400D, Is it possible to change the point of aim?
Started Jul 8, 2015 | Discussions
oxygna3 New Member • Posts: 1
Hi, could anyone advise whether or not I can manually adjust the point of aim of my fixed camera? To elaborate, the camera is 'fixed' alongside a HD video camera and both cameras point in slightly different directions which is really noticeable beyond 2 or 3ft.  My 400d points centraly but is aiming slightly high, therefore, if I could lower the point of aim slightly it would centralise everything.  Is there any way I could do this?
Many thanks
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X)
imqqmi Veteran Member • Posts: 8,639
Re: 400D, Is it possible to change the point of aim?
Many thanks
Not really sure what you're trying to accomplish but short of using a split (semi transparant) mirror system where the light is split 50/50 to two camera's I don't see how you could compensate for the parallax difference between two cameras pointing at the same subject.
I'm not sure what you mean by 'slightly high'. If you mount the camera on a ball head, you would be able to change your aim, right? Or am I missing something?
Kind regards
Imqqmi
Links:
View my webgallery
http://www.pbase.com/imqqmi
The DSLR jargon cheatsheet
http://www.jmbfoto.nl/dslrcheatsheet.pdf
Sunset blending tutorial
http://www.jmbfoto.nl/tutorial/blendingTutorial01a.pdf
Wilba's Frequently Asked (beginners) Questions and answers
http://snipurl.com/RebelFAQ
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
