Fast prime help
Started Jun 9, 2015 | Discussions
rponiarski
rponiarski Regular Member • Posts: 449
Fast prime help
I have the trio of Sigma primes (19mm, 30mm & 60mm), which I use quite often, but have been thinking of getting a faster prime lens for my E-P5 (they are fine for my E-P2 as that is used only in daylight). I have been thinking about the Olympus 25mm f1.8 or 17mm f1.8, or the Panasonic Leica 25mm f1.4 or 15mm f1.8. Pros and cons of each would be nice to hear. I tend to use my 12-32 Panasonic mostly for street shots, but would like something for interiors and lower light situations....
Richard M. Poniarski
Not a speaker for anyone but myself.
"Everyone is entitled to the reality of their own choice"
 rponiarski's gear list:rponiarski's gear list
Fujifilm X-Pro3 Fujifilm XF 18-55mm F2.8-4 R LM OIS XF 90mm Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR +6 more
Olympus PEN E-P2 Olympus PEN E-P5 Panasonic Lumix G Macro 30mm F2.8
Thin_Ice Regular Member • Posts: 426
Re: Fast prime help
Oly 12 f2 for interiors
Voigtlander 17.5 f 0.95 for low light, but this is manual focus only.
i started with the 12 mm, but didn't like the close distance indoor portriats. This is where the 17.5 rules.
The 12 mm strengths (size, AF, sharpness stopped down) are complementary with the flaws of the voigtlander. Both lenses give excelent colors, micro contrast and overall rendering.
The 15 mm might be a good compromise, but i don't own this one.
Steven
 Thin_Ice's gear list:Thin_Ice's gear list
Olympus E-420 Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
PaulNYC Forum Member • Posts: 68
Re: Fast prime help
I find the Voigtlander kind of heavy, and prefer auto-focus for indoor photos. (I photograph my elusive children.)
 PaulNYC's gear list:PaulNYC's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 17mm F1.8 Tokina Reflex 300mm F6.3 MF Macro Olympus 12-40mm F2.8 Pro
C Sean Veteran Member • Posts: 3,423
Re: Fast prime help
Can you define 'for interiors and low light situations.' These faster primes come with diffierent focal lengths and therefor it's important to know what you shot indoor and outdoor in low light. Also which prime do you use more and what do you shot?
Chas2 Veteran Member • Posts: 3,715
Re: Fast prime help
I think this is highly dependent on your preferred field of view.  Do you have kit zoom you can use with blue painters tape to "lock" the focal length into place so you simulate the fixed focal lengths?
If I had no other information to go on besides what you mentioned, I think I would have to go for the 17/1.8 as an all around lens.  I am interpreting your context for interiors as shooting indoors, rather than shooting interiors (architecturally).  If you actually need the lens for interior architecture shots, i would recommend a wider lens, such as a 12.
How do you like the 19mm FOV?  That is close.  For me, interiors, the 25 seems to be too tight.  I actually get by OK on the 20mm, but I would not recommend that lens with an E-P2.  I love it with my GX7, but the -4EV low light focus ability helps a lot with the 20mm.  Using the 20mm with my GH1 was painful at times in low light.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
rponiarski
OP rponiarski Regular Member • Posts: 449
Re: Fast prime help
When I use the primes from Sigma it depends, though I usually use the 30mm or more often the 19mm for outdoor shots. Indoors I like to shoot people at gatherings, such as when we have some holidays, or trade shows such as the International Motorcycle Show, which I attend every year. I do not like to use flash much, though I have the FL-300R. I am leaning towards the 25mm f1.4 due to the speed advantage, just not sure it is the right focal length, which is why the 15mm and 17mm are interesting me...
rponiarski
Re: Fast prime help
I like the 19mm FOV, as it is one I use a lot. I am planning on using the prime on an E-P5, as I leave my E-P2 for my riding days and that will do it. And I have little interest in shooting interiors; you correctly assume I want to shoot indoors.
addlightness Veteran Member • Posts: 3,641
Re: Fast prime help
Is the f2.8 on your favorite 19mm fast enough for most cases?  If yes and all you need/want is a wider lens, then Panasonic 14mm f2.5 might be a good option.  If you need a faster lens and would like to stay close to 19mm FOV, then 17mm f1.8.  Since 19mm FOV is your favorite, I suspect 25mm might be too tight.
If you want/need faster and wider, then 15mm or 12mm.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
bs1946
bs1946 Veteran Member • Posts: 7,779
Re: Fast prime help
Until I gave them to my son, I had the 30mm and 60mm Sigmas. They are great as short telephotos and portrait lenses but can be a pain indoors. I personally have never been thrilled with the 50mm focal-length so I can't tell you about either 25mm.
I have the 17mm and the 12mm. I always used a 35mm for street shooting but now I've come to prefer the 12mm over the 17mm. Both lenses are great for street shooting. They both have the snapshot feature so with either lens, if you pull back the focus ring, prefocus to 3 meters, and set the aperture to f5.6 or f6,3, everything from about five feet to infinity will be in focus.
I don't have the 15mm f/1.7 but all the reviews and user comments are very positive. One thing I asked about was if the aperture ring and the AF/MF switch worked on Olympus bodies and several people who have the lens responded that they do not. Still it's right in the middle between the 12mm and 17mm and would make another great street lens.
Bill S.
"Sharpness is a bourgeois concept" Henri Cartier-Bresson
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Re: Fast prime help
Concentrate on the 17/1.8 or the 15/1.7 if you like the 19, but want a larger max aperture.  Good luck!
Johnny The Greek Regular Member • Posts: 251
Re: Fast prime help
I have the 12mm, 25mm (Oly) and 45mm, and have tried the 17mm f1.8.  I didn't care for the rendering of the 17mm but if you want a faster lens and shot mostly with the 19mm Sigma, then go for the 17mm Oly.  I think it would be adequate for what you need.
Either way, as others have said, it depends on what you shoot.  I shoot a lot of portraits, so 25/45 is my go to combo.  Robin Wong's blog has a practical comparison of the 25mm f1.4 vs. f1.8, and either way you can't go wrong with either lens.
 Johnny The Greek's gear list:Johnny The Greek's gear list
Olympus PEN E-PM2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +10 more
rponiarski
Re: Fast prime help
Thanks for the tip on Robin Wong's comparison. May make my decision a bit easier...
Ronald Rosenwald Contributing Member • Posts: 552
Re: Fast prime help
I recently opted for the 17 MM F 1.8 from Oly.... it is a great compromise between a wide angle view and a "standard" vfirld of view and excells in the low light situations i soimetimes face in my travel photography. Recent trip to portugal and barcelona showed me the decision was valid.... Plus I can go manual with it with just a snap of the ring....
 Ronald Rosenwald's gear list:Ronald Rosenwald's gear list
Olympus E-300 Olympus E-510 Olympus OM-D E-M10 +2 more
rponiarski
Re: Fast prime help
This looks more and more like the lens I will choose, though that Olympus 25mm is still in the running. May have to head to the store and try them both and see which I like better...
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: Fast prime help
I'm very fond of my 15mm F1.7. It is sharp, has a nice field of view for indoor shots and is fast.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Re: Fast prime help
In this day and age, I suppose you can also point out that the 15mm FOV matches the ubiquitous smartphones Samsung Galaxy, iPhone 5 and 6 FOV (within a mm or two), so maybe the choice of a 15 mm focal length is not so crazy after all...it is a FOV that many are used to.
Miron09 Senior Member • Posts: 1,068
The Oly 1.8 25 usually suffices
I did some available light shots with the Pana 2,5 14mm. I usually avoid WA lenses
 Miron09's gear list:Miron09's gear list
Olympus PEN E-P1 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 Olympus PEN E-P3 Olympus PEN E-PL5 +18 more
Hithertoo Senior Member • Posts: 1,841
Re: Fast prime help
shooting people indoors, I would gravitate towards the Olympus 17mm F1.8, or if you want something really small, the Panasonic 20mm F/1.7 I'd find the 25mm F/1.4 too narrow for my liking.
I own the Panasonic 20mm F/1.7 but that's because it came up cheaper and faster than I could find the Olympus 17mm F/1.7. The Panasonic pancake is fine on Olympus bodies.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
