Discovering the SD15...
Started Jun 5, 2015 | Discussions
papillon_65
papillon_65 Forum Pro • Posts: 27,030
So I bagged a mint condition SD15 complete with Sigma 18-50mm F2.8-4 lens all the way from Latvia for the princely sum of £190, which I consider to be quite a bargain. Judging by the condition of both camera and lens they had hardly been used. The file count is only around 1700 shots and the condition of both items reflects that. I bought it for infrared shooting and having done some tests with the combination it works very well. I've mounted an old Helios optical viewfinder in the hotshoe which is marked 35mm, 85mm and 135mm so I can recompose after putting the IR72 filter on the lens and switching to manual focus and it all works as I'd hoped. The lens is not bad at all, not Sigma Art quality but good enough for my purposes.
When I processed the X3F files I discovered that Lightroom 4 actually supports SD15 X3F's, which was a pleasant surprise to me. Not only that but it doesn't do a bad job with them either so happy days. I also learned that focusing is a bit flaky on the SD15, sometimes it's a bit hit and miss so you have to be careful. You also have to sharpen the X3F's from the SD15 by quite a bit, which isn't how I remember the files from the DP2X, which I think has the same sensor, the colour definitely seems the same as the 2X anyway, which is good as I liked it, the dynamic range also seems pretty much the same and a bit more forgiving than the Merrills.
Anyway, overall I'm pleased with the set-up, a typical Sigma cam, no frills, does what it says on the tin, though I do like the mirror lock up being on a dial and the bracketing feature, which is neat. Hopefully we'll get some decent sun this weekend so I can do some IR shooting and post back.
"In a time of universal deceit telling the truth is a revolutionary act".
George Orwell.
http://bit.ly/1BIquIF
 papillon_65's gear list:papillon_65's gear list
Fujifilm FinePix X100 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sony Cyber-shot DSC-HX50V +7 more
Sigma DP2x Sigma SD15
Pete Stavrakoglou Veteran Member • Posts: 8,331
Re: Discovering the SD15...
The SD15 is not supported by Adobe ACR, in Lightroom or Photoshop.  The last camera supported was the SD14.  While files from your SD15 will open in ACR, they will not process correctly.  Use SPP for RAW conversion.
My humble photo gallery: http://www.pete-the-greek.com
 Pete Stavrakoglou's gear list:Pete Stavrakoglou's gear list
Fujifilm X-S1 Sigma SD1 Merrill Canon EOS R Sigma 10-20mm F4-5.6 EX DC HSM Sigma 70-200mm F2.8 EX DG Macro HSM II +18 more
papillon_65
OP papillon_65 Forum Pro • Posts: 27,030
Well they looked ok to me so I'll not worry too much about it.
George Orwell.
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Hmmph! My new-in-box SD14, ordered 5 days ago, hasn't even shipped from Amazon yet, grrr.
Quite tempted to pop the filter out of the current SD14, now we've got some sun around here  . . .
Pedantry is not a felony.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
xpatUSA
Peter is right to an extent, especially re: SD14. The SD15 colors were not quite right in ACR, if I recall correctly, even though the X#F could be opened and would display a review image. I find similar for FastStone Viewer - both for DP1s and Merrill X3F and, yes, FSV does decode X3Fs if you set it to.
Still, for IR or even full-spectrum work, color accuracy is virtually irrelevant, is it not? I've had pleasant results from RawDigger RGB exports for SD10, SD14 and SD1M, they come out not so insanely pink.
Looking forward to seeing your stuff . . .
Ted
papillon_65
I do all my black and white stuff in the Silver efex plug-in from Lightroom so I have to go through it really.
Thanks, hoping to get in the forest this weekend, no shortage of green stuff in there at the moment.
Ted
George Orwell.
papillon_65
Well the Latvian Postal system must be uber efficient, only took two days to get here in the UK.
Should work as well as the SD15 for IR stuff and popping the dust protector/Filter out is no biggie. I also lkie it because you get to shoot when normally you'd do the opposite due to the harsh light.
Ted
George Orwell.
target5
target5 Contributing Member • Posts: 813
An amazing, immortal camera, the colors are appealing, love mine.
 target5's gear list:target5's gear list
Sigma DP2 Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD15 +4 more
tennjed Junior Member • Posts: 46
I ordered my SD15 from Sigma Outlet this past Wednesday at about 1:00 PM. I received it this morning at about 10:00. At the Outlet web page they state that your camera could be refurbished, a return, or old/new stock. From the looks of my camera, I got lucky and received a new camera.
I popped in the Pentax M42 adapter and have been playing around with a couple of my Pentax M42 lenses. JPEGs look pretty good. I haven't recorded any RAW files yet.
For $399, I could not pass on it. Oddly enough, it has the same feel as my Merrills: sort of like one of the Merrills has morphed into a DSLR and developed a few more aggravating little quirks along the way. I think I am going to like it.
 tennjed's gear list:tennjed's gear list
Ricoh GR Digital Ricoh GR Digital II Ricoh GXR Mount A12
Here are a couple of my first shots with the Pentax lenses
Pentax M42 Takumar 200mm 1:3.5, Sigma SD15
Pentax Macro Takumar 50mm 1:4, Sigma SD15
papillon_65
Yes I think I'll like mine, basic and old school, I always like that, and the feel that you're not one of the pack.
George Orwell.
papillon_65
How did you find the manual focusing? I have a super tak 55m F1.8 which I will be trying on mine when the adapter arrives.
George Orwell.
The screen is not ideal as it is small and does not appear to be real contrasty. Images do not jump into focus with the two Pentax lenses I have tried. The autofocus indicator is not even close. However, I think it is good enough.
The two images are from the first 50 images that I have shot with this camera. As you can see, the focus is not perfect, but I believe I will get better as I practice. This weekend I will get a few shots with my Zeiss M42 50 1.4. As far as manual focus lenses go, the optics on that lens cause the image to virtually leap into focus on my Pentax cameras. It will provide the real test.
Roland Karlsson Forum Pro • Posts: 30,033
So .... then we are back to the pre Merrill color look. Flower photos with strangely colored and desaturated greens. That is a property for the sensor found in all the pre Merrill DP cameras and SD14 and SD15.
And, of course, SD9 and SD10 had other color problems. Foveon blue skies and yellow skins, anyone?
I would say that Merrill and Quattro are the only sensors with natural looking colors. At least out of the box.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
(unknown member) Senior Member • Posts: 1,857
I don't know where this comes from. The SD15 is (in general) known for very good color.
The main issue for me was the highlight clipping and relatively low resolution for bigger prints.
I wish my SD1 could produce this result (without photoshop) in such situations:
ISO400, auto WB
Yes it is - in particular compared to SD14.
But - IMHO - the sensors that are found in the SD14 to SD15 generation of cameras has a hard time handling flower pictures. If you choose to get the petal colors correct, then the green is often desaturated and a strange color. Just look at this image. No green greens there.
ISO400, auto WB
One of the main disadvantages of Merrill and Quattro is noise. The two lower RAW channels are very noisy. Something you have to correct when doing color conversion. But ... there is a limit to what you can do.
We in Kalpanika have, just as Sigma, managed to tame the noise in Merrill and Quattro. But, it did take some rather exotic noise reduction of the two lower layers before doing the conversion.
If you are referring to the shots that I included with my previous post, I have the picture settings at -.6 saturation. It was one of the things I changed, right out of the box.  Generally speaking, I find most cameras over saturate.
Do you have a calibrated monitor?
DMillier Forum Pro • Posts: 23,871
The greens here do have rather a SD9 greyness to them.  In fact the whole image looks to have very greyish, low contrast look.  I think this is likely to more a processing choice than the sensor.
My sense is that Foveon colour becomes more believable and more "Bayerish" with every Foveon generation.  The SD9 in particular is peculiar, the SD14 can do nice looking colour if you can tame its tendency to green-yellow overall casts. But for me all the early cameras tended to do odd things to some colours and tended to respond dramatically to the colour temperature of the light. I don't like my SD9 or Sd14 in warmish light, it gets far to yellow/warm looking for my taste. The newer cameras, incl the SD15 seem to have a much cooler rendition that I prefer.  The quattros seem to be the most "normal" of all. Some people might think they are too Bayer like?
Good to hear you guys are still hard at work with your dev work, is any kind of progress report hint possible?
"...while I am tempted to bludgeon you, I would rather have you come away with an improved understanding of how these sensors work" ---- Eric Fossum
Galleries and website: http://www.whisperingcat.co.uk/
Flickr: http://www.flickr.com/photos/davidmillier/
I tried to adjust the colors. Increasing saturation made the nearby greens good, but the grass in the background still was grey, even though it is in the sun. The blue flower though got a tendency of over saturation before the nearby green looked good. I think it is the same problem as always. The color space is seriously bent, like space in the Einstein universe. It is possible to correct, but you need to do serious stuff.
As usual ... things are not progressing as fast as you want and first estimated. But ... something is going to happen.
