To those with both EM5-II and EM1
Started Jul 2, 2015 | Discussions
AdamT
AdamT Forum Pro • Posts: 62,285
To those with both EM5-II and EM1 - if you had no old 4/3 lenses which would you keep ? ..
I ask because I use the EM1 as a secondary work system and an old friend (retired from the job) who`s had an EM5-II for a few months has come into some SHG 4/3 glass and is suggesting an exchange because I don`t have and am not likely to get any 4/3 lenses .
Reasons which benefit me would be
1:- Quieter shutter, 2:- true EFCS, 3:- total Electronic shutter 4:- borderline OK video (as opposed to awful) 5:- Hopefully more stable AF system 6:- better IBIS 7:- HR mode for Stock photography 8:- superb twisty screen which folds inwards 9:- Hopefully none of the EM1 maladies such as burned EVF, dials failing and lugs falling off
Reasons I can think why not and keep the EM1 would be
1:- that deep EM1 Grip 2:- losing function buttons 3:- having to buy Capture one 8 because 7 doesn't support the 5-II 4:- it has an AA filter whereas the EM1 does not
Any input from owners of both regarding handling, AF, detail in files and IBIS would be gratefully received - I use mainly the 12-40 F2.8 and the Panasonic 14-140-II
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
Olympus E-M1 Panasonic Lumix G 14mm F2.5 II ASPH
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
Re: To those with both EM5-II and EM1
I no longer have my EM-1 but my thoughts may be of interest, for my use (primarily macro + studio with a bit of walkabout / landscape ) I prefer the EM-5 mk2
One big downside for me to get out of the way is the grip, if I were judging purely on the ergonomics of that, I would keep the EM-1, which suited my hands much better and just seemed a better bit of design and construction
- battery life is not so good either but not sufficiently degraded as to be a problem for me
So, why the EM-5 mk2?
- the IBIS does seem to work better, particularly when shooting close macro work hand-held (my usual mode of working)
- although it is supposed to be "the same" sensor as that in the EM-5, I believe that something has been improved (maybe in the in-camera processing?) as I get less noise as the ISO increases to 1600 and the images have a cleaner more open look (subjective assessment + comments from club member who have seen images from all three of my EM's 5, 1 and now 5 mk2) Its certainly less noisy than my copy of the EM-1
- I think that focus is faster than the 5 and on a par / maybe a tad faster than the 1
- for my studio / still life work the Hi Res 40mp mode is a real benefit
- although I make only limited use of it the on-board flash is a real improvement with swivel and bounce potential and, I get the impression, a wider focal width (not made enough use for objective comment here)
That's it really, two superb tools and I regret selling all my original kit (a poor call brought on by muscle and joint weakness problems resulting from side-effects from a prescription drug I was taking, now resolved as I have stopped the drug and strength is returning - a magic feeling! ) but it did result in me getting the mk2 which I am finding does everything I need so far
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
AdamT
OP AdamT Forum Pro • Posts: 62,285
Yeah - in that it IS a grip - I felt liberated by it after the EM5 Mk1 and 10 with the 14-140 on - does the RH lug still stick into the hand when using the MkII like the Mk1 and EM10 ? ..
Well, the EM1 is crap on that score .. LOL . I liked the way the EM10 recycled old EPL and EP batteries , kinda hoped the Em5-II would have carried that on .
Does it - I wondered if the reports on this were merely the Traditional DP-Review Forums Hyperbole coming into play .
What about RAW ? . to be honest my EM1 isn`t much diff to the EM5 Mk1 and EM10 at high ISOs - I only use JPG for Product work
It`s the tendency for Olys to sometimes miss on bright sunny scenes by a bit and rear focus that I`m hoping they`ve cured in the 5-II - though they`ve done it since the EP1 so hoping a bit much I guess .. Panasonics simply do not do this (though they simply do not have EFCS either bar the compromised GM cams hence why I moved to an Oly)
I do hate Tripods with a passion so doubt I`d use it much but I can imagine with the 12-40 set to F4 the results are out of this world.
I can`t imagine me using it for anything other than as a commander on an OMD BUT it WILL work on my GM5 after a small mod so that`s another big bonus for me - thanks
Thanks for your input Brian .......
alatchin Senior Member • Posts: 1,055
Files have been superb from these cameras since the EM5, so I wouldn't worry too much about IQ. The EM5.2 does have the HR mode which I use for product and interior when I need that step up.
IBIS, well it certainly seems better, but not worlds, so I wouldn't worry too much about that.
The grip, I do have my grips on the EM5 and EM5.2 a lit of the time, but when I go out with my kids or when I travel they come off and I go with my small lenses (9-18, 17mm, 45mm, 40-150 f3.5-5.6) so 6 of one, half a dozen of the other.
Twist screen has been useful for awkward angle shots.
To me, I would make the trade. as I have found the body immensly useful and I use the 50mm f2, the 35mm f3.5 macros and I have just purchsed the 43rds 7-14 for interiors.
All the best
“You don’t take a photograph, you make it.” -Ansel Adams
blog.alatchinphotography(dot)com
Anders W
Anders W Forum Pro • Posts: 22,144
To my knowledge, neither the E-M1 nor the E-M5.2 has an AA filter. According to the horse's own mouth (see here), the TruePic VII of the E-M5.2
"performs high-precision demosaicing optimised for the low-pass filter less sensor".
Other than that, I think you got the pros and cons largely right except that I don't know what you mean by "hopefully more stable AF system" on the E-M5.2 (I am not aware of any stability problems with my E-M1 AF) and that you will lose some C-AF functionality with the E-M5.2, not just with FT but also MFT lenses, due to the lack of on-sensor PDAF.
Then it's all up to you how much this or that matters. Personally, for my shooting, I think I'd be inclined to swap if I got an offer to exchange my E-M1 for an E-M5.2. But I can certainly understand if some people see it differently.
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Brian Wadie
Lenses used in my assessment
I forgot to add this Adam, primary lens is the 60mm macro (of course), the others, in order of use: 12-50 kit lens, 17mm f1.8, old style mk2 40-150 and a manual focus canon fd 400mm f4
As to RAW, I can't say that I have seen much difference so won't make a judgement call on that. For most of my present work I have been shooting RAW + LSF jpg but mainly processing jpg for speed.
What I have produced using RAW has been for my gallery sales and a few studio images printed off for competition work and the quality is at least as good as anything I got with the EM-1
I think the lugs are a little further forward than on the EM-1 but as I modified my holding technique to avoid them on the EM-1 I don't find either body giving me a problem that some have described
As you will have gathered - I'm very happy with this new body
AdamT
Thanks Anders and I`ve now fixed the need to upgrade my RAW conveter too - I`ve written a Batch file for GSAR to "Turn" Em5-II RAWs "into EM1" ones - it alters the identification text in a folder full of ORFs in one go - I checked it on some downloaded from P-Blog and it worked
AdamT
Re: Lenses used in my assessment
As long as it`s no worse then Fine for me ............ thanks
as I said to Anders ----- I`ve now fixed the need to upgrade my RAW conveter too - I`ve written a Batch file for GSAR to "Turn" Em5-II RAWs "into EM1" ones - it alters the identification text in a folder full of ORFs in one go - I checked it on some downloaded from P-Blog and it worked
AdamT
this was one of the plusses, it can be folded in to make the cam "Visibly Silent" easily as well as acoustically and protect in storage
Brian Wadie
I forgot a big plus of the folding screen - no more nose prints on the LCD (sound stupid but it really used to brass me off having to constantly wipe the screen clean )
Brian Wadie
a few examples with the mk2
just in case you are interested
studio
https://www.flickr.com/photos/75445098@N04/sets/72157652230013050
macro
https://www.flickr.com/photos/75445098@N04/sets/72157651925548450
a variable set, street, landscape etc
AdamT
Re: a few examples with the mk2
Thanks Brian , lovely examples .. I`m not expecting much of a difference at any ISO to be honest, if its an updated version of the Sony sensor in the EM10, it ought to be better at Chroma noise at high ISOs and long exposures but I doubt even that is night and day  ..
Two features I never use on the EM1 are Continous focus (tracking or otherwise) and it`s ability to use 4/3 glass
Brian Wadie
thanks Adam, likewise - I have never used continuous focus (except as a test), with either my canon pro kit or any of the EM's
The EM-1 with 50-200 SWD was a remarkably good combo for my action sports and nature work, I'm now waiting for the 300mm f4 to arrive, that + the 1.4Xtc is going to be a dream system on the EM-5 mk2
Joe Lynch Veteran Member • Posts: 3,186
AdamT--I got a 5ii a few weeks ago and use it with a 12-40Pro.  I also have an E-M1 but, since getting the 5ii, I only use the E-M1 with the 4/3 lenses, usually the 50-200 SWD and 1.4.  If I could only have one body, it would be the 5ii, and I would just get the 40-150 Pro.  The video is good on the 5ii, the IS is excellent, and I love the flip out screen.  I really like the fit and feel of the 5ii as well.
I'm sending in the E-M1 for a replacement left side eyelet lug and replacement of the top plate and rear dial.  I will defer my long zoom shooting for a few weeks and enjoy the E-M5ii while the E-M1 is gone.   I can lug around an E-5 with the 50-200 SWD for a few weeks.
If I didn't have 6 E-series lenses I would have chosen the E-M5ii over the E-M1, I think.
Joe
 Joe Lynch's gear list:Joe Lynch's gear list
Sony a1 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +5 more
dulynoted
dulynoted Senior Member • Posts: 2,267
actually the em5 mark 2 video is better than ok. Its quite good compared to most options from nikon or canon. Just when compared to sony and panasonics fantastic video it is lackluster. I have heard several videographers say that the video is equal to that out of a 5dmark2 but benefits from crazy good stabilization. You should watch some videos shot with it.
em5 mark 2 has no aa filter
AdamT
Well that says it all !! ......... Really warming to the idea, the cams will meet on Saturday to given the guy a chance to see the 14-35 and 50-200SWD on the EM1 and for me to see the 5-II . He`s set on the EM1 and even if I don`t do the deal (which is unlikely after the way this thread has developed) he`ll part-ex it for one anyway .
The laugh is that the easiest way to reset the EM1 is to load the new firmware - LOL
Thanks Joe
AdamT
I`m amazed its even usable from Oly as I carry an LF1 for vid snippets if the GM isn`t handy or the lens on it isn`t long enough - I`ve not had a main M43 camera which shoots half passable video since changing the GX7 for the EM1 ....
I find that hard to believe but then the 5D-2 is very long in the tooth - the "old" 550D almost matched it also apart from DOF, I guess the EM5-II`s grip having a headphone socket ought to have been a clue - maybe I ought to watch some vids from the EM5-II,
I`ve been so used to Olys dire Video performance from EP1 to EM1 it seems almost like a fantasy so have one that`s capable - Like Fuji in fact who have the record for the worst video imaginable - the last time they lead the field in Digicam video was the Finepix-S602 of about 13 years ago which managed 640X480 until the card ran out (everyone else was lower rez and shorter times) - Fuji have sucked big time since then .
thanks
Landscapephoto99 Veteran Member • Posts: 3,216
The video quality on the E-M5ii is actually quite amazing if people turn noise reduction down to low.  The preset values for noise reduction are too high which I think had a negative influence on some early video reviews.  With a slightly improved sensor, image quality up there with the latest APS-C, better  than the Canon, and all the features it has the E-M5ii is one of the best still photography / video cameras out there.
OzRay
OzRay Forum Pro • Posts: 19,428
thanks
This is a video that I took last year from a helicopter, the Vimeo compression reduces image quality substantially: https://vimeo.com/97571768.
The full story is here: http://australianimage.com.au/wordpress/index.php/a-matter-of-balance/
While the video isn't comparable to the GH4, it's not complete rubbish.
BTW, swap the cameras and let your friend enjoy truly great lenses.
Thoughts, Musings, Ideas and Images from South Gippsland
stefano martini Regular Member • Posts: 175
em5 Mk 2 is too small it not well matched to 12 40 every other consideration is misleading
 stefano martini's gear list:stefano martini's gear list
Olympus Tough TG-3 Canon G3 X Olympus OM-D E-M5 Olympus PEN E-P5 Olympus E-M1 +22 more
