Macro lens and adaptor for m4/3?
Started Jun 22, 2015 | Questions
Dan Richardson Contributing Member • Posts: 545
I was out hiking this weekend, and ran across some neat bugs and realized I didn't have a lens that could pop out a few macros.  I could get the 30mm macro for $400, but would like to go around $100 if I can - old manual focus lens and adaptor.
I know the adaptors are really hit-or-miss, so is there a good/cheap brand folks here recommend these days?  Getting the lens off at some point is a good thing.
what about lenses?  How's the Nikon 60mm 2.8?  Any others worth checking out?
Thanks!
-Dan
Panasonic Lumix G Macro 30mm F2.8
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: Macro lens and adaptor for m4/3?
Thanks!
-Dan
The Konica Hexanon AR 55mm Macro is typically available for less than $100, the Fotga AR to M43 adapter about $12. Hexanon lenses had a good reputation for sharpness. Mine is excellent.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
OzRay
OzRay Forum Pro • Posts: 19,428
You don't need a macro lens, depending on what lens/lenses you have, a reasonable quality extension tube set like the Fotga and/or a close up lens is all you need.
The extension tubes are good with long focal length lenses and the close up lens when it comes to wider lenses. And you'll have AF as well.
Thoughts, Musings, Ideas and Images from South Gippsland
http://australianimage.com.au/wordpress/
OP Dan Richardson Contributing Member • Posts: 545
Funny you mention the tubes. I picked up a Leica adaptor and a pair of tubes a few years ago and completly forgot about them. I'll give them a shot this week and see what happens.
My memory is that they shrunk the oly 45mm DOF to something crazy paper thin when I tried it. Hmm.. Now where'd I put them...
OzRay
With a 45mm you'll need a fairly thin extension tube, else the subject will be very close to the lens. Close up lenses work better in these circumstance, any from between +2 to +5. And for the 45mm, good ones should be reasonably inexpensive.
Martin Maier Contributing Member • Posts: 696
macro tubes for $35
 Martin Maier's gear list:Martin Maier's gear list
Panasonic Lumix DMC-ZS60 Panasonic Lumix DMC-GH4 Samsung NX500
farmer35 Contributing Member • Posts: 968
Thanks!
-Dan
I've had good results from Fotasy brand adapters in several different mounts.  I've bought them from Rainbow Imaging for about ten dollars each.
I have the Minolta 50mm macro lens and I am happy with it.  I've seen recommendations here for the Nikon macro lenses as well as for Canon, Konica, Pentax, Vivitar.  So probably whatever you come across that is in good shape for a decent price will work nicely for you.
RaymondR
RaymondR Senior Member • Posts: 2,496
most of the legacy macros are pretty good -- if you want to stay under $100, consider a Fotodiox adaptor and a Minolta 50mm 3.5 macro.  That goes to 2 to 1 and with the adaptor tube you can get to one to one.  if you want AF, consider a 4/3 macro (the 35mm 3.5 and the 50mm Oly 4/3 macros are both superb lenses) and the proper adapter (the Panny 4/3 to m4/3 adaptor tends to sell for a bit less than the Oly one).  This will likely push you over $100 and AF is not strictly necessary or even desirable for macro work.  I started with the legacy macro, moved up the 4/3 and found myself doing so much close up work I splurged for the Oly 60mm, which is one of my most used lenses.  For insect work, you might want more working distance, look at the legacy macros available at 90, 100, 105 and 150mm.  Not sure you can stay under $100 at that focal length.  KEH usually has a nice selection of legacy macros -- the prices are reasonable and I have find KEH to be fair on price and rating of lenses.
RaymondR
 RaymondR's gear list:RaymondR's gear list
Sony a7 II Sony a7C Sony FE 24-105mm F4 Sigma 70mm F2.8 DG Macro Art Tamron 17-28mm F2.8 Di III RXD +2 more
