Autofocus issue with canon EF 28 mm f/1.8 on a 70D
Started Jun 6, 2015 | Questions
pilou1253 Regular Member • Posts: 139
Hi there!
I recently purchased a used canon lens EF 28 mm f/1.8 to go with my canon 70D. I made some tests and I find that when shooting in autofocus mode, with autofocus on one AF-point only (at or near the center), the zone of focus in the final picture is actually not exactly on the AF-point but slightly behind.
I made this test for several aperture value, from f/1.8 to f/6.3, and it does not change the problem significantly. All shots were taken without recomposing the picture.
The lens is in good state, no indication that it could have suffered any damage. However, can a certain damage on the lens trigger such an issue on the focus system?
Has anyone observed similar thing? Is there something I am missing?
Thank you in advance for any tips or feedback!
Best regards
PL
 pilou1253's gear list:pilou1253's gear list
Canon EOS 1000D Canon EOS 70D Canon EF 28mm f/1.8 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +7 more
Canon EF 28mm f/1.8 USM Canon EOS 70D
davel33 Senior Member • Posts: 2,978
Re: Autofocus issue with canon EF 28 mm f/1.8 on a 70D
The 70D has MFA, try it
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
OP pilou1253 Regular Member • Posts: 139
Hi Dave,
Thanks for the tip, didn't know about this nice feature! Will try it and keep you posted!
Regards
PL
Hi again Dave,
I tried the MFA and it seems to have improved the results a bit.
However, I think I am just simply and slightly disappointed by this lens... Hard to get sharp focus, and incredible high chromatic aberration between f/1.8 and f/2.5, even with the automatic correction function turned on. Or it is simply just too hard to switch from an IS lens to an older one...
Thanks for your help anyway!
PL
Sorry its not working for you, I did not think much of the 28 1.8 for the same reasons you give.
Best of luck.
Dave
snofox Regular Member • Posts: 334
I would check on the forums for this, because I think it is an issue with some 70Ds not being able to focus correctly with fast lenses (faster than f/2.8). I don't know if this has been resolved by now, but there were posts on it when the 70D first came out.
EDIT: I'm probably wrong. If your lens doesn't focus correctly by f/2.8 or higher, then the problem is not the 70D. I just remembered that you said it isn't good at f/6 either.
 snofox's gear list:snofox's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS 60D Canon EOS 700D Canon EOS 80D +6 more
Abu Mahendra Veteran Member • Posts: 5,312
Best of luck.
Dave
I'd buy an EF 28mm f/1.8 IS USM in a flash!
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
Hi all,
Thanks for your messages. Actually, I've been making some more tests and the lens performs rather well (let's how I expect it to behave...) in Live View focus, with very sharp images in focus. The soft focus only occurs when using AF-points.
Anyway, I also find that I don't need to shoot so much wide open, all my shots are done at f/2.8 which gives the best results for my topics (mainly my daughter). Shooting higher than f/2.8 always brings the risk of having only her nose sharp...   And limiting the aperture to this value also has a great advantage: no more problematic chromatic aberration.
I also read about these supposed misfocus problem with the 70D but I think it performs great with all my other lenses. I am only an amateur, so there might be some things I still need to lear to be alble to overcome this AF-point issue on the 28mm f/1.8 lens.
Cheers!
PL
