Best very compact normal zoom for Oly OMD E5 when 12-40 is too big
Started Jun 15, 2015 | Discussions
tombell1 Veteran Member • Posts: 3,138
Morning everyone. I have the 12-40 which is clearly excellent however when walking sometimes i would rather go VERY SMALL.
S accepting that there is compromise if you HAD to choose to take the Panasonic 14-42 vario PZ and the tiny Olympus 14-42 EZ . The former seems to have the better optics but there may be problems with CA and vignetting wheras the latter may have some advantages.
i appreciate the 14-42 11 and 14-45 are better but it is SMALL i am looking for here as when top notch is demanded i would go back to the 12-40
thanks
Tom
Tom Bell
Dartmoor
Devon
http://flickr.com/photos/tombell1
 tombell1's gear list:tombell1's gear list
Fujifilm FinePix X100 Fujifilm X100F Olympus OM-D E-M5 Fujifilm X-E1 Fujifilm X-T1 +16 more
Panasonic Lumix G 14mm F2.5 II ASPH
berni29 Veteran Member • Posts: 3,119
Re: Best very compact normal zoom for Oly OMD E5 when 12-40 is too big
Hi
I would say the 12-32 would be the lens for you. I like mine very much, and it is the wide end that you will miss if you get a lens that starts at 14mm. You can always crop if you have to.
Berni29
EM-10, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm f1.7, Voight 17.5mm f0.95, Oly 45mm, 50mm F2 macro, (prev EM5, GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
papillon_65
papillon_65 Forum Pro • Posts: 27,030
Panasonic 12-32mm...
It doesn't get any smaller or better, it's no-brainer if you want a small but excellent lens.
"In a time of universal deceit telling the truth is a revolutionary act".
George Orwell.
http://bit.ly/1BIquIF
 papillon_65's gear list:papillon_65's gear list
Fujifilm FinePix X100 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sony Cyber-shot DSC-HX50V +7 more
Loga Senior Member • Posts: 1,981
You could also try a prime or two for walking. The pana 14 f2.5 and 20 f1.7 is very small and performs very well. You choose the focal length. If you are not on a budget, you can buy both, and easily keep one in your pocket while the other is on the cam.
L.
thanks
Tom
Tom Bell
Dartmoor
Devon
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +6 more
Jon Schick Veteran Member • Posts: 5,163
Hi Tom - another vote for the 12-32 (similar size to 20mm pancake). Moved from the LUMIX body recently? Jon
http://thephotographersblock.wordpress.com
http://jonschick.smugmug.com/
 Jon Schick's gear list:Jon Schick's gear list
Olympus E-M5 III Panasonic Lumix DC-S5 OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +13 more
RichRMA Veteran Member • Posts: 4,073
Original Panasonic 14-45mm. I still have one.  It's roughly 1/2 the size of the 12-40, by volume.
clack
clack Regular Member • Posts: 284
12-32 +1
Every thing has already been photographed - but not yet by everyone. (Karl Valentin)
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
I am very happy with the IQ of the Pana 14-42X.
There seems to be consensus that the 12-32 is actually the best and most compact, but whether it is the best I don't know. The most compact, certainly.
I got the Pana 14-42X before the Oly 14-42EZ and Pana 12-32 existed. The image quality is actually very good. I do not hesitate to take pictures with it when I left the 12-40 at home. I use it with the FreeMod X-Cap which essentially turns my E-M5 + 14-42X into a point and shoot with automatic lens cap.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Karld70 Veteran Member • Posts: 3,553
+1 for the Pan 12-32
Not much not to like about the lens.  I got it as a kit lens with my camera, but love it!
RealPancho
RealPancho Senior Member • Posts: 1,315
Problem with the 12-32?
Isn't the 12-32's O.I.S. 1) incompatible with the Olympus I.B.I.S. and 2) un-switchable, and thus, always on? Am I missing something? Because this seems like a deal breaker for me.
Frank
 RealPancho's gear list:RealPancho's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +6 more
OP tombell1 Veteran Member • Posts: 3,138
No i have the Panasonic 20 and Sigma 30 .... It is the option of a zoom i wish to look at but thanks
Tom Bell
Dartmoor
Devon
We must stop meeting like this Jon!
We must stop meeting like this Jon, i do still have the Panasonic G6 and it is a fantastic camera but not aesthetically and i bought a OMDEM5 second hand ... Love the camera ....and at last have bought a high quality zoom ... But still want something for long walks. Trust all well best wishes Tom
Re: Best very compact normal zoom for Oly OMD E5 when 12-40 is too big--
Tom Bell
Dartmoor
Devon
Skeeterbytes Forum Pro • Posts: 23,186
Re: Problem with the 12-32?
All OIS Lumix lenses can be switched between OIS and IBIS on the Oly bodies. The default setting is to not access OIS, but that setting can be changed in the camera menu to use OIS instead. This is specific to the OIS lenses without physical switches.
With lenses having an IS switch, IIRC it's possible to run both systems simultaneously and that's a no-no and will blur the photos.
Lifted from the E-M1 manual:
When using a lens with an image stabilization function switch, priority is given to the lens
side setting.
• When priority is being given to the lens side image stabilization and the camera side is set
to [S-IS-AUTO], [S-IS1] is used instead of [S-IS-AUTO].
My only Lumix lens doesn't have IS, so I have no hands-on.
Rick
Joakim Edsjö Regular Member • Posts: 192
Re: +1 for the Pan 12-32
I have both the Oly 12-40/2.8 and Pana 12-32 that I use on my E-M5 II. The Oly 12-40 is of course a better lens, but the Pans 12-32 is not far behind regarding image quality. Actually, I got the 12-32 with my GM1 but never really liked it (ergonomically) on the GM1 where I use mostly small primes, but on the E-M5 II it is really nice if you want a small standard zoom kit.
As mentioned later, you can decide in the Oly menu to use IBIS instead of OIS.
Joakim
RealPancho
side setting.
Rick
Thanks, Rick. Now that you mention it, I seem to recall seeing that in the menu system(s), but I guess I have disregarded it since all my Lumix lenses are hard switchable.
Frank
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: Panasonic 12-32mm... +1 -- and I do this, not just talk! :)
papillon_65 wrote:
It doesn't get any smaller or better, it's a no-brainer if you want a small but excellent lens.
I have the Panny f2.8 12-35 for my G6 and GX7 but my walk around lens is the diminutive 12-32.
The 12-32 has a huge advantage over the smaller 14-42 lenses -- it goes down to 12!!!
AND at 12 it is only half a stop disadvantaged in aperture compared with the 12-35 (or 12-40 in your case, Tom).
AND it produces excellent quality images.
AND you can get a JJC auto lens cap for instant opening and protection.
It does have barrel distortion at 12, but it is regular and can be removed in a second when necessary (most of the time it doesn't matter) with PTLens (PS compatible) plug-in in PP (I use it with PhotoLine) or manually.
The 32 at the long end is a touch short but given the IQ of the lens and the 16MPX sensor, you can crop to get that extra reach. With the Panny bodies, I use EX TELE which takes an 8MPX crop out of the center of the sensor, effectively a 1.4x tele extender for 45mm equiv. The 8MPX is good for top quality viewing on any screen and an A3 (tabloid) size print (or larger depending on viewing distance, of course).
Out for a ramble in the bush or suburbs, I have the 12-32 on the camera and the Panny 45-150 plus the Raynox 150 c/u supplementary lens in my pocket. The Oly 40-150 f4-5.6 is the Oly alternative, an excellent lens, although the Panny is just slightly smaller and lighter.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
