Sigma DP1 Quattro: Is the lens up to the task?
Started Jun 15, 2015 | Discussions
Hardy Steiner Senior Member • Posts: 2,442
Sigma UK published some sample pictures taken with the Sigma DP1 Quattro on Twitter. Direct link here going directly to photographer's website.
While these samples seem to be a lot cleaner than what we had previously seen, I still can't help but think that the borders are fairly soft (even at f8 and f11). This wasn't that apparent to me with previous DP1s. After hearing that Sigma actually changed/"improved" the lens design for the DP1 Quattro, I was expecting to see better. I am not saying that I expect DP2Q quality, but I think the 18-35mm A zoom would take sharper pictures. What's your opinion on this?
Best regards,
Hardy
Join the Sigma DP Macro Group on:
http://www.flickr.com/groups/sigma_dp_macro/
My pictures on:
On Flickr: http://www.flickr.com/photos/diddy
Sigma 18-35mm F1.8 DC HSM Art Sigma DP1s Sigma dp2 Quattro
nick_webster
nick_webster Veteran Member • Posts: 7,623
I asked this before
see here - http://www.dpreview.com/forums/post/55300149
Consensus seems to be there is little or no difference between the 1M and the 1Q - both are a bit weak in the corners and edges and also have some CAs on high contrast edges - though the latter is dealt with nicely in SPP
There are some links to images buried in there somewhere,
hope that helps,
Nick
Scottelly
Scottelly Forum Pro • Posts: 18,028
Re: Sigma DP1 Quattro: Is the lens up to the task?
I agree that the 18-35mm Art lens would make better images than the 19mm lens on the DP1 Quattro, and if you think that's sad, I agree.
I think Sigma should have improved that lens more than they did. Frankly I can barely tell a difference between the DP1 Merrill and DP1 Quattro lenses from the photos I've studied.
It looks like the DP0 Quattro is going to produce better image quality than the DP1 Quattro. If that is indeed the case, at least they will have done that.
At some point I might end up with the DP0 Quattro, a Quattro DSLR with the 18-35mm f1.8 A, and the DP3 Quattro. To that I could add the 70mm f2.8 macro, the 105mm f2.8 macro, and a 120-300mm f2.8 OS S.
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
OP Hardy Steiner Senior Member • Posts: 2,442
Yes, true, especially as you can't change lens I was considering the DP1Q for a bit as a lightweight alternative to the SD1 18-35 combo, but the image quality doesn't quite convince me. The Dp0q is a bit too wide for my taste.
Best regards,
Hardy
My pictures on:
Re: I asked this before
Thanks! Yeah, Rick was mentioning he had to sharpen the DP1Q pic to match the DP1M pic.
Best regards,
Hardy
My pictures on:
mrouleau Regular Member • Posts: 335
I find (in 35mm equivalent) 21/45/90 to be a much more attractive range than 28/45/75.
marcodadofoto
marcodadofoto Senior Member • Posts: 2,982
Exactly. It also means that sigma is lately doing a lot of thrash announcements - publicity. Try before believing. Sad but true.
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
The DP1s was sharp across the frame, but with the DP1M and DP1Q, there can be some edge softening.  It's a pretty large resolution jump between those models.
I think it's improved, in the sense that you see about the same results as the DP1M - but the DP1Q has more resolution.  It probably is a better lens, it just keeps up with the sensor instead of surpassing it.  The DP1Q also has somewhat better CA handling (though there can still be CA at times).
I still think that the DP1M/Q lenses are better than most wide angle lenses for other cameras.
I think it would be a bit better but don't forget it's quite a lot larger.  The lens itself weighs probably 2x what a DP1Q does!  I have the 18-35 but most of my wide photos are with the DP0Q because it's so much easier to carry, both in terms of bulk and weight.
I think the DP0Q will be better in terms of image quality because they are not constraining themselves to the smaller size of the DP1Q lens form-factor.  Im guessing that was the tradeoff for the DP1Q - they wanted a camera about the same size as the DP2Q, and the DP1Q does produce really good results - just not perfect.  I don't think the DP0Q will be perfect either, but I'm hoping it's noticeably improved over the DP1Q.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Scottelly wrote:
At some point I might end up with . . .  a Quattro DSLR  . . .
I like the way that just crept in there, Scott
Fifty bucks says you will not
Pedantry is not a felony.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
I would be happy to have a DP1Q with a slightly bigger lens (to improve image quality) - the thing with the DPs is that obviously you can't change the lens, so the lens should fully live up to the resolution of the sensor. I am looking forward to seeing some of your DP0Q pictures!
Best regards,
Hardy
My pictures on:
