NX10 Firmware change.
Started Jul 1, 2015 | Questions
Beej New Member • Posts: 5
I have acquired a Samsung NX10 which has had NX11 firmware 01.12 added to it.
I have the original NX10 firmware DVD.
1.  How do I delete the NX11 firmware as it i want to install version 01.32 of the NX10 firmware.
2.  How do I get the NX10  firmware I have on the DVD into the camera.
Samsung NX10 Samsung NX11
Coldamus Senior Member • Posts: 2,281
Re: NX10 Firmware change.
You may be stuck with an NX11. I'm fairly sure that NX11 firmware 1.11 was the last that contained the hidden service menu. You would need to access that menu to downgrade the firmware or to load NX10 firmware again.
Similarly, N10 firmware 1.31 was the last that contained the hidden service menu. If you manage to reload NX10 firmware but want to leave open the possibilty of upgrading to NX11 again, do not load NX10 firmware later than 1.31.
Currently your camera thinks it is an NX11. The method of accessing the hidden service menu on an NX11 was as follows:
Set Mode dial to Smart Auto, Switch on, Press Up (top of 4 way controller), Press OK, Press Down (bottom of 4 way controller), then press OK once while holding down the +AV button.
If that doesn't bring up the hidden service menu, it probably no longer exists.
EDIT:
On second thoughts, I haven't tried this but you may be able to achieve what you want using the normal firmware upgrade option from the standard menu, provided the version number you try to load is higher than the existing version.  i.e.  Your camera is currently on NX11 firmware 1.12, so it may be able to load NX10 firmware with a version greater than 1.12.  The original version on your DVD won't meet that requirement, so download 1.31 or 1.32 from the Samsung web site.
From the downloaded zip file, extract the file nx10.bin, rename it to nx11.bin and copy to the root directory of an sd card.   Ensure the battery is fully charged.  Insert the sd card and switch on.  Go to the utility menus (gear icons) and find and select "Firmware Ugprade".  (It is in the 3rd utility menu on nx10, hopefully also on nx11).   The version numbers of current camera and lens firmware will be displayed.  If this is going to work, the option to upgrade to the version you put on the sd card will be available.  Select that and continue as if it were a normal software upgrade.
Demigod New Member • Posts: 1
Where would one find old firmwares for the NX10 and NX11. I can only find the v1.32 for the 10 and 1.12 for the 11
itsmepaul57 New Member • Posts: 8
EDIT:
Hi I have recently purchased a second hand NX10 and I have been trying to update it to the latest firmware. 1.32. I have copied the Bin file to the sd card as instructed - camera battery fully charged - switched on and when i get to the Firmware update menu both the body and lens update menus are greyed out and unselectable! Any ideas would be gratefully accepted because right now im taring my hair out. The current firmware is the one the camera was initially installed with. Best regards P Edwards
QdotJ New Member • Posts: 2
I replied to your original post; but will ask again. What firmware is currently installed on the camera?
aloosecanon Regular Member • Posts: 151
Hi Paul
If the firmware on your NX10 is below 1.15 then you will need to upgrade to version 1.15 before you can go any higher. Samsung still has firmware version 1.15 on their website for this purpose.
https://www.samsung.com/uk/support/model/EV-NX10ZZBABGB/
Download version 1.15 and install it. Then you should be able to install version 1.32.
