Two bodies or an extra lens for my upcoming trip to Rome?
Started Jun 19, 2015 | Discussions
redli0nswift Forum Member • Posts: 91
As the title says, my wife and I are going to Rome in September.
I'm back and forth between picking up the 35-100 F2.8 Pany or for the same amount of money; a second body like the Oly E-PL6 (same battery as my E-M10), with a 20mm F1.7 Pany, and a 45mm F2.8 Oly.
Now, I'm buying this gear used for the most part to keep the costs down.  I would use the 35-100 to compliment my current setup.  I would use a second camera as a super lightweight choice for my wife.  This way we could both take shots of Rome. Your thoughts?
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Sirus Tripod ~13inches
Billingham Pro bag
Batteries (3)
Memory cards (3)
 redli0nswift's gear list:redli0nswift's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 50mm F1.8 STM Canon RF 15-35mm F2.8L IS USM
Olympus OM-D E-M10 Olympus PEN E-PL6
DonEvans New Member • Posts: 1
Re: Two bodies or an extra lens for my upcoming trip to Rome?
Just come back from the same trip. I used a 60mm with the tripod for some night photography.
Michel Bulte Junior Member • Posts: 30
two bodies. After changing lenses twice you will regret not bringing two bodies. Your wife will appreciate too for not having to wait while you change lenses
 Michel Bulte's gear list:Michel Bulte's gear list
Olympus E-M1 Fujifilm X-T4 Olympus PEN E-PL5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro +6 more
kaphinga
kaphinga Veteran Member • Posts: 4,081
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
I would lean toward a second body for the trip. A longer lens does come in handy occasionally, but not enough to justify carrying a 35-100 f2.8.  If you get in a jam, you can always switch on the digital teleconverter for the handful of shots when you really want the distant details. On my last two trips to Rome, I used the longer lens (the kit 40-150) mostly for architectural details around the Forum. Otherwise, it stayed in my camera bag.
You might also want to consider something wider than the 12mm on the 12-40. An ultra-wide comes in handy in places like the Pantheon.
I also like the idea of you and your wife both having cameras. She may be more patient with your shooting if she can shoot, too.
 kaphinga's gear list:kaphinga's gear list
Nikon D750 Fujifilm X100V Olympus E-M5 III Olympus E-M1 III Apple iPhone 11 Pro
Gravi
Gravi Senior Member • Posts: 1,546
different approach:
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
I would NOT visit Rome without an UWA. If I where you, I'd go for the Olympus 9-18mm lens. If you have cash to spare, add in an EPL6.
I think Rome is too compact to really get the best out of the 35-100mm.
Gravi
PatrickNSF
PatrickNSF Regular Member • Posts: 406
I'm in Rome now and have been in Florence, Venice, Switzerland and Paris this summer. I packed my 14-150 but only used it once while hiking on the Italian Riveria. I also packed my 17/1.8 and 25/1.8 but they haven't left my bag. I've used the 12-40/2.8 90% of the time. I have used my 14-42 EZ a couple of times when I wanted to travel lighter, and my Canon G7 X while biking.
Id skip the 35-100 and consider a wider lens. Had the 7-14/2.8 been available, I would have loved using that. Enjoy the trip.
 PatrickNSF's gear list:PatrickNSF's gear list
Canon G7 X II Sony a77 II Olympus E-M1 Olympus OM-D E-M10 II
3dwag
3dwag Veteran Member • Posts: 4,674
Two bodies...
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
You should get a second body:
- each of you can have a camera, and perhaps reduce lens change frequency
- backup in case one body fails on trip
Only question here may be, will you need a viewfinder for the E-PL6?
Additional lens considerations:
- not sure about the Panny 20mm f/1.7. Does it play nicely with the Oly? Kinda close in focal length to your 25mm f/1.4, to compliment that I suggest something a bit wider like the 17mm f/1.8, I think that you will find that to be much more useful in Rome, if you want a 2nd fairly fast, somewhat wider prime.
- For the rare occasions when you might need something longer, the Oly 40-150mm is much better IQ than you'd expect for the $120 or so you can usually get it for. It's not a 35mm-100mm f/2.8, but not a slouch and I think an excellent compromise in order to have a second body for such a trip.
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital 17mm F1.8 +19 more
OP redli0nswift Forum Member • Posts: 91
I guess I've never considered going wider.  Is there really that much difference from 12mm (12-40) vs the 7mm Pany or 9mm Oly?
Where besides the Pantheon would you have used a wider lens?
kaphinga
There is a noticeable difference between 9mm and 12mm.
Also, I sometimes shot panos with my iPhone to get a wider field of view.
* Barberini Palace
* San Carlo alle Quattro Fontane (actually, just about any church)
* Gallery Doria Pamphilj
I may have to look through my pictures and see what else I can come up with.
77phil77 Regular Member • Posts: 113
Hi
I would (and do) have a little panasonic GM1 as my second travel body to my EM-1. It takes up hardly any room and works so well with the olympus lenses (mine normally has the 17mm or 45mm 1.8 permanently attached to it, I have the Panasonic 25mm and that works well too)
I admit that it would need different batteries and a charger but these are luggage items less day to day items to carry.
This camera has now been superseded so you could likely get a SH one quite reasonably. If you would like to see what its capable of heres a link to a flckr page (you can see in the EXIF which lens was used for which picture. In good light the kits lens isn't so bad either
https://www.flickr.com/photos/phils--photos/sets/72157648145523154
Enjoy Rome
Regards Phil
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
SGA
SGA Regular Member • Posts: 295
Check this thread for a lens usage distribution on my recent trip to Italy and Spain.
http://www.mu-43.com/threads/76595/
I had a second body - actually two: RX100m3 and GX7 - to complement the E-M1.  The RX100 got a lot of use, and the GX7 never left the room.
 SGA's gear list:SGA's gear list
Olympus E-M1 III Olympus E-M5 III Panasonic Leica 100-400mm F4.0-6.3 ASPH Panasonic 12-35mm F2.8 Panasonic 35-100mm F2.8 II +7 more
bs1946
bs1946 Veteran Member • Posts: 7,779
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
For about six month's, my primes were parked on the shelf and my main kit was my E-M10, 12-40mm f/2.8 Pro, 35-100mm f/2.8, two 32GB SDHC cards, and three spare BLS-5 batteries.; all living in an ONA Bowery bag along with the battery charger and cable. If you like zooms, this is an excellent kit and you can leave the 25mm f1.4 home; you won't need it. I also found that the 12-40mm was on the E-M10 95% of the time but, each person works differently.
Bill S.
"Sharpness is a bourgeois concept" Henri Cartier-Bresson
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 12-60mm F3.5-5.6 OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 20mm F1.7 II Apple iPhone 12 Pro Max
Colin K. Work Veteran Member • Posts: 3,699
* Barberini Palace
I'd concur - wider the better. If you haven't traveled in Italy (or for that matter Europe) before you may be surprised how densely packed old cities are, with alleyways only a few feet wide etc. It can be very hard to step back to get a shot of a building without a UWA. And while there are some large cathedrals which will be fine for your 12-40, some of the most interesting stuff will be found in much smaller buildings.
Normally I would advocate a 2nd body, but since you have overlap with your existing lenses, I'm not sure there's a lot of point. My ideal combo would be 2 bodies, 12-40 on one and 7-14 on the other.
Tripod ... I wouldn't bother - some places prohibit them anyway - but I would bring a bean bag - there's always somewhere you can put the camera on the bean bag for long exposures.
A longer lens is useful for picking out architectural details, but much else.
The last time I was in Italy was with Canon FF. In FF terms, the 17-40 was by far the most useful lens, followed by 24-105 (mostly for street portraits) and my 70-200 hardly made an appearance.
Your fast Pany may be handy, but not as much as you might think - the old buildings can be very dark, and you'll need support even with the fastest lens.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
Isabel Cutler
Isabel Cutler Forum Pro • Posts: 19,189
Re: Two bodies....
Changing lenses is a royal pain and opens the cameras to dirt on the sensors.  Changing lenses is asking accidents to happen.
I went to England last year with two e-pl5 bodies, the 12-40 and 35-100 lenses.  Not tied down with a huge amount of weight and a good choice of equipment.
Almost had a mini-disaster in a car park one day when a keen-eyed person noticed I had dropped the door to the battery compartment of one of my bodies.  I couldn't thank him enough.
Isabel
 Isabel Cutler's gear list:Isabel Cutler's gear list
Sony RX10 IV Panasonic Lumix DMC-GX7 Canon EOS 7D Sony a7 III Olympus OM-D E-M10 II +2 more
Miron09 Senior Member • Posts: 1,068
I'd leave the Billingham at home
and use a less conspicuous bag. lots of thieves around
 Miron09's gear list:Miron09's gear list
Olympus PEN E-P1 Olympus PEN E-P3 Olympus PEN E-PL5 Panasonic Lumix DMC-GF3 Olympus PEN E-PL1 +18 more
lahsrah Contributing Member • Posts: 603
35-100mm for sure.   You want less lens changes but all you seem to have is primes except for the 12-40,  so 2 bodies will do only so much.
Cane Veteran Member • Posts: 6,900
You are primarily shooting architecture. You need wide, not long. These aren't bird photos.
Egregius V
Egregius V Contributing Member • Posts: 538
redli0nswift,
I agree with the recommendations that you consider a second body and an ultra-wide lens. That said, there's a question I don't think anyone's asked you yet. What do you like to photograph?
When I go to Rome (I'm going again in September, too!), I bring two cameras. My Oly. 9-18 plus a circular polarizer is a must-have, because I like to photograph churches and other very large structures like the Colosseum. I needed to go at least as wide as 9mm for both exterior and interior shots. Indoors, f/4-5.6 was doable hand-held with an E-PL5. I'll be using two OM-Ds on my next trip so I can keep the ISO lower.
I also find the 9mm focal length indispensable at the Vatican Museum, St. Peter's Square, various plazas, and even places like train stations and narrow streets. The 9-18mm range is great for street photography, too.
A 7-14 is nice, as long as you don't mind the limitations and drawbacks of this kind of lens. I'll have my little Rokinon 7.5mm fisheye with me for those few times when that much width is desired. (I do a lot of post-processing. Plus, fisheyes can be fun.)
Besides the 9-18, I love the 25mm f/1.4. Probably my most-used lens. I consider the 20mm pancake a more pocketable alternative. One of these, plus a 14mm and 45mm prime, will be in my bag. Your 12-40 is a great alternative to such a set of primes and should stay on one of your bodies, in my opinion.
I heartily recommend a telephoto zoom for capturing details in cityscapes and making portraits of more distant subjects. On my last trip, I used a pocket superzoom camera, the Panasonic DMC-ZS30. It served me very well for telephoto shots - mostly at St. Peter's, the Forum, in garden areas, and on some streets where you don't want to get too close to people. However, I'll be using the cheap, light, and excellent 40-150 f/4-5.6 next time, since I like to shoot RAW and will want the superior IQ. It'll only be used outdoors. On rainy days, I'll bring a weather-sealed 14-150 II instead.
The 35-100 is a great lens, but will you need f/2.8 vs. a much cheaper lens with a much greater range?
I hope this helps. Wishing you a great adventure!
P.S. - yes, the difference between 12mm and 7 or 9mm on micro four thirds is quite significant! It's all in the angle of view. You can get by with 12mm, but you'd probably wish you had a wider lens in some places.
 Egregius V's gear list:Egregius V's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +17 more
BigGG Contributing Member • Posts: 933
Current gear:
OMD E-M10
12-40mm 2.8 PRO Oly
25mm F1.4 Pany
Billingham Pro bag
Batteries (3)
Memory cards (3)
Make sure that you take the appropriate  chargers for the each of the camera Body.. Last year I found out the hard way, when overseas, about having the correct charger for the body.
GaryG
 BigGG's gear list:BigGG's gear list
Sony SLT-A77 Sony Alpha a99 Panasonic Lumix DMC-GX8 Sony a77 II Sigma 35mm F1.4 DG HSM Art +43 more
Pete Berry Veteran Member • Posts: 4,322
Re: Two bodies....
Isabel
I'm with Isabel here. Lens changes on-the-fly touring a city, etc are an accident waiting to happen. In my six years with m4/3's including a variety European and Asian destinations, two bodies, with a P-L 14-150 on the main and a 7-14 on the other, with a rarely used Panny 25/1.4 on the side, served me well, with very rare lens changes and minimal baggage.
The GH de jour (now GH4) on a cross-chest strap and the secondary/7-14 (way wider than 12mm!) with wrist strap in a beat-up old lens-down belt-holster from the Nikon film days. No swag bag per se that attracts attention. The 25mm, flash and minipod in a small day pack w/ rainjacket, water, etc, and hotel shower caps for camera rain protection, with chips and a battery or two in pack or cargo pants/shorts.
I shot a heck of a lot above 40mm in the tight little towns of France's Alsace as well a big cities like Prague and Zurich, so I think a "super-tele" such as the Oly m14-150 or the Panny 14-140 (or the sublime, but heavy 4/3 P-L 14-150 with adapter, which may be passe by now) would be a great walk-around choice for you. I rarely found the lens speed or shallow DOF limitations of my kit limiting - certainly not for the usual daylight architectural and street-scene shots, where f/6.3 seemed my sweet spot at all FL's.
Pete
