rx100 m1,2,3,4: Outline of Feature Differences
Started Jul 8, 2015 | Discussions
elliottnewcomb Forum Pro • Posts: 17,945
7
Courtesy of new forum member Bebear, from another thread, a concise list of differences:
"I took the time to research DPreview and Sony's websites and compiled what you gain on each upgrade and I wanted to share":
RX100 mk2 from RX100:
+ Updated sensor (BSI)
+ WiFi
+ Hot shoe
+ 24p video
+ Tilting LCD
+ Active OSS
+ Improved AF speed
RX100 mk3 from RX100 mk2:
+ Updated processor (Bionz X)
+ Pop-up viewfinder
+ Clean HDMI output + 4k photo playback
+ Video recording with full sensor readout
+ XAVC-S 50Mbps
+ 3-stop ND filter
+ Downloadable apps
+ Better tilting LCD (180/45 vs 90/40)
+ 720p120
+ Extra-fine JPEG mode
+ White-Balance Bracketing
(+/-) Different lens (24-70mm instead of 28-100mm)
- Loss of hot shoe
RX100 mk4 from RX100 mk3:
+ Improved AF Speed
+ Updated sensor (stacked)
+ Updated pop-up viewfinder
+ Max shutter speed (1/32000 vs 1/2000)
+ Faster continuous drive (16fps vs 10fps)
+ 5-minute Direct 4k movie @ 100Mbps
+ 1080p120 @ 60Mbps
+ S-Log2 gamma video
+ Super slow motion
+ Eye AF
+ Dual-Rec still shooting while recording video
The lens switch between Mk2 and Mk3 was as such:
RX100 Mk2: 28-100 (f1.8-f4.9)
RX100 Mk3: 24-70 (f1.8-f2.8)
There's a nice graph in the dpreview's RX100 Mk3 review showing the aperture across the focal length:http://www.dpreview.com/reviews/sony-cybershot-dsc-rx100-m3
From the graph, it looks like the Mk2 lens is better only between 28 and 33mm. At 70mm, the RX100 Mk3 lens provides a significantly wider aperture than the Mk2.
The lens change has been controversial at best, which is why I didn't consider it a plus or a minus on my change list above.
his other thread about m4 limitations/quirks
http://www.dpreview.com/forums/thread/3870213
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX1R Sony RX100 III Olympus Stylus 1s Sony RX100 VI Sony Xperia XZ +1 more
Sony RX100
alolywu Regular Member • Posts: 387
Re: rx100 m1,2,3,4: Outline of Feature Differences
Nice summary, thank you!
newellj Senior Member • Posts: 1,064
Would suggest editing to change "better" to "faster" when referring to the two lenses (minor point).
 newellj's gear list:newellj's gear list
Sony RX100 II Sony RX100 VA Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
Peter v.d Werf Contributing Member • Posts: 749
Some additions to the list:
Mk2
+Custom button option to appoint function (like toggle manual/contiunous AF in movie)
Mk3
+combined video and images in playback
+able to use auto iso in manual
Mk4
+able to set minimum shutter speed in Auto ISO
KJaay Veteran Member • Posts: 8,319
+ WiFi
+ Hot shoe
+ 24p video
+ Tilting LCD
+ Active OSS
+ Improved AF speed
+ Pop-up viewfinder
+ XAVC-S 50Mbps
+ 3-stop ND filter
+ Downloadable apps
+ 720p120
- Loss of hot shoe
+ Improved AF Speed
+ 1080p120 @ 60Mbps
+ Super slow motion
+ Eye AF
Elliott
Nice summary, thank you for taking the time.
KJ
 KJaay's gear list:KJaay's gear list
Canon PowerShot S3 IS Fujifilm X-S1 Nikon Coolpix P600 Nikon Coolpix P900 Nikon Coolpix P1000 +1 more
Autoxave Regular Member • Posts: 262
Excellent. Saved me a lot of time investigating on these issues.
