CNC macro rail
Started Jun 30, 2015 | Discussions
Luisifer
Luisifer Contributing Member • Posts: 631
CNC macro rail
I know that macro digitizing stool is not completed yet but let open my second small project in the very beginning phase.
Target:
- precise (about 1 to 10 μm) and solid / rigid construction of CNC moving for DSLR body (w or w/o lens ... possible lens on bellows)
- start with 1 axis ... afterwards possible 3 axis movements of DSLR body
- the shortest possible lag between requests and start of motor stepping (app on client side directly communicate with something like Raspberry Pi 2 and controller app for drivers of stepper motors)
- possible usage in nature (not only in "studio")
The beginning, here are 16 mm rods and couple of other parts of linear technology:
The following steps:
- absolute measurement of position via something like this:
http://www.renishaw.com/en/linace-absolute-inaxis-linear-shaft-encoders--17800
- moving via stepper motor with something from HIWIN:
http://www.hiwin.com/ballscrews.html
 Luisifer's gear list:Luisifer's gear list
Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
CheleA Regular Member • Posts: 269
Re: CNC macro rail
I'm sorry, I can't tell if you are asking for guidance or just stating what the project will be:(
Let's assume it's the former, the one drawback to the round rails is that you will need two. It can get tricky to maintain perfect alignment to avoid binding. Plus you will need two platforms(one to hold the rails and one to hold the camera to the rails) adding weight and bulk. There are square/rectangular rails that are very steady and you can use a single rail by itself without the need for a supporting base. Plus the round rails tend to be higher profiles compared to rectangular ones. One thing to keep in mind is that those things are a bear to machine! ONLY carbide/diamond tipped tools can cut into those things, high speed steel will only scratch the surface! Regardless of which style of rail you pick, they tend to be fairly heavy. BTW, I'm not trying to talk you out of it -- it's just that I used to be a CNC/EDM programmer in a former life and we had to work on those things. We used to get the rods separately from the aluminium bases. The bases were predrilled but not the rods and we used to drill rods up to 12 feet long in diameters from 3/8" to 2". I absolutely hated those suckers!
A square rail sample:
http://sktbearing.en.alibaba.com/product/1394023772-221619562/Taiwan_brand_CNC_linear_motion_guide_linear_guideway_rectangle_wheel_lnear_rail_series.html
Luisifer
OP Luisifer Contributing Member • Posts: 631
Re: CNC macro rail
Thanks for the reply. This thema may by one man show but other suggestions are welcome too.
The rectangle guideway i am using for the digitizing stool. But for this purpose i was thinking to try use something other.
On the first photo there are two round rails which will be mounted together with ball screw. On one side of the rails and ball screw will be stepper motor (holder). On the other end of round rails will be holder of DSLR. Two ball cabins will be connected together on some platform for mounting to tripod or for mounting to next axis.
This first photo is my own ... so this things are already at my hands so they will be used certainly.
Re: CNC macro rail
Here is another option for the drive mechanism http://www.thomsonlinear.com/website/com/eng/products/ball_screws_and_lead_screws/lead_screws/xc_adv.php
You can get those to use screws as small as 3/16", reducing the weight/bulk/price.  Of course, if you want absolute precision -- you need a precision ground ballscrew:(  Keep in mind that not all ballscrews are precision or zero backlash.
I had tried to make something similar to what you are doing, however, I couldn't come up with a design that I liked.  One major difference is that I didn't want/need the automation you are trying to accomplish -- there was no need back then, it was just 35mm and no option to focus stack.  The only device I came up with, and liked, was this.  I do a fair amount of macro but don't go past 1:1 and haven't tried stacking -- yet.
Luisifer
Re: CNC macro rail
I expect to use something like 12mm from this ball screw line:
http://www.cncshop.cz/fsi-din-matice-sroub
With micron measure device from first post.
It should be used with MP-E lens, so 1:1 to 5:1. But maybe with other lenses too. (Not only under the 5:1 mag. But over 1:1 too ...)
F.e. later with some macro lens for middle/large format.
Re: CNC macro rail
If I may ask, what's your expected budget?  I have been out of that field for a long time, but back then none of those things were cheap.  You might try to find salvage/surplus stores and hope to find things like these.  There were two where I live but are long gone.  Will you be doing the CNC work yourself?
Luisifer
Re: CNC macro rail
I would like to do it as precise as i am able. So no budget is set for it. But together it means longer time to the finish.
A lot of things i buy on our local store http://cncshop.cz there is most of the necessary things.
And CNC thing has to be on my own. Hope that i will able to solve it. Because i would like to push my skills forward together with the hobby. Later i would like to build my own "hobby" 12x20" camera with complete "remote touch screen control" with possibilities of technical camera. So this will be the step forward before the biggest project from my own hands...
(only small targets... )
Luisifer
Re: CNC macro rail
grasshpr
grasshpr Contributing Member • Posts: 540
Re: CNC macro rail
Depending on your load, you may need to stiffen up your shaft along the radial direction. Something like this: http://www.pbclinear.com/Linear-Shafting-Support-Rails
If your load starts bending your shaft, it will bind on your linear bearing.
A recommendation for a simplistic linear motor instead of using a home made ball screw assembly is this: http://www.robotshop.com/en/firgelli-technologies-l12-30-210-12-p.html
They come in all different lengths and have built in potentiometers (pretty easy to measure in comparison to encoders).
 grasshpr's gear list:grasshpr's gear list
Sony a6500 Sony a7 III Sony DT 16-50mm F2.8 SSM Sony E 55-210mm F4.5-6.3 OSS Sony E PZ 18-105mm F4 G OSS +9 more
Luisifer
Re: CNC macro rail
Hope that used guide rods not to bend on load. The length is 500 mm and diameter is 16 mm, induction hardened (62HRC). It is not lightweight construction. It is more like a tank. But small weight is far to the top of important parameters this time. The most important parameter in this my "DIY CNC rail project" is ultimate precision. Precision goes together with nonbending/robust solution after load by attaching camera and other parts.
Now i tried to load it by my weight (about 85 kg) and it was still moving without trouble.
No way to bend it via more than twenty times lighter real equipment.
http://www.robotshop.com/media/files/pdf/l12_datasheet.pdf
The second hyperlink looks good but two parameters miss the target:
- Datasheet say 100mm max stroke. It is four times less than this axes needs
- Positional accuracy about 0.1 mm - my expectations are with precision at least ten times better.
grasshpr
Re: CNC macro rail
If ultimate precision is what your after, then with 500mm stroke and 85kg combination, you should think about stiffening that shaft as 16mm is quite small.  You will definitely have significant bending to the point where your linear renishaw encoder will have alignment issues.  I've used those encoder's in my workplace, and tbh, they are very sensitive to alignment issues, which mostlikely will be your worst problem if precision is your ultimate goal.
Luisifer
Re: CNC macro rail
I expect that there will be some troubles but 85 kg was only extreme test when i was writing the answer. One end will be with stepper motor, driver, etc. (about 2 kg max) other side with camera, lens, etc. (about 2 kg max too). Ends of the rails will be loaded about 5 kg max when it is sumarized from point of SMAL double closed linearset which will be attached to a tripod or other axes.
Luisifer
Re: CNC macro rail
Third small step, attached Manfrotto 625:
TejasRamakrishnan
TejasRamakrishnan Junior Member • Posts: 32
Re: CNC macro rail
Sorry if I am going off-topic, but how do you get such nice backgrounds for the pictures. Is it added in PP, or some cloth?
 TejasRamakrishnan's gear list:TejasRamakrishnan's gear list
Canon EOS 600D Tamron AF 70-300mm F/4-5.6 Di LD Macro Canon EF-S 18-55mm f/3.5-5.6 IS II
Luisifer
Re: CNC macro rail
It is background from black colored paper (no real black on used light, but dark gray) with small tonal differences. In PP are those differences via curves "narrowed".
TejasRamakrishnan
Re: CNC macro rail
Thanks for answering.
Really nice shots. You are a pro.
And good luck with the build.
Luisifer
Re: CNC macro rail
Only amateur.
And thanks. Hope that i find some budget for next step...
craig66 Senior Member • Posts: 1,484
Re: CNC macro rail
You can buy complete linear rail assemblies including the stepper motor for probably little more than the cost of the components. Here's an inexpensive one that uses a trapezoidal screw and brass nut. This supplier has a number of types and lengths including ball screw driven units for not much more. Have a look in Store Categories on the left of the page:
http://www.aliexpress.com/store/product/ST-200mm-Linear-Guide-Moving-Table-T-screw-slide-Slip-way-1Pcs-42-Stepper-Motor/1986599_32647250431.html
 craig66's gear list:craig66's gear list
Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 500mm F4.5 EX DG HSM +10 more
Luisifer
Re: CNC macro rail
Fourth step will be attaching ball screw etc.
http://12in.cz/fotografie/velka/71_Linearni-technika-IV
petrochemist Veteran Member • Posts: 3,619
Re: CNC macro rail
Looking very good but I suspect there might be issues having the tripod plate right at one end.  With the camera all the way to the far end from the tripod mount you'll be rather prone to vibrations...
A  rigid board/sheet linking both the lower mounts with the tripod fixing central would seem a better bet to me.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
