HDMI out on T6s record indicator stays on and low battery icon appears as well.
Started Jun 12, 2015 | Discussions
Motoriley New Member • Posts: 1
Recently was shooting some video on the new Canon T6s and recording the HDMI out to an Atomos Shogun. Camera was set to 29.97. One warning to others is that you will not get an HDMI out if Wifi is on even though the Wifi controls are disabled in video mode. Odd but true. The real irritant is that it seems like the red record dot is burned into the HDMI out so it will also be recorded if you want tor record in camera at the same time as you record to the Shogun. The low battery icon will also appear on the output even if you aren't recording in the camera. Anyone have similar experiences or found any solutions?
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
dottore New Member • Posts: 1
Re: HDMI out on T6s record indicator stays on and low battery icon appears as well.
Haven't figured out how to get rid of the red dot myself (wasn't "clean" hdmi output one of the selling points of the T6?), just wanted to say thanks for the Wifi info - that was driving me crazy.
Exit10 Senior Member • Posts: 2,264
The WiFi thing is the same if you connect to a computer using USB - until you disable WiFi the computer doesn't recognize the camera.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
MyceliumMedia New Member • Posts: 1
Seems that the HDMI out is interlaced also. Doesn't matter what setting it's either. I'm going through black magic mini recorder.
Anyone found a work around?
