Panasonic 14-42mm f3.5-5.6 II problem. Help Please
Started Jun 11, 2015 | Questions
Colourise Junior Member • Posts: 37
Hi
I should be grateful for some advice, please.
I am using a Panasonic 14-42mm f3.5-5.6 II on an Olympus EM-10 and find that when the lens is zoomed hard (there is no further available movement of the zoom ring) to the 42mm position, the display in the viewfinder sometimes shows 40mm and the EXIF data also shows 40mm.
On other occasions the display and EXIF data correctly show the 42mm setting.
Has anyone else experienced this type of behaviour before and does this suggest that it is an incompatibility issue or could the lens be faulty?
The lens is new
grcolts Veteran Member • Posts: 3,914
Re: Panasonic 14-42mm f3.5-5.6 II problem. Help Please
Colourise wrote:
Hi
The lens is new
Since I don't have the EM-10, I cannot give you an answer but I do have the Panasonic 14-42mm f3.5-5.6 II and use it on my Olympus EPL-7 without any issues. The EPL-7 from my understanding is very similar to the EM-10. Maybe someone else will chime in who has used that lens on the EM-10.
GR
OP Colourise Junior Member • Posts: 37
grcolts wrote:
Colourise wrote:
Hi
The lens is new
GR
Thanks for the reply.
That's very useful information
timo Veteran Member • Posts: 5,927
Hi
The lens is new
Is this really a serious matter? It sounds as if the electronic sensing in the lens may not have been correctly callibrated, but I can't see why this is of any great consequence, provided the lens works well optically at full zoom.
Tim
http://timauger.smugmug.com (click browse)
http://timauger.blogspot.sg/
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Sigurthr
Sigurthr Regular Member • Posts: 239
With OIS it won't be an issue, but IBIS needs focal length data for calibrating IBIS before every shot.
 Sigurthr's gear list:Sigurthr's gear list
Olympus PEN E-PM1 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +2 more
I doubt if a 2mm discrepancy is going to make any practical difference.
Tim
Sigurthr
Tim
That would be a good thing for the OP to experiment with test shots and find out. Just manually set the FL info and use a stationary subject with fixed lighting. Though, it's hard to get any consistency with camera shake.
Tim
This is all very useful information, thanks for taking the time to respond
trog100 Senior Member • Posts: 2,149
i dont think its of any real significance.. everything will still work okay..
its just a tiny read out variation..
trog
Narcosynthesis Senior Member • Posts: 1,832
Colourise wrote:
Hi
The lens is new
What does the camera read the focal length at at the widest setting? Is it also out of calibration there (try zooming in by 2mm and see if it changes where it should). I would hazard a guess that either the system that reports the zoom position is either mis-calibrated or the sensor is not working perfectly when it is at the long limit.
Ultimately, I doubt a 2mm discrepancy will make any practical difference to the IS system or anything. so I probably wouldn't worry about it myself.
www.flickr.com/photos/narcosynthesis
www.illaname.deviantart.com
Narcosynthesis wrote:
Colourise wrote:
Hi
The lens is new
The camera does read 14mm at the wide end, and when zooming in does change by a couple to mm to read 16mm.
Interestingly I managed to try the EM-10 with a Panasonic 14-45mm f3.5-5.6 and the camera read the focal length correcttly at both ends of the zoom range.
I take your point about the IS system.
Thanks for your input
