Should I get the 17-55mm IS USM lens?
Started Jun 6, 2015 | Questions
Euell Veteran Member • Posts: 5,724
Re: Should I get the 17-55mm IS USM lens?
Abu Mahendra wrote:
Euell wrote:
Ronomy wrote:
Euell wrote:
Ronomy wrote:
Euell wrote:
Ronomy wrote:
Abu Mahendra wrote:
I wouldn't. That Canon lens is an aging lens, good five years ago when the options were fewer and sensors less dense. If you can live with the risk of focus inconsistency associated with Sigma and the absence of IS, I'd steer you to the Sigma 18-35/f1.8. Sharper at f/1.8 than the Canon lens at f/2.8. Mine suffers from focus inconsistency on 6x0D bodies, but I keep it because the optics are so exceptional. I'd then round off the top end with the new, $125 50/1.8 STM lens.
Alternatively, you can consider the 18-55STM kit lens, backed up by two fast primes, the 50 STM and the 35IS.
The 17-55 is certainly not a dated lens and is quite sharp enough for the 7d2, and certainly the 60d. The lack of IS on an all-purpose zoom, such as the Sigma, is a nonstarter. Moreover, while I am still considering the very sharp Sigma 18-35, the posts here indicate focus issues that can be a pain in the neck to address. No such problems with the 17-55. The 18-35 seems like a specialty lens to me, rather than a general purpose standard zoom.
I borrowed a Canon 17-55 f2.8 from a friend before I bought the Sigma 18-35 f1.8. The Sigma is noticably sharper than the Canon lens and I have not needed IS yet. Its crazy sharp at F1.8. Indoors and low light I shoot in live view because of the focus issues although it seems to focus better through the viewfinder when I offset the focus point from dead center.
The Canon is still a nice lens...a little soft at F2.8 when shooting close range though. But not too soIn the end I had to buy the Sigma over the Canon and glad I did. And I don't miss the IS with that fast lens.
You forgot to mention that with 3 f-stops of IS, the 17-55 is capable of shots in far lower light than the 18-35. There is also a fallacy often assumed concerning fast lenses. Wide open there is almost no DOF, particularly for up-close shots. Narrow DOF can be good or bad depending on application, but DOF can be more easily controlled if a lens has IS, because it gives you greater latitude to select F-stops. There is no question that the sharpness of the 18-35 is revolutionary, and, no doubt, Sigma could not have made it so sharp if they had used an optical formula incorporating IS, but darn IS sure is handy.
IS doesn't do me any good when there is movement. My point is I have taken pictures indoors at family events with only a couple 60 watt bulbs in a room maybe less and hand held I still get great pictures with the Sigma 18-35 ART lens. It is not a long zoom lens and its super fast so you can keep the shutter speed high enough. Thus I don't need the IS with this lens. It takes way sharper images at f1.8 than the 17-55 at f2.8.
Now with my 10-18 STM lens it is a slow lens and I need the IS and I also love that lens too.
Well, you're right about the unusual sharpness of that lens and the subject movement issue, but as I say, IS makes the 17-55 the faster of the two for capturing static subjects and, of course, the 17-55 is more versatile.
BTW, the OP says he bought the 17-55.
Well I never said it was a bad lens! I did like it...just wanted a bit sharper. The canon is faster focusing I think in low light.
Since I am personally interested in the 18-35, perhaps you could fill us in on the strengths and weaknesses of that lens based upon your usage.
Strengths:
  • IQ (resolution, geometric and chromatic aberrations)
  • Aperture/speed
Weaknesses:
  • Focus inconsistency
  • weight
Here's one from last night at 18mm and f/1.8 at ISO6400
Any noise cleanup in post?
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6500 Sony a7R III Canon EF-S 17-55mm f/2.8 IS USM +18 more
skanter
skanter Forum Pro • Posts: 25,683
Re: Sharp, fast f2.8 "standard zoom"
joelmiller wrote:
skanter wrote:
Jay Brookstone wrote:
One of the best, really, for a crop frame body. Excellent build quality, too. Flat-out fun to shoot with, especially at f2.8 where it is still very sharp. No IS, but I've never missed it on this lens. If you can really get it for the low price you quoted, it would be a lost opportunity to pass up.
Jay
17-55 2.8 has IS. Hard to believe you own this lens without knowing it!
To OP who hopefully owns lens by now: 17-55 2.8 is a GREAT lens for Canon crop cameras, arguably the best zoom lens for crop. I've used it for 60D and 70D for years. It is incredibly versatile. I use it for indoor sports, tennis, with its very fast AF. It's a fine portrait lens at 2.8.Great for indoor low light shooting and street photography. It's sharp, even wide open. It's an excellent video lens with constant 2.8 aperture (no change in aperture if you zoom in and out). Yes, noisy IS but no serious videographer uses an in-camera mic.
It's heavy, but worth it's weight in gold. It stays on my camera most of the time. Enjoy it, shoot interesting images.
I do now own the lens and I am very pleased with it!
I got it at the perfect time too as my 70-200mm f4 L IS USM had to go in for repair (the focusing ring kept slipping which I have heard is not too uncommon with this lens), so at least I have something new to play with.
In defence of Jay, he did later point out that he meant to say that he just never uses IS.
Why on earth would one -never- use IS, unless always on a tripod and never shooting hand-held?
Anyway, thanks again for everyones opinions.
Joel
Congrats, I'm sure you'll love this great lens.
One thing - there have been complaints that the lens sucks in dust - not sure where, how or why. I, and others, have kept a high-quality UV filter on and never had this problem. I would recommend the same, even if you don't normally keep protective filters on your lenses.
Sam K., NYC
“A camera is a tool for learning how to see without a camera.”
-Dorothea Lange
 skanter's gear list:skanter's gear list
Sony a6300 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 35mm F1.8 OSS +3 more
Abu Mahendra Veteran Member • Posts: 5,312
Strengths:
  • Aperture/speed
Weaknesses:
  • weight
None, zero, zilch.
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
tvstaff
tvstaff Veteran Member • Posts: 3,264
joelmiller wrote:
Hi,
I'm just wondering what everyone thinks about this, this is my first post so bear with me. I currently have a canon 60D with a 70-200mm f4 L IS USM, and an 18-135mm IS kit lens. I'm looking at getting the 17-55mm lens to replace the 18-135mm as a walk around lens, but I'm not sure if it is worth it. I can get it new for about £395 (from a reputable seller), which I'm lead to believe is very cheap for this lens (this price does include a cashback offer from canon). It also comes with a two year warranty. Is this offer to good to miss?
I know that the 17-55mm has a wider aperture and better image quality (the best for an EF-S lens?). I also like the fact that it has full time manual focusing. Is the difference in image quality very noticeable?
I should also add that I like to take landscape shots as well as pictures of people.
I had thought about getting a 50mm prime and just sticking with the 18-135mm.
Does anyone else have any alternative lens combinations?
Thanks!
Joel
YES
Feel Always Humble - "FAH" - You'll Learn More
http://tony6454.wix.com/aruba-kitesurfing
 tvstaff's gear list:tvstaff's gear list
Canon EOS-1D X Canon EOS-1D X Mark II Canon EOS-1D X Mark III Fujifilm GFX 100S Canon EF 35mm F1.4L USM +28 more
jwilliams Veteran Member • Posts: 6,395
i used to have the 17-55 and only got rid of it because I got a 6D and 24-70. I just got the 18-135 to go with a SL1 for a general purpose all in one type kit. The 17-55 is a superb lens. Image quality is great so for pixel peeping it will always win out. I've only had the 18-135 a while, but it seems to have above average sharpness for a lens with a wide FL range. It focuses really fast and the IS is great and I believe better than my 17-55.
In short the 17-55 will give you some lower light capabilities due to its faster aperature, slightly better image quality that I doubt will show up in most real world photos, and less DOF if you want that. The 18-135 gives you a great focal length range for a walkabout not sure what I am going to shoot type lens, it has better AF and IS. If you ever use live view the STM motor will work noticabely better with the SL1, 70D and newer Canon bodies.
I have always recommended the 17-55 to people wanting the best general purpose zoom lens for crop cameras, but after getting the 18-135 I can see where for a lot of people it may be the better lens depending on their needs.
You have a great lens now. Getting a 17-55 will give you another great lens with a different set of capabilities.
Edit:  Just realized you didn't state what 18-135 you had.  My comments reference the newer STM version.  Never had the other version, but I from what I read older one had good optics that were close if maybe not totally the equal of the new STM.  Hope this helps.
Jonathan
