ND FILTER & polarizer for Samsung NX 16-50mm F3.5-5.6 Power Zoom & Memory Question for NX 500
Started Jun 30, 2015 | Discussions
antonio pepe New Member • Posts: 7
i have ordered an Nx500 with 16-50 pz and a 45mm 1.8
i want ask u if is possible to mount an ND filter on top of 16-50 and if it remain attached when shutdown the camera via to the movement of the zoom.
from the specs on internet i read that must buy a 43 mm filter ?
i want to buy a variable nd filter like this
http://www.amazon.it/Concept-Variable-Neutral-Adjustable-Cleaning/dp/B00JL4IFL2/ref=sr_1_1?ie=UTF8&qid=1435686620&sr=8-1&keywords=filter+43mm
or is best an fixed nd version ?
Another question is for the memory choice...
for 4k 70 MBPS its right choice this
SanDisk Extreme Pro Scheda di Memoria SDXC 64 GB, 95 MB/s, Classe 10 UHS-I ?
http://www.amazon.it/SanDisk-Extreme-Scheda-Memoria-Classe/dp/B005LFT3UW/ref=sr_1_fkmr0_1?s=pc&ie=UTF8&qid=1435668348&sr=1-1-fkmr0&keywords=SanDisk+Extreme+Pro+Scheda+di+Memoria+SDXC+32+GB
thx for yours time from italy
Samsung 16-50mm F3.5-5.6 power zoom Samsung NX 45mm F1.8 Samsung NX500
creaDVty
creaDVty Senior Member • Posts: 1,431
Re: ND FILTER & polarizer for Samsung NX 16-50mm F3.5-5.6 Power Zoom & Memory Question for NX 500
Hi Antonio! Benvenuto!
Yes a 43mm ND filter or variable ND filter will work with the 16-50 f/3.5-5.6.
Yes the Sandisk Extreme Pro 95 mbps is a good SD card.  I tried it with 4k mode at PRO quality and it was able to record the video.
By the way, do you know that the 4k mode on the NX500 is cropped?  A 16mm lens looks like a 27mm lens.  I just want to make sure you already knew.
Best regards,
Mic
www.BetterFamilyPhotos.com
TTL Flash Tutorial and over 900+ other original articles for taking better candid and family photos.
http://betterfamilyphotos.blogspot.com/p/better-family-photos-index.html
Flickr page: https://www.flickr.com/photos/13451101@N05/
 creaDVty's gear list:creaDVty's gear list
Fujifilm FinePix F31fd Panasonic Lumix DMC-LX5 Fujifilm FinePix Real 3D W3 Sony Cyber-shot DSC-RX10 Olympus Stylus 1 +29 more
OP antonio pepe New Member • Posts: 7
thanks to the fast response
i know the crop factor in 4k & UHD mode ...
soon as possible i will buy a 12mm for a bit wider angle...
but we hope that Samsung update the firmware and give us the full sensor read
thx
antonio
