Is this rolling shutter? EM5ii on silent
Started Jul 6, 2015 | Discussions
Nicholas Johnson Regular Member • Posts: 387
Going through my first 2000 photos (across two batteries) I see this strange scene. I expect I whipped the camera around to the subject and shot while still moving. Shot on silent. Maybe I'll have to use the physical shutter as my default after all. Though one in 2000 for my style of shooting might make it worth not wearing out that shutter with my spray and pray style.
Truck was in a parade doing maybe 3 mph.
Helen
Helen Veteran Member • Posts: 7,606
Re: Is this rolling shutter? EM5ii on silent
Yes, that's it.  A potential side-effect of pretty much all silent shutters at the present time (the Nikon 1 models seem a bit less prone than most, since they scan a bit faster than the average).
lattesweden
lattesweden Veteran Member • Posts: 5,583
If I think correctly here, from a technical standpoint a person with programming skills should be able to construct a program/plugin that somewhat fixes this problem by side stepping each line horizontally on the long side of the picture to the next one with the right amount. Since the scanning time is different for each camera, the side stepping needs to be adjustable and a final crop will be necessary so one would loose some of the size.
Best regards
/Anders
I'm from Sweden, but my pictures are in all languages: http://500px.com/anderslattermann
OP Nicholas Johnson Regular Member • Posts: 387
Found more examples, though less severe
Looking through more 11 fps bursts and scrolling in Adobe Bridge it seems the rolling shutter is strong. Wobble wobble everywhere though you generally can't tell in a still. When I was on a four-wheeler, shooting with my elbows vibrating to the idling engine the effect was most noticeable with side by side images. Luckily the normal shutter is really quiet too. I wonder if any of this is exacerbated by the IBIS moving quickly or if its all my movement. The subjects were barely moving.
Photoshop > Edit > Transform > Skew
Made the leaning line vertical and cropped. So there is a fix in case I get an image I really want thats rolled.
Astrotripper Veteran Member • Posts: 8,676
Note that this fix will work ok only on images where rolling shutter effect was provoked by the camera movement. This was the case here, since not only the truck is skewed, but the background in the distance as well, so everything was skewed pretty much the same.
If you kept your camera still and captured fast moving subject, you'd have a situation where you'd either have skewed subject or skewed background. I imagine fixing this would involve more photoshop work.
I expect this will be greatly reduced with the use of next generation of sensors, but until then, mechanical shutter is the only option when fast movement is involved.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
sigala1 Veteran Member • Posts: 3,911
That's it exactly
Never use e-shutter if you are moving or anything in the picture is moving.
ysal
ysal Veteran Member • Posts: 8,769
Yes.  Look at what e-shutter did to the wing tips of this hummingbird.
yuki
 ysal's gear list:ysal's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-GX7 Canon EOS 80D
Bas brugemann Regular Member • Posts: 101
Re: That's it exactly
Even the corrected image has some obvious skewing. Never knew this could happen.
Good advice.
It has something funky on hummingbird wings though.
 Bas brugemann's gear list:Bas brugemann's gear list
Sony RX100 II Pentax K-r Olympus E-M5 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 Limited +5 more
