Gelatin Filter - For Drop in 52mm f/2.8 300mm IS USM II
Started Jun 9, 2015 | Discussions
tvstaff
tvstaff Veteran Member • Posts: 3,264
I'm looking to cut back on my "blues" and "Purples" and "Magenta" as I shoot water sports with my f/2.8 300mm IS USM II and 1DX and also increase contrast if possible
There is a 52mm drop in filter built into the lens and I'm looking for the "Gelatin" to put in the filter holder for varied degrees of UV filtering. I tried the Canon CPL and it's too extreme in color shift.
Can anyone recommend what to buy and offer any advice on what I'm trying to accomplish?
Right now without the filter I'm pulling back on blues and purples in post production and raising the lum on my reds and orange to too much of an extreme.  I'd rather compensate with the proper filter if possible.
Thank you!
http://www.KissMyKite.com
Feel Always Humble - "FAH" - You'll Learn More
http://tony6454.wix.com/aruba-kitesurfing
 tvstaff's gear list:tvstaff's gear list
Canon EOS-1D X Canon EOS-1D X Mark II Canon EOS-1D X Mark III Fujifilm GFX 100S Canon EF 35mm F1.4L USM +28 more
Canon EF 300mm f/2.8L IS II USM Canon EOS-1D Canon EOS-1D X
robert614 Senior Member • Posts: 1,745
Re: Gelatin Filter - For Drop in 52mm f/2.8 300mm IS USM II
I use this drop in filter holder that excepts any threaded 52mm filter of your choice.Although you should make sure the filter is slim enough first.Though I found B+W f-pro filters work fine.So I don't think the filters need to be super slim.
http://www.bhphotovideo.com/c/product/763737-REG/Canon_4773B001_52mm_Drop_in_Gelatin_Filter.html
A little pricey,but I think it's a little less fiddly than cutting out my own filters.
Robert
tvstaff
OP tvstaff Veteran Member • Posts: 3,264
Robert
BINGO! Thank you!! Thank you!!! Thank you!!! Thank you!!!
tvstaff
UV 370 vs. UV 400
Robert
Robert,
I'm shooting over water, want to keep contrast crisp and cut back on those blues and purples.  Need to stay at 1/2500 with as low ISO as possible so sometimes I'm at 320 ISO.
So many choice in 52mm UV filters.  I see some with rated UV values,  Have you found better results with some vs. others?
Thank you
Tony
Re: UV 370 vs. UV 400
Robert
Robert,
Thank you
Tony
Tony,
I'm afraid I don't have much experience with UV filters.I usually use Neutral density filters in my lens.
I shoot a lot of motorsports.So when I when I take panning shots using very slow shutterspeeds in bright daylight,my aperture goes to like f22 and higher.Where diffraction starts creeping in.
The Neutral density filters allow me to keep my aperture in a much more optimal range.
I do use clear filters on my other lenses,just to protect the lens.I use B+W clear filters.But they don't filter any wavelengths of light.I will say I have always used B+W filters though.I don't have any experience with any other brands.
Here's a link that might be of interest to you.It's an old article where they test different UV filters.You probably have seen it before.
http://www.lenstip.com/113.4-article-UV_filters_test_Description_of_the_results_and_summary.html
you can click on the "test" highlighted in red in the far right column of each filter.
This will show you a visual graph of the wavelengths that each filter blocks out.
My guess is that of the two filters you're looking at,the UV 400 would probably filter more of the near UV blues and purples.The visible spectrum is from about 390nm to 700nm.Below 390nm is UV light.
All the filters have slightly different curves of the wavelengths they suppress.You probably want a filter that slightly dips into the visible spectrum to try and tame the near UV blues and purples.
Keep in mind I'm just hypothesizing here.I have absolutely no first hand experience with your problem,or if UV filters will help the situation.
Anyways,I hope this helps.
Good luck finding a solution to your problem.
Robert
tvstaff
Robert
Robert,
Thank you
Tony
Tony,
Robert
Thank you Robert.  This was helpful I never read it before.  If anything it shows the lack of efficacy as I can't see the difference.  This is going to be by trial... hit and miss ROFL  Tony
