Will I miss my 75m?? (purchase 40-150 pro)
Started Jun 24, 2015 | Discussions
flobcn New Member • Posts: 3
Hello.
I would like to buy the zuiko 40-150 Pro 2.8 but i would need to sale my 75mm 1,8.
Wil I miss my 75mm if i i replace it with the new zoom?
I use the 75mm for theatre photo with low light and few portrait outside. It is too long inside. I also doing basket photo of my dauther. The focus of the 75mm is however to slow and I maul use the 45mm that focus much more fast. Or a least it hesitate less.
I have the 17, 45, 60mm for my e-m5 I.
I like mainly to do macro and the new 40-150 could be a good complement of my 60mm for butterfly pictures. the zoom will also be nice for the theatre and live music of my children. Portait with a nice bokeh should be alright also for the children. basket ball would also be fine.
Other question. Wich filter would you recommend. Hoya pro1 or B&W. UV or neutral glass?
Thank you for your help.
lambert4
lambert4 Senior Member • Posts: 2,335
Re: Will I miss my 75m?? (purchase 40-150 pro)
Depends but at the current $959 for the 40-150/2.8 on the Olympus site you will miss it a little less.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
Skeeterbytes Forum Pro • Posts: 23,186
flobcn wrote:
Hello.
You're giving up more than a stop for theater work, which might be a problem. Optically the zoom is essentially as sharp and focus response is at least as good. It's pretty big on an E-M5 and I'd want the grip for that combination. It handles well on the E-M1 even without the grip.
The zoom's flexibility probably more than compensates for the lost aperture at 75mm, so in balance the swap is worth it in added flexibility.
Rick
bigley Ling Veteran Member • Posts: 4,490
I think you will miss your 75mm, as with m43 the faster the aperture more subject isolation can be achieved. The 40-150 pro is also substantially larger, so you will stand out more when you are taking those theater type shots.
There is no doubt though, for close up butterflies, insects, birding and sports, the 40-150 is the correct lens choice. Maybe you can find a way to have both!
Currently I have using B&W and find it to work well with my Olympus and Panasonic lenses
 bigley Ling's gear list:bigley Ling's gear list
Apple iPhone X
jackkurtz Veteran Member • Posts: 4,724
I have both. Both lenses are very sharp and excellent in every way.
I carry and use the 75mm f1.8 every day. I carry the 40-150 when I think I'm going to need a longer lens.
Advantages to the 75: much smaller and a better fit on the E-M5, a little more than a stop faster.
Advantages to the zoom: greater flexibility, weather proof construction.
I think the 40-150 is a brilliant lens. In FF terms, it's the equivalent of an 80-300mm f2.8. Include the tiny 1.4X teleconverter and you have the reach of an 80-420mm lens. For a little over $1500 US. That's pretty remarkable. In absolute terms, it's a small lens, about the size of a Canon or Nikon 70-200 f4 with a lot more flexibility than either. In Micro 4:3 terms, it's huge.
That said, I still consider the 75mm f1.8 as my principal telephoto. That's because I'm a prime guy (my other lenses are the Oly primes) and the 75mm f1.8 is about the sharpest lens in the Olympus inventory. I think it equals the Canon 135mm f2 L.
 jackkurtz's gear list:jackkurtz's gear list
Fujifilm X-Pro3 Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS XF 90mm Fujifilm XF 35mm F2 R WR +3 more
ediblestarfish Regular Member • Posts: 499
Depends what you like doing more.
The size and weight of the 40-150 really restrict it in some ways. It's not a very good walk-about casual lens the way the 75mm can be.  People don't really pay attention to my 75mm when I have it on the camera. People do take notice with the 40-150, for better or worse.
The shallow depth of field is better on the 75 if used in the same way, but the 40-150 can get a lot closer, so it can make up for that in a different way.
Preference for me is a tossup, and is based more on circumstance. If I go on an extended trip and can only take one or the other though, I predictably take the 40-150, along with the 12-40, and hopefully soon, the 7-14. Speed, flexibility, and time are the issues that really bring the pro zooms to the forefront.
If you got time to waste wandering about (and can use your feet to zoom), or a controlled setup to exploit to keep the 75 at its focal length optimum, the 75 is more enjoyable to use. However I just don't find it critical in any situation, save the very low light situations which are for me, less often needed.
The 75 is just an option for me, and nice to have, but not necessary.
Michael Jardine
Michael Jardine Senior Member • Posts: 2,006
A few galleries...
Honestly, if I had to choose between the two, and if I did not shoot night sports, and given that I travel - I'd probably stick with the 75mm. Both are beautiful lenses but the 40-150 takes you back into 'DSLR' territory, size-wise.
Lucky I don't have to choose. I love both lenses.
40-150 Gallery :
75mm Gallery :
Michael
www.Qamera.com
 Michael Jardine's gear list:Michael Jardine's gear list
Zeiss Batis 85mm F1.8 Nikon D800 Olympus E-M1 Olympus OM-D E-M10 Sony a9 +13 more
Bhima78 Senior Member • Posts: 2,850
Great shots!
That Snoqualmie photo is fantastic. Thanks for sharing.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
Michael Jardine
Re: Great shots!
Thanks!  I've had a number of comments on that particular one and it goes to show, you never can tell what other people will like. I only included that one in the gallery because a few others insisted on it.
Michael
www.Qamera.com
In full frame terms the DOF will be much wider though, so equivalent wise 80-300 (f5.6 for doetph of field) and f2.8 for light gathering.
This is another advantage to the 75mm f1.8, is it's ability to maintain a very shallow depth of field.
Apple iPhone X
eques Veteran Member • Posts: 4,115
Panasonic 2,8/35-100?
As far as size/weight is concerned, the  P2,8/35-100 is nearer to the 75mm, also in price.
And I think, resolution is on the same level as the O2,8/40-150.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Petar Veliki
Petar Veliki Regular Member • Posts: 256
folklor
I do folklor shot, so catching stage on medicore light. I do with 50-200 if far behind. But in smaller halles i used Pana 20 mm, but needed zoom, so bought Zuiko 45 mm. Wish 75 mm also, which will come in future.
I wouldnt change 75 mm for zoomer, unless always far back. Also 75 is considered as best m4/3 lens.
 Petar Veliki's gear list:Petar Veliki's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic G85 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +5 more
Fri13 Veteran Member • Posts: 3,116
Sharpness is same, your question is can you live with f/2.8 or d you need the f/1.8?
How about focal length?
Look your photos metadata what they have been shot at and it tells you what you need.
Michael Jardine
Size Matters
Another key difference is the size. The 40-150, though smaller than its' 'pro' equivalents in the DSLR world, is still a 'big honker'. The 75 is incredibly unobtrusive. If that is of importance to you.
Michael
www.Qamera.com
stevesaab New Member • Posts: 13
Re: Protective Filters
Everyone has an opinion about the need for front element protection. If you're in the 'protect it' camp then consider the Marumi brand thoughtfully sold by 2filter.com. The Super DHG Clear has been trouble free for me on all my lenses with no indication of image loss. You can 'buy up' to the Marumi EXUS offerings if you have B+W money. Remember that digital sensors are not sensitive to UV so UV 'protection' is not needed.
 stevesaab's gear list:stevesaab's gear list
Olympus E-M1
SkiHound Veteran Member • Posts: 3,939
They went fast.
Tried to order yesterday as soon as I saw the email, but alas, all sold out.
(unknown member) Veteran Member • Posts: 6,392
Michael...
great galleries.
do you shoot jpg or RAW?
Thanks,
Paul
Panny at 100mm isn't at the same level as the Oly 40-150 at 100mm though.
Peter
The Oly is definitely sharper at 100mm and goes to 150mm. Having said that, I personally wouldn't want to lug the Oly around and find the Panny 35-100mm to be a great balance of size, performance and price.
Michael Jardine
Always RAW
Paul Auclair wrote:
great galleries.
Sometimes shoot RAW + JPG (low res) when I know I'll be Tweeting photos via my iPhone, i.e. for sports events etc.
Michael
www.Qamera.com
