Hen3ry
It isn't Irish football and never was, Tom
Paul Amyes wrote:
R V C wrote:
Tom Caldwell wrote:
Skeeterbytes wrote:
Fun, and well done! I understand there are rules, but the couple of times I've run across it on the tube I couldn't begin to guess what they might be. Calvinball for grownups.
Rick
Basically Irish Football played with a rugby ball on a cricket oval ground where both teams start out on both sides of the centre line and there is no crossbar so you can kick the ball anywhere between two posts and you also get a consolation point for a miss through the next outer posts. The only football that I know where it is legal to obstruct an opponent from approaching another team member who is carrying the ball - but maybe American Rules? You can carry the ball for so many steps but then have to bounce it and to pass it you have to hit it off one hand with the fist of the other. Or kick it high (mostly) so another team member (hopefully) can make a spectacular catch in which case they get a free kick.
There are four quarters not two halves.
Scores, like basketball, are in lottery numbers.
Comprendez?
Sounds like Calvinball /
Also known as "Aerial Ping Pong" in the rugby states
It grew out of rugby but improved on it enormously.
it is the only football (or any game really) where you have the players spread throughout the field contesting against another individual -- although that hs become less marked in recent times with the flooding that can see almost all members of both teams concentrated at one end of the ground.
The ground is bit -- 150 meters or more long -- and oval.
It is the only true football in that the only way to make the maximum score is for a member of the attacking side to kick the ball -- you must kick the ball (hit it with a foot or leg below the knee) -- cleanly between the goal posts, whether it goes through in the air or bounces. Touching the posts or a miss either side, but which passes between the "behind" post and the goal post is a behind, one point, a sixth of a goal. If the opposition kicks it through the goals (or the behinds) the scoring team receives one point. If either attackers or defenders touch the ball through, then the score gained is one point.
Australian football developed in Melbourne with early matches being played where the MCG (the Melbourne Cricket Ground -- the home of Australian football!) and Richmond Football Ground are located.
It was the first football anywhere in the world with fully formalized and codified rules.
Damon Runyon, the great American sports fan and writer, thought Australian football was the most democratic of games (being based on the notion of individual players pitted against each other throughout the field rather than two Feudal armies going to war from a base of their own territory), the most spectacular, of course (a quick look here at some goal kicking -- the white arc is 50 meters out from goal so you see people kicking 60 and 70 meter goals), and regarded American football as slow, cumbersome, and unnecessarily complicated in comparison.
The power base of Australian football is across southern Australia -- Victoria, South Australia, Western Australia, Tasmania, with the Northern Territory added in an some penetration, mostly recent, into New South Wales and Queensland.
