EF 85 mm f/1.8 with 70D: front focusing?
Started Jul 1, 2015 | Discussions
pilou1253 Regular Member • Posts: 139
Hi all!
I have recently purchased the 85 mm f/1.8 and I made some first shots that were really nice, especially head shots. But today I tried some shots at longer reach (about 5 m) and I am surprised to see that the lens seems to front focus rather significantly.
On the image below, AF-point is located on the face (nose/mouth) whereas the focus plane is somewhere in the grass ahead of the character.
It cannot be that she moved or anything like that (I took several photos that all have the same problem).
When I shot at closer reach (head shots), I don't see the same effect, at least not at strong, which make the result acceptable.
I have been testing some MFA and although I did not have the time to make lots of test shots, it seems to solve the problem ... at longer reach only because with the correction, my focus is then completely messed up for head shots :-s
Doing my tests, I even noticed that at closer reach, the lens/camera can sometimes front or back focus. But this is maybe something I am doing wrong there.
My main issue is that I don't think it is normal to have this clear front focusing at longer reach. This makes the lens pretty tricky to use since I need to adjust the MFA all the time. Have other users observed similar behaviour?
I ask this now because I have a week or so to return the lens if I am convinced that it is the best solution.
Thanks for your help and feedback!
Cheers
PL
 pilou1253's gear list:pilou1253's gear list
Canon EOS 1000D Canon EOS 70D Canon EF 28mm f/1.8 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +7 more
Canon EF 85mm F1.8 USM Canon EOS 70D
Damoo Senior Member • Posts: 1,102
Re: EF 85 mm f/1.8 with 70D: front focusing?
Appears like a front focus issue unless u are constantly focussing incorrectly.
1. Can u try single point AF and use the centre point to focus?
2. Before MFA, try to shoot using a tripod on a static object which is located in the same distance.
3. If the problems persist, then perform MFA or exchange the lens.
 Damoo's gear list:Damoo's gear list
Leica M Monochrom (Typ 246) Olympus OM-D E-M5 Canon EOS 6D Sony a7S Canon EOS 5D Mark IV +16 more
arty H Senior Member • Posts: 1,546
I can't tell what is going on from this photo. I recommend photographing a person at 1 meter and at a distance, but focus on the near eye. If the lashes are sharp, you are fine. Another test is to stagger books in a bookcase, and photograph one of them. This way you can tell if the lens is OK, but be sure to stagger depth in front and behind the target book. There are also more formal tests, and you can check online.
The first 85F1.8 I got front focused too much. I sent it back for another that was OK. The AF was consistently in front in the replacement by about 1/4" and it is easy to compensate for that. This was with cameras without microadjust. If the lens is on at close distances but not far, that is a clear indicator that you need a swap.
zalle Contributing Member • Posts: 898
several primes have different focusing behaviours at different distances. It's annoying and you need to learn to live with it...
ELSOK4ME Senior Member • Posts: 1,026
Hello:
I am curious if you mean, or suggest for example, if I have a Sigma 50mm, f/1.4 (Canon mount) lens, could I expect to find MA adjustments, which produces sharp photos at one distance - would (or may) be off at further distances?
Thanks for your time,
Have a nice day...
Ed
jitteringjr Veteran Member • Posts: 3,608
My first copy of my 85/1.8 went back for focusing issues. Second is pretty solid. Get a stationary subject with good contrast in good light. Tape a magazine cover to your house outside or something but makes sure it's flat. Set camera up on a tripod and take a few shots in live view and then switch to through the viewfinder shooting. This will test the phase detection AF mode against the contrast detect mode. If the live view shots are much sharper than viewfinder, exchange the lens.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +9 more
Hello:
Have a nice day...
Ed
That's exactly what I mean.
OP pilou1253 Regular Member • Posts: 139
Hi all and thanks for your messages. I am currently on holiday and it s hard to find good conditions to make proper tests.
However, today's shots, using MFA, gave better results, for both closer and longer reach. To be continued...
Will keep you posted.
Cheers!
PL
Hi!
I found some time to make some more tests with fixed camera.
I was purposely at f/1.8 and tried to achieve focus when shooting at a magazine cover located ca 3-4 m from the camera.
AF-single point on the center AF-point.
As you can see on the pictures below, it looks like I need a MFA of +12 AF to get a good focus (almost as good as what I can get with Live View). But the difference with same test but without MFA is not super big, I find.
MFA: +12 AF
No MFA
Another thing: I did have rather volatile results, even with fixed camera. I do all I know to shoot without disturbing the focus (not moving if possible, single shot AF on center point, no recomposition), but are there other methods that could help improving my focus technique??
Finally, I think I can be rather satisfied in how my lens perform (and only wish to improve my technique). Do you guys also agree or do you see a clear indication that I got a bad copy?
Thanks in advance for your help!
Cheers
PL
cberry Senior Member • Posts: 1,127
My experience with an old copy of the same lens was that it required +18 MFA and produced fantastic results at f/4, very good results at f/2.8 and acceptable results most of the time at f/1.8. I didn't buy a copy of the lens although at f/4 the results were amazing simply because I put more money into a 70-200 f/4 IS - and had a 50mm f/1.4 which is a lot more erratic.
The 85mm would have been a keeper though but not if I didn't have MFA.
cb
 cberry's gear list:cberry's gear list
Canon PowerShot G7 X Canon EOS 70D Canon EF 70-200mm F4L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 24mm F2.8 STM +3 more
