cyan in magenta
Started Jun 25, 2015 | Questions
Gabone New Member • Posts: 9
cyan in magenta
Hi,
I have an Epson L800 for 8 months. Last month started to print cyan into magenta. If I try to print a red image, the first line of, let's say 5mm in height, is smeared with dark ink. Only the first line. The rest of the image is a clear red and has no problems.
I am attaching two pictures with tests for cyan and magenta. The pictures are not very good, took them with my phone this morning. Please excuse the quality.
I would appreciate very much if you could tell me or if you have any idea of what might by the cause for this.
Thank you.
Gabriel
OP Gabone New Member • Posts: 9
Re: cyan in magenta
Here is another picture of what it prints.
Thanks.
Re: cyan in magenta
Anybody?
Vernon D Rainwater Forum Pro • Posts: 15,052
Re: cyan in magenta
Gabone wrote:
Hi,
Thank you.
Gabriel
I am not familiar with your printer Model but have five (other models) of Epson printers.
Do you have a GOOD Nozzle check with no broken (missing) areas. Also, your 2nd printed example indicates your Printer needs to be aligned which for my models that is an option in the Setup information where nozzle check, ink status, etc; is located.
I am assuming you are not using Bi-Directional printing where the printer prints in only one directional pass -- sometimes referred to as economy mode.
Any information you can provide regarding these mentioned items will help other to better assist you with your printer issue. I seriously doubt with such a (near new) printer that there is any serious print head problem. One of my Epson printers is over 10 years old and continues to print as when new. I do regular cleaning and maintenance for all my printers. My newest (a 3880) is over 2 years old.
Vernon...
Re: cyan in magenta
Hi Vernon,
Yes, the nozzle check is fine except that cyan and magenta are a little mixed. The lines are straight and as they should be.
It is a possibility. I will try to do that again, even though I aligned it a couple of weeks ago.
No, I am not using bi-directional. As far as I know in my driver it is known as High Speed, if I am not mistaking. I also read on other forums that bi-directional printing is causing banding or other problems.
Vernon...
The economy setting, besides mixed cyan/magenta also prints thin horizontal bands, but the photo setting prints only the smudge on top (the attached red colored print). Others said on the forum that the waste ink pump might not work, and the ink is soaking on the waste pad, and because of that the ink is sucked up the printhead capillary tubes or whatever they are. I do no know if this is the problem here.
Thank you very much for your answer.
Gabriel
Re: cyan in magenta
I also tried to drain the waste ink pad with a syringe and distilled water until there was no ink left in the pad. I dried out the pad using paper towel. I also cleaned the rubber piece near the pad. But still the nozzle check had the same cyan/magenta mixed ink on the paper.
Re: cyan in magenta
I took the printer to an authorized service dealer and they said the printing head is faulty and has to be replaced. Now they are waiting for the print head delivery to replace it.
Thanks.
Gabriel
John1990 New Member • Posts: 3
Re: cyan in magenta
I have exact same problem. I didn't contact the service yet.
It seems to be a common issue. I found a few Russian threads about it.
I wonder if your problem was resolved.
Thanks!
mikling Regular Member • Posts: 289
Re: cyan in magenta
This was a common mode of failure in the original Epson printers after the R200 based ones. The R260, R280, R380, RX580, RX595, RX695, SP1400 and possibly Artisan 50 and Artisan 1430 as well. Only time will tell.
What is happening is that the printhead is built up on layers and each ink channel is separated but joined by the adhesive or material between each layer or lamination. The ink is slowly leaking through a crack between each layer. When the crack is small, it is slow and mainly not noticeable. Over time time the crack/leak gets bigger and it worsens to the point it is noticeable. The first hint of this is a nozzle check that shows some steps to be miscolored and then goes away with use.  If this happens when it is new, it is indicative of a defect in manufacture.
The next stage is when the printer is not used for days and then you get miscolorations that takes a head cleaning to clear up. At this point the leak is so slow that during use, it is not leaking fast enough to create a discoloration. Eventually a period of a few hours will cause discoloration.
The final stage is when it is bad enough that a head cleaning will not clear up the contaminated color. On the mentioned machines it was always typically between yellow and black, obviously yellow that was contaminated with black. If yellow had leaked into black, it likely would not be noticeable.
I had 5 printers from the above list that all exhibited this problem. It appears to be a weakness in the design or fabrication of the printhead.
Re: cyan in magenta
Thank you for detailed info. Mine is still under warranty so I hope I can get the print head replaced. Even if they replace it, new one will probably have same issue eventually.
Gesture Forum Pro • Posts: 10,749
Re: cyan in magenta
Saw the same thing with my SP1400 to a tiny degree.
aads New Member • Posts: 3
Re: cyan in magenta
Gabone wrote:
Hi,
Thank you.
Gabriel
My Epson L800 printer also has the same color mixing up, cyan and magenta. Since it is past its warranty period, I decided to get into the head and clean it. But to no avail. Same results in Nozzle Check.
Having read Mikling's comment re printhead defect even in previous model, I am having second thoughts if i will have the printhead changed or not.
The cost of the printhead here is about the price of an Epson ME-10 which I am considering for specific printing jobs and plan to change the ink with pigment because of its minimum droplet volume of 4pl. I thought this size will give minimal problem with head clogging. Or I may not be right.
I hope you can still update your post about the new printhead. I've been looking for similar issue and I'm glad I found this. Thank you. God bless you.
Re: cyan in magenta
Hello again,
I did not know that so many of you had the same problem. I am glad that you also posted your problems. Maybe we will find a solution... not by changing the printer, I hope
My printer worked fine for almost an year after they changed the print head. At least that's what they said. I have no idea if they did that or something else. Well, recently, I noticed that the yellow is contaminated with black (or it seems to be black, or some combination of some of the inks). It seems that it's leaking ink over the sponge cap. Every other day I clean that sponge with a piece of paper towel and I can tell it is saturated with ink. I think that the print head is getting dirty by sucking ink that leaked in that sponge. Because after I print a page full of yellow, it is just fine. I can print for hours without any problems.
I suspect that the CISS system is leaking, but I do not know how to prove it, or how to fix it. It's not only the black (still I am not sure if it is the black, or too much cyan, or some other combination) that is leaking. I also saw a lot of yellow on the paper towel. At the moment the printer is low on ink, and I still do not know what to do. Should I buy new ink, or just throw away the printer and buy a new one?
Thanks.
Gabriel
Re: cyan in magenta
Just to make an idea of what I managed to clean from the sponge where the print head rests:
Petruska Veteran Member • Posts: 9,361
Re: cyan in magenta
That's normal for any capping station sponge..........
Bob P.
Re: cyan in magenta
Well, it seems that Mikling was right. I think the print head is gone. Take a look at the nozzle check. Not only the black is in yellow but also cyan is over magenta. So I guess this printer will go to garbage can (maybe I will keep the CISS). This is the second print head that is gone in 2 years. I will not buy a third one.
This is a one time use, disposable printer, just like condoms. If you are lucky (mine broke down after 6 months) you can print the full set of inks that comes with it. If Epson would make condoms, the world would be full o paternity suits. I am not saying that their products are not good, but this one is a total failure.
Re: cyan in magenta
Gabone wrote:
Hello again,
Thanks.
Gabriel
Hi Gabriel.
As of now, I haven't brought the printer for repair. It is out of warranty so i have to save for the head replacement. But my daughter can still use it for document printing for her homework. The black nozzle is still in good condition (at least 90%, I suppose). I also use it for printing positives on inkjet transparency for t-shirt printing.
I still prefer to use this printer for photos when it is in great condition.
As for the leak you're experiencing, it happens to mine, too. It seems it has to be cleaned and nozzle-checked when left turned off and idle for a long time. You are doing the right thing. cleaning the sponge in the capping station as the ink will not be completely drained out. Using an external waste ink tank, Soaking with a cleaning solution will help loosen any dry ink in the station. I would suck it out using a syringe through the tube.
You said, "My printer worked fine for almost an year after they changed the print head." Does this mean your are now unable to use the printer?
Have you printed photos after the head replacement? How was the quality?
Thanks.
Alex
Gary R. Veteran Member • Posts: 3,216
Re: cyan in magenta
Thanks to Mikling for the detailed answer given above.  I have an Artisan 50 which I used to love for its easy, brilliant, "looks like the screen" photo printing (as opposed to my R1800 which is absolutely horrible in trying to match screen to print).
I didn't use the Artisan for most of a year, and fully expected to have to do some cleaning/cartridge replacement, which I did, and the nozzle check showed it was firing on all cylinders.  I didn't notice that a few lines of the cyan had "traveled" over to the magenta part of the nozzle check, but when trying to print I was getting muddy areas, mostly in the shadows that were not dark black.
I even bought new cartridges, thinking that mine may have been outdated, though that's never been an issue before.  Still muddy shadows, though with enough manipulating of the photo I was somehow able to get a few prints that looked OK.
But this was nothing like the old Artisan 50...which always gave such great prints with no hassle.  So I cleaned everything, pads, under the print heads, nozzles repeatedly, but still had that puzzling cyan traveling over to the magenta nozzle check.  Finally found a productive Google search which led me here.
I'd have fooled with this thing forever, perhaps wasting more money on new ink, had it not been for the explanation of the de-laminating print head, so thanks a bunch for saving me the trouble and money.
In my personal opinion, since this is a common issue (apparently), Epson should replace the printheads no matter whether in warranty or out.  It's defective, plain and simple, and I did nothing to cause it other than use the printer.  But fat chance of that, so I yanked the plugs and to the trash it goes.
Thanks again to the OP, and Mikling for the detailed explanation which was clear enough that I won't bother to try to fix it.
 Gary R.'s gear list:Gary R.'s gear list
Casio Exilim EX-Z850 Panasonic Lumix DMC-LX7 Casio Exilim EX-100 Panasonic Lumix DMC-GH2 Canon Pixma Pro-100 +1 more
Pratik Thumbar New Member • Posts: 1
Re: cyan in magenta
No text.
ravenainotenshi New Member • Posts: 2
Re: cyan in magenta
I have a Epson L805 with the same problem. Thanks everyone for such an useful information about inkjet.
My solution is to keep using this printer as a black and white inkjet and buy a new one (except the model with the same print-head problem)
