I highly suggest that you get it repaired. You will never be satisfied with this camera as long as it is partially malfunctioning. The aggravation will grow like a cancer, eating away at your ultimate satisfaction and enjoyment.
Or buy a new E-M10 MkII
Jim Pilcher
Bonita Springs, Florida, USA
