Prime lens recommendations?
Started Jun 9, 2015 | Discussions
LarsRost Contributing Member • Posts: 663
Hello,
A G7 will be mine in a couple of weeks and I'm looking for advice choosing prime lenses.
I am thinking about 2-3 primes in the 14-50mm range. I have read reviews but would like your real life experience. I shoot landscapes, street photography and everyday snaps/portraits of kids and family.
What about these lenses?
Panasonic 14mm F2.5?
Panasonic 42.5mm F1.7, Oly 45mm F1.8, Sigma 30mm F2.8 ?
Everyday lens in the 17-25 range... Leica 25mm F1.4 or, Panasonic 20mm F1.7 perhaps?
Kind regards
.lars
 LarsRost's gear list:LarsRost's gear list
Fujifilm X-H2S Fujifilm XF 56mm F1.2 R Sigma 50-100mm F1.8 DC HSM Art Fujifilm XF 18mm F1.4 R LM WR XF 150-600mm
Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7
Paulmorgan Veteran Member • Posts: 9,499
Re: Prime lens recommendations?
LarsRost wrote:
Hello,
Kind regards
.lars
Firstly, what is your working budget ?
Bottom end.
Panasonic 14mm, Sigma 19mm, Olympus 45mm
Middle end.
Panasonic 14mm, Olympus 17mm, Olympus 45mm
Top end.
Olympus 12mm, Olympus 17mm, Olympus 45mm
Get the idea.
jeffharris
jeffharris Forum Pro • Posts: 11,409
LarsRost wrote:
Hello,
Tough question.
I've got lenses all throughout that range. After carrying various combinations over time, m favorites to carry are 17.5mm, 42.5mm and 75mm (all Voigtländers). A 25mm is a no-brainer, too.
So… 17mm f1.8, 42.5mm f1.7 to start. Add a 25mm f1.4 later on.
What about a Sigma 60mm f2.8? People who have them rave about them.
Another suggestion. Why not shoot with the kit zoom for a while and look at which focal lengths you shoot most… THEN decide. It's very easy to start wanting every lens in creation… see my gear list … and end up buying all sorts of things you may not REALLY want.
So, relax, take your time.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
OP LarsRost Contributing Member • Posts: 663
Bottom end.
Middle end.
Top end.
Get the idea.
Thanks, I guess "Middle end" will fit my budget the most. Any particular reason you chose Oly 45mm instead of Pana 42.5mm? I considered the 42.5mm OIS as G7 does not have IBIS.
Kind regards
.lars
LB1940
LB1940 Regular Member • Posts: 155
If you are interested in portability - and this is one of the strong points of micro4/3 - then the Pana 14 and 20 mm are musts. I have the Oly 45 mm and can assure you that this is an outstanding lens. If, however you are using a G7 without on camera image stabilization, then you should opt for the Pana 42.5 mm.
Luiz
LB1940
 LB1940's gear list:LB1940's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +1 more
brentbrent Veteran Member • Posts: 5,766
Many people here really like the 14mm lens, but I never warmed to it, though it does have the advantage of being incredibly tiny. I replaced it with the 15mm and like that lens a lot better, though it is more expensive. The Oly 17.5 f/1.8 is another option for a "street" lens.
For portraits, you might consider the 42.5, 45, or the Sigma 60 (excellent and inexpensive, but a bit slower at f/2.8).
Your choices as to the above might influence which lens, if any, you want to get in the middle. The Oly 25 is another option.
I have a G7 on pre-order. I see that B&H now lists expected availability as July 2 (I think it was once June 15, and it still is on Amazon).
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
pocketpygmy Contributing Member • Posts: 829
Hello,
Kind regards
.lars
Classic trio keeps the spread of focal lengths fairly wide:
1. 14mm f2.5: standard 28mm-equiv. wide angle, perfectly serviceable lens, but most of all super compact and no fuss
2. 25mm f1.4: all-purpose 50mm-equiv. 'normal', super bright Leica glass, produces very high quality images
3. 42.5 f1.7: the short tele, good for portraits and blowing out the background
Stick with Panasonic lenses. Not that all of them have lens-based stabilization (only the 42.5), but they do tend to play nicer on Panasonic bodies (automatic corrections for distortion, chromatic aberration, etc. - I'm not one to ask about for specifics, but I'm sure others can chime in).
jeffharris wrote:
Tough question.
Thanks. I have been using Pentax for many years.  I measured my most used focal lengths 5 years back in time:
24-28mm (APS-C) = 60%.
55mm (APS-C) = 20%
15-21mm (APS-C) = 20%
So 17mm seems like a good start.
Kind regards
.lars
JeanPierre Martel Veteran Member • Posts: 3,304
A) For landscape, I would choose the widest automatic-focus prime: the M.Zuiko 12mm.
B) These days, about any focal length can be used for street photography. I'm using the M.Zuiko 12mm. If that's too wide for you, than the M.Zuiko 17,5mm is more conventional.
If you disagree and don't want the 17,5mm, then the Lumix 25mm F/1,4 could be your family portrait lens (and the second lens in your collection)
C) As a third prime, you could get a bright 42,5mm or 45mm lens. The best one is of course the PanLeica 42,5mm F/1,2. But if you want something more affordable, the M.Zuiko 45mm F/1,8 and the Lumix 42,5mm F/1,7 are as good. Get the cheapest one.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
lahsrah Contributing Member • Posts: 603
The Olympus 17mm F1.8 isn't that much bigger than the 20mm F1.7 especially considering the G7 body.  I wouldn't get the 20mm F1.7 anymore its rather dated, yes its optically superb, probably sharpest M 4/3 lens under $500 and maybe in the top 3 of all time M 4/3 but the focus speed really brings it down, especially for night use.
Will the AF be just as fast on the G7? What about lens auto-correction? As I shoot RAW+JPEG lens auto-correction is not a deal-breaker but it's nice when you're in a hurry.
.lars
LarsRost wrote:
Bottom end.
Middle end.
Top end.
Get the idea.
Kind regards
.lars
No reason, whatever fits your needs the most.
I have shot with the Olympus 17mm on Panasonic bodies, there isn't much CA etc that needs correcting with this lens, my OOC shots looked just fine. The focusing is lightening quick. I have shot with the 12-40mm PRO zoom and a few other lenses and the 17mm is the fastest equal if not the fastest lens.
I suggest you watch some David Thorpe reviews if you haven't already https://www.youtube.com/playlist?list=PL754C3AAF38017475
He has reviewed many MFT lenses and bodies, including the 17mm F1.8 and 20mm F1.7 (+ mark II).
bs1946
bs1946 Veteran Member • Posts: 7,780
LarsRost wrote:
Bottom end.
Middle end.
Top end.
Get the idea.
Kind regards
.lars
All of these lenses are quite small, so the lack of OIS is not going to be a killer. I have an E-M10 with Paul's top end set plus the Rokinon 7.5mm f/3.5 FE and the 12-40mm f/2.8 Pro. I don't use the 12-40mm all that much, preferring to use primes. I had the Sigma 30mm f/2.8 DN until I gave it to my son. It is a great lens but the 45mm is much better and if you have one, you don't need the other.
I'm not really a landscape shooter but I went out for the day with a friend who is. Here's a couple I did with the 12mm, 45mm, and my recently acquired 7.5mm FE on my EPL-7. I never had anything wider than 28mm (14mm in M43) until I bought the 12mm f/2.0 with my E-M10. It has replaced the 35mm (17mm) as my most favorite focal-length.
Looking down on the Connecticut River and Pioneer Valley from Skinner Mountain, MA. It was morning and the valley was still quite foggy
This was done with the 7.5mm Fisheye on my EPL-5 later in the morning
Another fisheye shot looking South.
I don't use my 45mm all that often but, this was one of those times where it was the right choice.
Looking North from the bridge over the Connecticut River.
Bill S.
"Sharpness is a bourgeois concept" Henri Cartier-Bresson
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Steve_
Steve_ Senior Member • Posts: 2,876
the devil's advocate
I've got a lot of m43 lenses, having first gone the prime route and later buying good zooms.
I really like the 14mm Panansonic. New examples can be had on ebay from Japan for less than $200, when they were more plentiful they were $169.
I had the 20mm Panasonic, and it is great optically. But the focus is pokey, especially on Olympus bodies. I also can't say I ever truly warmed to the oddball focal length.
I now have the 25/1.4 Panasonic, a truly great lens. But a bit on the bulky side and somewhat pricey. I may replace it with a 25/1.8 Oly to improve the chances of it being around when needed.
I have and love the Oly 45, but in your case I'd get the Panasonic 45/1.7 for the stabilization. Both great lenses.
But these days they rarely get used, and my 12-35/2.8 and 35-100/2.8 Panasonics certainly do. Consider that you could buy a 12-35 for less than the cost of the 14/25/42.5 combo. New gray market 12-35's are on ebay for ~$660, a terrific value.
I paid (gulp) $1099 retail for mine long ago, and the warranty isn't worth much as they don't break unless you break 'em. For that reason I've gone to buying all m43 lenses new via ebay from Japanese or Korean sellers. The savings are huge and the lenses reliable.
If you really want primes they are excellent on m43, but I'd actually recommend the 12-35 rather than spending more on 3 primes. It has no problem replacing all three in my use, and offers great stabilization.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G 14mm F2.5 ASPH +13 more
addlightness Veteran Member • Posts: 3,641
LarsRost wrote:
Hello,
Kind regards
.lars
Pancake: Pany 14mm f2.5 and Oly 17mm f2.8(not the 1.8)
Normal: Oly 25mm f1.8
Med tele: Oly 45mm f1.8
The 25mm and 45mm are usually for low-light or if I really need speed.  Otherwise 14mm or 17mm for (outdoors) family and street photography.
I find the 14mm and 17mm perfectly acceptable.  They are not as sharp as the 25mm which is the sharpest and fastest(as mentioned by many here) among my collection but sometimes sharpness is not everything
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
kwunyin Regular Member • Posts: 152
LarsRost wrote:
Bottom end.
Middle end.
Top end.
Get the idea.
Kind regards
.lars
from experience, I can tell you that you don't really need 14 and 17. You can work with either or. Having both feels a bit redundant to me as they both have a similar strength, environmental portraiture/street/documentary photography. The 14 is more portable, but the 17 isn't exactly bulky. The 17 has the manual focus clutch which is awesome. Personally, I'd go with:
Samyang 7.5: Different perspective, sharp and ultra wide
Olympus 17: Street/document photography
Olympus 45: Staple portrait lens
But this is my preference. You may like rectilinear wide angle lenses more. Either way, they have distortion, so as they say: go big or go home.
kernel panic Regular Member • Posts: 146
Hello,
Kind regards
.lars
Just to clarify: all Panasonic and Olympus lenses are distortion corrected on all Panasonic and Olympus bodies. This is part of the m43 standard.
www.mirrorlessdb.com
Thanks for all your advices.
Choices choices. ...
.lars
jeffharris
The 20mm's focus speed isn't a big issue when using Panasonic bodies. It's no speed demon, but it's fine. The G7 has similar low light performance specs as the GX7 and even in Silent Mode with the autofocus assist light disabled, AF works surprisingly well. It's not something worth worrying about. It's a great lens.
