CNC macro rail
Started Jun 30, 2015 | Discussions
Flashlight Veteran Member • Posts: 8,545
Re: CNC macro rail
Luisifer wrote:
Thanks, i thinking about it too. But for this case i need to use some MF or LF lens i.e. Schneider 80mm f/5.6 Apo Digitar M.
For now i don't have such a kind of lens. For now i have only modern lenses with electronic aperture and with moving lens assembly where i need to have lens on body.
You can use old lenses from an enlarger like these: http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR12.TRC2.A0.H0.Xenlarger+lens.TRS0&_nkw=enlarger+lens&_sacat=0
Lenses like the Schneider you mention are not very suitable as they are much less sharp per square mm than normal FF lenses, you need a really big 'sensor' (film) to use them successfully.
You'll need a bellows too: http://www.ebay.com/sch/Lens-Adapters-Mounts-Tubes/30059/i.html?_from=R40&_nkw=bellows+camera or you can make something yourself.
Philip
Luisifer
OP Luisifer Contributing Member • Posts: 631
Re: CNC macro rail
Yep, it will be definitely some my own solution. But someday... manana.
____
Mentioned Schneider has only 80mm image circle (at 1:1 magnification i expect)
https://www.bhphotovideo.com/c/product/468642-REG/Schneider_03_017942_80mm_f_5_6_Apo_Digitar.html
so it is not so large - but in case of 3D movements of DSLR it would be better with larger image circle than only about 44mm covering FF sensor .... on the other hand this lens was example only
 Luisifer's gear list:Luisifer's gear list
Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
Luisifer
Re: CNC macro rail
Today i tried create small application:
and now i am processing images from this movie:
https://youtu.be/KFqQAy6kfbU
Here is the result for tonight:
Next test (maybe tomorrow night) will be with changed application that there will be slow coherent motion (only one HTTP REST call) with simultaneous exposures in concrete interval. I expect setting with recording to CF (no online downloading RAWs to PC - it is slow) with 0.5s between each exposure....
...ok, application is modified on both side (C# on PC and C on Raspberry too) and works thanks to sending space for starting exposure to the EOS utility only once per second. So i slowed down the movement to 100 steps per second for this purpose. The test with some subject comes later.
Luisifer
Re: CNC macro rail
And the test of smoth motion, 100 steps (20 micrometers) per second, one frame per second, 160 frames total:
https://youtu.be/2S93Mr5vLzA
Luisifer
Re: CNC macro rail
One Primula from today's 350 frame stack:
Larger version: http://12in.cz/fotografie/obr/88_Prvosenka
TBLF Senior Member • Posts: 1,389
Re: CNC macro rail
That is a cool aspect view of a primrose! Almost need a reference pic to get your bearings.
EricV
 TBLF's gear list:TBLF's gear list
Sony a7R V Sony FE 200-600 F5.6-6.3 Sony FE 55mm F1.8 Tamron 24mm F2.8 Di III OSD 70-200mm F2.8 GM II +1 more
Luisifer
Re: CNC macro rail
So another detail. This time violet with magnification about 7:1 thanks to extension tubes and 400 frames stack.
Larger version: http://12in.cz/fotografie/obr/89__30_Fialka
And some from backstage:
Luisifer
Re: CNC macro rail
There is some small progress which is on the side of Win app. I am preparing new version based on WPF:
http://12in.cz/temp/MicroStePi.zip
And one new stack. But it is very huge crop (about 6 Mpx from 30 Mpx source).
Luisifer
Re: CNC macro rail
One new photo 210 + 210 frames, larger version: http://12in.cz/fotografie/obr/91_Vosa
Wow
Didn't click for the high rez version because I want to sleep tonight
Philip
BobORama
BobORama Senior Member • Posts: 2,842
Re: CNC macro rail
That's sexy!
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Luisifer
Re: CNC macro rail
And another one, 170 frames
larger version: http://12in.cz/fotografie/obr/92__1_Bzucivka-obecna
Luisifer
Re: CNC macro rail
One new with magnification about 7:1, 190 frames.
Larger version: http://12in.cz/fotografie/obr/94_Bzikavka-slepoocka
Luisifer
Re: CNC macro rail
Some small progress, Canon SDK is included in my windows WPF app, already added functions: Detection of camera, exposure setting, LiveView, Test shot.
(test are directly downloaded to HDD, real shots will be stored on CF/SD for faster writing and downloaded at the end by button to other folder than test shots)
Mystery Gardener
Mystery Gardener Contributing Member • Posts: 838
Re: CNC macro rail
Fantastic photos in your previous entries, very interesting build. Will I have to come to Czech Republic to get one of your custom CNC rails?
Cheers, James
'The question is not what you look at, but what you see'
Thoreau
Luisifer
Re: CNC macro rail
I don't expect to travel with this gear even if I go to visit my sister in Vancouver. But i don't have other one custom cnc rail and i'm not expecting to build more pieces.
Benjamin51 New Member • Posts: 1
Re: CNC macro rail
A recommendation for a simplistic linear motor instead of using a home made ball screw assembly is this: https://www.oyostepper.com/
