Improving the handling of the Panasonic 14-42 v1
Started Jun 18, 2015 | Questions
agentul Contributing Member • Posts: 619
I have been thinking of buying the legendary Panasonic 14-45mm for years now. I actually ordered it (used, for $180) from Amazon a few days ago, but I had serious second thoughts and decided to cancel the order today. I already have the 14-42mm that came with my GH2. I know the image quality is not as good, but after re-visiting some old threads, it seems like it's close enough to not warrant the upgrade. I also gave up on the 12-32mm, since it apparently exhibits shutter shock at 32mm under certain conditions, and my GH2 does not have an electronic shutter option. So I'd rather try to save the money for the 15mm f1.7 - maybe it will come down closer to $500 in October.
Now, one of the main reasons that I wanted the 14-45mm for was smooth zoom action. The 14-42 is very jerky, and it's a problem when shooting video (although motorized zoom would be ideal). I was wondering if there was a way to approach the smoothness of the 45-150mm by lubricating the outside of the zoom cylinder with a little WD40 to help it glide better. Is there any risk at all of the lubricant getting into the optical elements? I realize that it's not a weather sealed lens, but lubricants do adhere to the surface they are applied on, so I'm hoping that it wouldn't start spreading on the inside.
My idea is to spray some WD40 (I also have some gel grease around as an alternate, and that won't run at all under normal temperatures) on a napkin and rub it on the zoom barrel to form a thin film.
Has anyone else tried something similar? Is there a chance of screwing this up and destroying the lens?
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS
hindesite Veteran Member • Posts: 4,893
Re: Improving the handling of the Panasonic 14-42 v1
No way would I lubricate the lens with anything. And certainly not WD40 - and I don't think the barrel is the bearing surface anyway.
Besides, it isn't a very nice lens (compared to the rather lovely II version, which almost certainly is better than the 14-45 anyway) - and is probably cheaper new that that lens, too.
Why not fit a lever to the zoom ring. Might make things smoother.
I really prefer legacy lenses for video, but hard to get that range in legacy glass (all my video is longer FLs).
alcelc
alcelc Forum Pro • Posts: 19,004
I won't do it, but a good excuse to replace in case going wrong.
OP agentul Contributing Member • Posts: 619
a lever would not help much with the jerky movement of this lens. i have thought about buying one, but it would probably work best when the camera is on a tripod.
messing up the lens would be a good reason to replace it, but i'm trying to avoid doing that (otherwise i would have just done the operation by now). besides, i could have just bought the 14-45mm by now, right? i read enough about the 14-42 v2 to know that i don't want it over the 14-45.
Vesku Senior Member • Posts: 2,964
All my Panasonic zooms has "jerky" zoom action. Panasonic should think more about mechanical quality. Now Panasonic lenses has cheap and plasticky feel.
My friends Sony, Canon, Samsung and Nikon zooms works mostly very smoothly.
i found this thread:
http://www.dpreview.com/forums/thread/3376779
specifically, this video: https://www.youtube.com/watch?v=0tYLKFUWP68
i'm not doing that. i mean, i'm not taking the lens apart.
my 45-150 is very smooth, and has a solid, metal feel to it. i'm still impressed by how nice it is.
what about zoom creep? i heard that can be an issue on some lenses. i understand that you can't have it both, but compromises are certainly possible.
jeffharris
jeffharris Forum Pro • Posts: 11,409
After you "repair" the old lens, just get a 14-42mm II. You'll need it.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
LMNCT Veteran Member • Posts: 4,908
You seem to have a lot of problems with Panasonic products...never quite good enough and "plasticky".  I have never had a problem with a sticky lens barrel or parts falling off...or being repulsed by the "plasticky" feeling.  Part of the M4/3 production ethic is to keep equipment as light as possible. That is difficult to do if you build your lens barrels out of metal.  Probably Leitz/Leica would be closer to your ideal of quality.  However, I tend to grade lenses according to what comes out of them and I also tend to take very good care of my equipment.  If you handle a lens with sticky fingers, it will tend to pick up that property.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
nope, already debated this years ago in another thread. i'd rather have the 14-45mm if i were to get a replacement. of course, if there's a miraculous sale on the 12-35 f2.8, i could be persuaded to reconsider.
i've decided to just leave it alone and not mess around with it. i have a history of "repairing" things.
dontfret
dontfret Senior Member • Posts: 2,341
Have you tried the power zoom 14-42?  I replaced the kit 1442 on my G5 with the PZ, and love not only the smooth zoom but the compact size, especially when closed.  On the G5 the front slide lever controls zoom so super easy shooting and video zoom.  Even better is the internal zoom on the PZ45-175.
Rich
Take many pictures - a few are keepers, the rest are are lessons.
 dontfret's gear list:dontfret's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
isn't that plagued by shutter shock, though? i saw some bad reviews on the internet. the idea is very good, though, but i don't film so much as to justify a dedicated video lens. i would rather spend the money on something that works very well for stills.
too long a FL for my usual video needs, and i already have the 45-150 anyway.
A cheap solution, works very well
My 100-300mm is very sticky zooming but works quite smoothly with a rubber band. It balances the gravity and friction of the moving barrel and it moves steady and smooth during video, especially backwards, almost itself.
Re: A cheap solution, works very well
I can see part of your problem.  The lens (and lens cap) appear to be quite dirty.  Dirt can raise all sorts of problems.
What problems? My lenses has always clean optical surfaces. I dont think that fingerprints in lens barrel causes any issues. Do you use gloves with your camera?
That lens was sticky at day one out of the box. And the second one was sticky too after replaced by warranty after one year of use.
jeffharris
Aside from shutter shock issues on SOME M4/3 cameras, like my GX1, the PZ has lower image quality than the 14-42mm II kit lens. It's also only compact when the camera is OFF. Once you turn on the camera, it extends to the same size as the standard 14-42mm lens. For what it is, the PZ 14-42mm is overpriced.
I had one for several weeks and wasn't pleased with it, so returned it and got a 14-42mm II.
alcelc
No, even its really there, it would be either a matter of the intention of those posters, technique of user or worst scenario, sample variation. At least my 14-42 PZ worked fine on GX1 (the most suspected combo), G1, GF3 and GX7. Being an average skillful user should be OK. Post any sample to demonstrate SS is meaninlgless, able to prove no SS is valuable.
Look at Oly's equivalent power zoom pancake, there were also similar complains occasionally but at the same time a lot of happy users.
However, in terms of IQ, unlike 14-45, I don't think you would see any different from 14-42 M1 except for the build quality, size and that poor zoom ring. It is a reason for me never take it out from box since selling it would give me <US$40 ....
rambling robin
rambling robin Senior Member • Posts: 1,196
Panasonic are not the only ones to suffer. Late last year I bought a new Nikon 18-55 VR Mk2 for my Nikon D40.
This is a collapsible lens which saves a bit of space but not much else. The zoom action was appalling - stiff, jerky, useless. It was replaced with a normal 18-55VR - now all gone following complete move to m43.
Debating now to replace 14-42Mk1 with either 14-45 or 14-42Mk2, so if anyone has any real life experience of this conundrum I'd be grateful. The 14-42 Mk2 seems to offer a minimum focus distance of 20cm at 14 to 20mm which I would find very useful.
 rambling robin's gear list:rambling robin's gear list
Nikon Coolpix P7100 Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon D100
papillon_65
papillon_65 Forum Pro • Posts: 27,030
Quite easy - silicone grease.
I had a troublesome 50-200mm and I read elsewhere that a little bit of silicon grease on the barrel would sort it, and it did. There will undoubtedly be some people on here wetting themselves in horror at the thought but I've done it and it olved the problem and never caused any other issues. I've kept the tube and would have no problem doing it again on any other lens that was a bit tight and sticky.
"In a time of universal deceit telling the truth is a revolutionary act".
George Orwell.
http://bit.ly/1BIquIF
 papillon_65's gear list:papillon_65's gear list
Fujifilm FinePix X100 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sony Cyber-shot DSC-HX50V +7 more
Fredrik Glckner Veteran Member • Posts: 3,894
If you can source the newest 14-42mm lens, then I think that is the best choice. It has a very good image quality, and is very compact. The zoom action is quite good, but far from pro level, of course.
I have made a comparison between the kit zoom lenses here:
http://m43photo.blogspot.no/2015/06/lumix-kit-zoom-lenses-compared.html
Based on this (and previous comparisons), I would say:
Best compact lens: Lumix G 12-32mm
Best basic kit zoom lens: Lumix 14-42mm II
Avoid the Lumix PZ 14-42mm, as it does not perform very well.
The 14-140mm v2 is very good.
