Wide angle dilemma
Started Jun 6, 2015 | Questions
David Seume New Member • Posts: 6
Wide angle dilemma
In my FF film days, I had always enjoyed using a 24mm prime and, although later (with a DSLR now) I acquired a 10-22mm (14-32mm equivalent), it was the prime I favoured as a general lens.
For quite a few years I hardly used these cameras at all, prefering to use a decent compact. Then I discovered the Olympus PEN! The first additional lens I bought after buying my PEN e-pl3 was the 9-18m to recapture those wide perspectives. More recently, now with an OMD em10, I have added the 25mm f1.8 and 45mm f1.8 to my setup and I must say, IQ aside, I am enjoying the primes over zooms.
My dilemma is this: I am very taken by the prospect of the 12mm f2 prime but, given the cost, I would almost certainly have to sell the 9-18mm to fund it. Like most people here, I suspect, I use wide angles for a mixture of landscapes and interior shots. Clearly, for the latter, if the 12mm was wide enough, I'm sure its speed would be a real benefit but would that outweigh the lack of the extra 3mm?! Aaargh!
Any advice/thoughts (especially from anyone who's used both) would be much appreciated.
 David Seume's gear list:David Seume's gear list
Panasonic ZS100 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +2 more
Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,722
Re: Wide angle dilemma
I'm in the market for a 9-18 myself, but for a specific subject of interior design photography, so a wide aperture is not really of concern to me. Now, there might be another option that will give you the chance to keep your 9-18, and that is the Rokinon/Samyang 12mm f:2.
It is highly regarded, and it should be as sharp as my 7.5mm, which I love. Is manual focus only, but, depending on your subject, that can be manageable.
Martin
"One of the biggest mistakes a photographer can make is to look at the real world and cling to the vain hope that next time his film will somehow bear a closer resemblance to it" - Galen Rowell
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Pro Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH 7artisans 7.5mm F2.8 Fisheye +13 more
bradevans
bradevans Senior Member • Posts: 1,029
To *me* the 12/2 is too specialized and pricey, when you have three zooms: (both 7-14s, and the 9-18).  Plus you have the inexpensive (defished) Rokinon
The 9-18 is sometimes available as reconditioned on getolympus.com for $399 + tax
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 Panasonic Lumix DMC-GX7 +14 more
Martin Ocando
Are you sure about the 9-18? There is one right now, but is the 4/3 version, which is cheaper than the Micro 4/3.
Martin
Karld70 Veteran Member • Posts: 3,553
It's hard to answer because only you know what you like to shoot and what you need.  If you already have the 9-18, then you already know how often you need/want wider then 12 and if you would miss the 9-11 end. On the wide end, that makes a big difference, just like 12 is a bit wider then 14, but you would not see a big difference between say 48 and 50.
Not sure if you have spent any time looking through you pictures.  I always recommend doing an inventory of your pictures to keep note of what focal length you actually use the most.
An example, I'm new to M4/3, but did a review of what focal length I tend to use the most on my 12-32.  There is a obvious spikes on both end you tend to get with a zoom, bit I was surprised how often I shoot at 12
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Addressing your specific question, David
I would not find the f2 12mm adequate for interiors. That extra 3mm of the 9-18 delivers a dramatically wider angle.
I have two 12mm lenses -- the 12-32 and 12-35. In general use, they have reduced my use of the 9-18 compared with when I my previous "standard" was the Panny 14 BUT for the specific purpose of interiors, the 9-18 remains my go to lens.
In addition, there are landscapes where that 9mm angle of view is the only one to use.
That said, if I did not have the 9-18, I might try panoramas.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital 45mm F1.8 Panasonic 12-35mm F2.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
John Kubler
John Kubler Regular Member • Posts: 322
I have the 9-18 for over two years and I am very satisfied with the lens IQ. It is very sharp, except the corners are not tack sharp even at f5.6 (in need to pixel peep to see it). I recently acquired the 12mm f2 and I am very pleased. Obviously the 9-18 at 9mm is wider, but in most cases 12mm is wide enough for me. The 12mm f2 is very sharp across the frame at f4 and acceptable wide open when I need all the light. The manual focussing option is great when using the hyper focal distance for landscapes. Since I have the 12 I have used the 9-18 only a few times when I really need the very wide angle.
JMK
 John Kubler's gear list:John Kubler's gear list
Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +16 more
Day Hiker Forum Pro • Posts: 10,829
that 12mm f/2
The M.Zuiko 12mm f/2 is a fine prime lens. I acquired one in 2011 as soon as it was available. It's small, well built, attractive (I have the luscious silver version), and the image quality is very nice. My favorite aperture is f/4, but it sure is nice to have very usable f/2 when needed.
How do you know if 12mm is wide enough for you? Well, if 12mm is all you have, then 12mm is wide enough; you work the scene in front of you to a 12mm composition. No problem. I supplement my 12mm f/2 with the Lumix 8mm f/3.5 fisheye, but I never defish.
Jim Pilcher
Summit County, Colorado, USA
Johnny The Greek Regular Member • Posts: 251
Re: that 12mm f/2
I recently sold my 14mm to offset the cost of a used 12mm f/2 and I'm pleased with it, though it is early days yet.  To my eyes, though it's worth more than the 14mm, it's not worth 4x the used value of the 14mm which goes for around $150 on Ebay.  I got it for about $550 used.
I do a lot of indoor photography and outdoors I like natural lighting, so the 9-18mm was never going to have a wide enough aperture for what I needed.
 Johnny The Greek's gear list:Johnny The Greek's gear list
Olympus PEN E-PM2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus 9mm F8 Fish-Eye Body Cap Lens +10 more
bradevans
Hi Martin,
the 4/3 is almost always there at $399 - in fact i ordered one without noticing it said Zuiko not M.Zuiko.
But I did get my order in for the m43 (at the same $399).  I ordered it on May 28th and not here yet.
Ordered but no sign that it has shipped yet...
Bob657 Veteran Member • Posts: 3,486
The Rokinon 7.5 is on sale now for $199, that might help for when you need wider than 12mm.  Alternatively, there's always panorama that's more accessible now that LR6 includes it.
Bob G
 Bob657's gear list:Bob657's gear list
Sony a6400 Sony a7R IV Sony FE 100-400mm F4.5-5.6 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD
Martin Ocando
Hi Martin,
Good to know. Sadly, I'm saving on Amazon gift cards, so I'll have to buy through Amazon. Still a long way to go, though.
Martin
JeanPierre Martel Veteran Member • Posts: 3,304
David Seume wrote:
In my FF film days, I had always enjoyed using a 24mm prime (...)
You're a prime guy and you already have the M.Zuiko 45mm and the M.Zuiko 25mm. So that's obvious: the M.Zuiko 12mm will be a good choice to complete your lens collection.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
bikerhiker Regular Member • Posts: 499
Have you considered the Samyang 12 f/2 @ $349.  Half the price, but is manual focus.
I bought a Bower 14mm f/2.8 and a Mitakon focal reducer for $359 which makes it a 10mm f/2, which is a 20mm f/2 FF FOV.  It's wide enough for my interior shots.  Sharp at center at f/2 but not so hot on the corners.  The native Samyang 12 f/2 performs better on the corners by 1 stop from my Bower.  I'm saving up to buy a refurbished Olympus 9-18 just for the times I need autofocus to complement the Bower.  I find that at times, I like the flexibility of a UWA zoom where my movement is restricted in confined spaces.
 bikerhiker's gear list:bikerhiker's gear list
Nikon Coolpix AW110 Panasonic ZS100 Olympus PEN E-P5 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +1 more
addlightness Veteran Member • Posts: 3,641
I have the 9-18mm and the 9mm@f4.0 is wide enough(both angle of view and aperture) for outside enclosed areas (e.g. courtyards in medieval castles, etc).  For interior purposes, in low light, f4.0 is a challenge as I like to keep my ISO no more than 1600 if I can help it.
There's when I use my Panasonic 14mm f2.5 coupled with a 0.76x wide converter adapter converting my 14mm f2.5 into a 11mm f2.5, a 1 1/3 stop faster than f4.0 but 2/3 stop slower than a f2.  However my used 14mm was only $150 and another $12 for the wide converter.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 II Olympus E-M5 III +14 more
Hithertoo Senior Member • Posts: 1,841
I own both lenses and honestly, I'm glad I do, the 9-18 only becomes fully sharp at F/5.6 the Olympus 12/2 is fully sharp wide open, the difference in sharpness is more than noticeable, the 12mm F/2 is wide enough even if the 9-18 is wider.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
jeffharris
jeffharris Forum Pro • Posts: 11,410
If you think you'll miss the 9mm end, you will! I have the 7-14mm f4 and would never give up the wide end for anything!
I have an SLR MAgic 12mm T1.6 that I thought would be great for my interior shooting in low light, but at least for me, 12mm just doesn't cut it!
When I'm not doing quick progress shots of renovations, where I crank up the ISO a bit, I just carry my tripod and cable release.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
complete agreement
I have exactly that focal length combination and it's excellent. Each lens is fast, small, and sharp. Eventually I'll round it out with the M.Zuiko 17mm f/1.8.
I cap my trio at the long end with the 75mm f/1.8.
If I could wish for another prime, it would be 8mm f/2.4 in the size range of the 12mm f/2. I would say 8mm f/2, but that would probably cause it to grow from the 12mm f/2 size.
Jim Pilcher
OP David Seume New Member • Posts: 6
Thanks!
Thanks to all who have contributed answers to my question.
I guess I need to be patient and a) assess all the photos I have taken using between 9mm and 12mm, b) keep on using my 9-18 and analyse my images and c) try to take note of any photos I might miss through not having the faster lens/wider FL.
