bulb mode - buffer... loads up - no shutter - bad for fireworks
Started Jul 4, 2015 | Discussions
orchidblooms
orchidblooms Senior Member • Posts: 1,267
bulb mode - excited to head out for fireworks with new a7ii
used to nikon d800e - when in bulb mode - a person can simply blast away - buffer writes to memory card... until battery bis dead or memory card is full...
i have been testing bulb mode with a7ii   -  things are very different it seems...
seems with each actuation - you are prevented for a long time - seems twice as long as exposure from activating that next shutter release..
so if you are taking 15 second exposures - a person can take maybe 3 to 4 shots every 2 minns...?
with fireworks - it is bam bam bam shot after shot fast shooting in bulb mode
maybe i have something set wrong that is making this a real bummer for fireworks?
Phillip "Iggy" Murphy http://phillipmurphy.com
ILM Sandra Murphy - "The Orchid Lady" http://orchidblooms.com
Nikon D800E Sony a7
moffatross
moffatross Senior Member • Posts: 1,128
long exposure noise reduction ...
... switch it off
orchidblooms
OP orchidblooms Senior Member • Posts: 1,267
Re: long exposure noise reduction ...
suggesting using other than bulb mode??
i have never used other than bulb mode for fireworks....
will be an interesting evening...
this alone could be cause to keep the nikon body for certain things...
ill report back in morning - see how the flow goes once i get used to this.
p
moffatross
5
No, go into the menu and switch off 'long exposure noise reduction' and continue to use bulb mode (or whatever). Your problem will be solved ... the A7II will then behave like your Nikon camera
Promit Senior Member • Posts: 2,071
Re: bulb mode - buffer... loads up - no shutter - bad for fireworks
Just to explain what's happening - by default, on long exposures (greater than 2 or 3 seconds I think?) the camera engages long exposure noise reduction. This runs a second exposure with the shutter closed, and then uses that second frame to noise reduce the first frame by identifying hot pixels and the like. This optimizes the results, but at the cost  of considerable time, as you noticed.
 Promit's gear list:Promit's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +1 more
JimKasson
JimKasson Forum Pro • Posts: 33,941
You already know about LENR. Bulb mode also makes the a7II a 12 bit camera and introduces some spatial filtering.
Jim
 JimKasson's gear list:JimKasson's gear list
Nikon Z7 Fujifilm GFX 100 Sony a7R IV Sony a9 II +1 more
Have you encountered any situations where this is a practical problem?
JimKasson
The 12 bit issue is accompanied by increased read noise, and will affect the sky in fireworks photos. AFAIK, the main effect of the spatial filtering is on astro-photography.
Jim
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,673
You mean the sky won't be black anymore? How sad:) Actually, the second exposure (dark frame) is designed to eliminate random noise (and of course you know that). The fact that it doubles exposure time is what it is. I can't imagine 12 bit affecting a firework display. By the way, there are hundreds and hundreds of good folks picnicking under their tents and blankets here in Payson, sitting there with their coolers half empty waiting for the firework show . . . and it is raining like crazy. Win some, lose some. My weather station says .18 inches and counting. Forecast was for no rain. Blame it on El Nino.
Jim
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D Fujifilm XF 60mm F2.4 R Macro +32 more
JimKasson
We can only hope.
Jim
JimKasson
Steve, I now live in the Monterey Bay area. Fog is the usual summer evening weather. I used to live in the SF Bay area, where fog was often the summer weather. Therefore I haven't had recent experience with fireworks photographs. But I do remember that it looked unnatural if you raised the black point to drop the entirety of the sky to 0/0/0. Therefore, you had to deal with read noise. And it really looked weird if part of the sky had no noise and part had some.
The second exposure only reduces pattern noise that is correlated from exposure to exposure. It actually causes uncorrelated read noise to increase by a factor of 1.414.
Jim
orchidblooms
here it is...
seems to work fine -
no problems
