Switch to Sony for HDR Reasons? G7X vs RX100 M3/M4
Started Jun 24, 2015 | Discussions
greenarcher86 New Member • Posts: 15
I have always been a Canon user (Ixus 400, EOS 450D and S90). I love the interface and the colors.
Now that HDR has become a standard feature on mobile phone cameras, I realized it's about time to get a camera that has this feature and save myself a lot of headache when taking scenes with imbalanced lighting.
As you can see, all my cameras are for long-term use. The 450D is already 8 years old and the sheer bulk is no longer feasible for vacation trips. Basically I'm now looking for the best compact out there below $1000.
I've read the reviews and have seen the photo comparisons both in studio and real life. If there was no side by side comparison, the Sony colors would have been OK. Unfortunately it turns out Sony still produces slightly pale photos when compared to Canon. This is the biggest downer for me.
On the Canon side, I found out that the HDR feature on its cameras are either useless or too much. I want something "just right", something similar to what phones do, which the Sony does very well. The USB charging option is an added bonus.
Is there a way to "fix" the HDR on Canons? Or is there a way to make the Sony take similarly-colored shots to Canon in-camera without post processing?
Finally, which one should I get? The price matters but not entirely; since this will be a long-term investment. Should I wait for the G7X successor and hope they fill fix the HDR?
(BTW I rarely shoot videos, I don't shoot RAW, I rarely use the zoom and I don't have a lot of time to do post-processing besides tweaking the contrast, brightness, shadows and highlights.)
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon PowerShot G7 X Canon PowerShot S90 Sony RX100 III
Darjeeling Junior Member • Posts: 27
Re: Switch to Sony for HDR Reasons? G7X vs RX100 M3/M4
If there's a way to fix the HDR function, I can't find it. I contacted Canon about the "bug" and hope others do too; maybe they will release a firmware fix if enough people mention it (not likely, but we can dream).
There's always exposure bracketing, but it requires a bit of post-processing work.
brianj Forum Pro • Posts: 14,657
The Icontrast on canon cameras works extremely efeectively to enhance DR by rolling off the highlights curve and raising shadows, without applying too much HDR affect, I leave mine turned on to AUTO all the time, it just applies the exact amount depending on the scene.  Is that what you are after?
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
OP greenarcher86 New Member • Posts: 15
The results I want when I turn HDR on can be found on samples below:
http://maxcnash.com/sony-rx100-iii-in-review-the-best-performing-compact-is-back-with-a-vengeance/
http://photoframd.com/2013/06/03/high-line-nyc-2013-late-afternoon-walk/
Possibly similair to Icontrast, but a bit more effect, too much for my liking, but that doesn't matter because its what you want.
These albums show what Icontrast looks like:
http://www.dpreview.com/galleries/5128303546/albums/cruising
http://www.dpreview.com/galleries/5128303546/albums/central-australia
http://www.dpreview.com/galleries/5128303546/albums/vietnam-cambodia
Brian
Might be too much to ask but would you have sample shots comparing shots with and without Icontrast side by side? It's the only way I can see whether it can give me what I need or not.
Not at the moment, I haven't turned it off since I discovered it a few years ago.  I could do a couple of shots for you but I will need to wait until we have the sun here because that is where the DR enhancement does its magic.
Icontrast and the 'my colors' settings is just about the only reason I buy canon cameras.
Brian
B1ackhat Senior Member • Posts: 1,980
You can't even make the Sony take similarly-colored shots to Canon with post-processing.  Sony's RAWs are pre-cooked to a significant degree and most photos can't be color-corrected to resemble Canon/Olympus/Fuji whether you spend 5 minutes or 5 days processing them.
"We can judge the heart of a man by his treatment of animals." ~ Immanual Kant
requa
requa Contributing Member • Posts: 860
This may or may not help. Using my G7X, I took a series of photos with areas of full sun on white surface and areas in shadow. I figured this would challenge the DR mechanism. The first three are in P mode with auto ISO. I'm not seeing a huge difference between standard DR and 200% DR compensation (other than my 200% shot being out of focus), and both did a good job of pulling the flowers out of the shadow. The HDR version looks too dark to me.
Dan
Base scene with no DR or shadow correction applied.
Standard DR and shadow correction applied.
200% DR and shadow correction applied.
HDR mode.
 requa's gear list:requa's gear list
Olympus Stylus Tough TG-870 Canon G5 X II
damian5000 Senior Member • Posts: 1,948
This goes to show the standard hdr mode on g7x is virtually useless. Step it into 'art standard' and it does a much more obvious job, but with colors grossly oversaturated. For me not so unpleasant, but not very realistic either.
 damian5000's gear list:damian5000's gear list
Dan
HDR doesn't work at all, and the first normal shot the grass that is in the sun looks like its in dark shadows, but the one done with the DR and shadow raising the grass looks like its in the sun and the shadows under the tree are less deep.  To me the only shot that looks normal here are the ones done with DR enhancement, which I assume was Icontrast.
Brian
Dan
Brian
There was some big discussion about this in the past. It's not labeled as icontrast in function menu. It's DR correction and shadow correct. Icontrast is in playbakc mode. Not sure how they're related, but likely icontrast is the same as shadow correct as you've surmised, though the settings are different in playback mode (low med high).
requa
damian5000 wrote:
Dan
Brian
Exactly. The manual at p.77 says i-Contrast (in shooting modes) involves two functions of Dynamic Range Correction (correcting for blown highlights) and Shadow Correct, which are controlled independently.
semifast Contributing Member • Posts: 780
Brian
In the HDR picture there's more detail in the dark tree trunks than there is standard shot. And the tree trunks look like mud in the contrast altered pics.
It's hard to tell if the chairs are enhanced since there's basically no detail in smooth plastic chairs.
 semifast's gear list:semifast's gear list
Panasonic Lumix DMC-FZ200 Samsung Galaxy Camera 2 Sony SLT-A58
requa
semifast wrote:
brianj wrote:
Brian
I see what you mean. Playing with these images in Lightroom, if I bump the shadow slider to 100% it's pretty dramatic. I wasn't focusing on the tree trunks when I took or posted the images. I was looking more at the pot of flowers in mid-shadow. I may have to play a bit more this weekend. I don't think in-camera HDR is the approach I would choose, largely because of the slow processing time, but this may push me back toward raw capture, at least in tricky lighting like this.
Incidentally, the chairs are actually composite not smooth plastic. I don't expect you to care what kind of furniture I'm sitting on; I'm just pointing it out because the wood fiber/plastic composite material actually does have a very fine grain, but it's no surprise that it doesn't show in the photos given how bright the white is. I can see it with the naked eye, but only from close distance, and can certainly feel it.
Actually, this may be good news for me. I've been looking for evidence in my own photos to convince me that I should switch to raw. I suspect raw will give better detail without the lag and without the overall dark image of the HDR. If so, and if I can't figure out how to get the same in JPEG, I may finally be convinced.
Dan
Nobody is going to focus on one single area and pixel peep it. The question is what does default HDR do for pictures here, and the answer is virtually nothing. Try art standard, that produces more dramatic results, but vey saturated color.
I take it the Canon HDR has limited controls ?
I'm not sure about the RX100 but other Sonys, like the Nex cameras, have 5 or 6 levels of automatic HDR processing.
NIK11 Senior Member • Posts: 2,827
I have owned both RX100m2 and G7X and found the Sony HDR implementation much better than Canon's. G7X adds only 1 stop, degrades IQ substantially and my copy suffered from colour banding round the edges when negative EV was applied. RX has more range, degrades IQ slightly and better stitching.
But that's not the whole story. I found Canon's i-contrast that's adds 1+ stop of highlight retention (jpeg) superior to Sony's DRO equivalent (about 0.6 stop), in both cases no deterioration in IQ.
So I'd say it's a draw and unlikely to be a deciding factor for most buyers, I suggest.
Nick
I'm really puzzled with Canon. How can one of the pioneers and landmark companies in digital photography not be able to do something what all mobile phones can today...
I played around with my friend's RX100M3 and the colors are really too far off from Canon's.
Guess I just have to wait until Canon learns how to do HDR the right way...
Maybe canon is using HDR for what it is meant for, extreme cases of high DR which needs two images blended into one to cope, not for producing adsurd over the top cartoon looking images.
Brian
