GM5 and some BIF's
Started May 27, 2015 | Discussions
hifi
hifi Senior Member • Posts: 2,569
GM5 and some BIF's
18
Taken this past weekend with my GM5 and RDS (Red Dot Sight), and the 100-300 lens.  Some of these are not technically in flight, but they move quickly - land, snatch food, and takeoff again.  Last 2 are from a grebe nest.  Thanks for looking.
 hifi's gear list:hifi's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
brentbrent Veteran Member • Posts: 5,766
Re: GM5 and some BIF's
Those look great to me!  I've seen enough shots with the 100-300 that I'm sometimes tempted, though I don't lean toward the long end.
Your thread title says "GM5" but the EXIF says "GM1."  I'm assuming it must be the GM5 with a hot shoe to mount the red dot sight?
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
alatchin Senior Member • Posts: 1,055
some great angles there
I tried a bit of this the other day, itvis a lot of fun.
how did you find the combo for AF?
“You don’t take a photograph, you make it.” -Ansel Adams
blog.alatchinphotography(dot)com
jjdsyd New Member • Posts: 15
Re: some great angles there
Wow these are great shots from that little camera. And good technique from you. Not easy. Were you using continuous focus?
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: GM5 and some BIF's -- excellent, hifi!
Some very nice pictures indeed. Inspiration for me.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
hifi
OP hifi Senior Member • Posts: 2,569
Thanks!
Yes - I am using a GM5 but have to change the exif on the raw files to GM1 so DXO Optics Pro can process the files.  Still waiting for them to release an update, but I have a quick batch solution to change the exif's so a quick fix for now...
hifi
I am very pleased with the GM5/100-300 combo; works fine for me!  The main item that helps me for BIF's and other fast moving objects is the RDS (red dot sight).  The RDS helps me get the subject in view of camera and then it is not that hard for the camera to lock focus and get the shot.
hifi
Thanks!
Yes - mostly using CAF and high speed burst.  I love the GM5 because to most people it looks like another everyday point & shoot, but it is a serious camera.  For this session, I had on the 100-300 lens and a red dot sight (the camera was buried in there somewhere).  Afterwards, popped the 12-32 kit back on and the camera is back in "casual P&S" mode.
hifi
Many thanks!
alcelc
alcelc Forum Pro • Posts: 19,003
Shooter or gear first
Well done.
It just comes up to my mind again, would the shooter or the gear be more importance?
You had demonstrated how to do BIF successfully on using the tiny camera and known not fast AF lens (some even classified it an old design)!
Zensu11
Zensu11 Senior Member • Posts: 1,542
Thanks!
Also waiting on DXO. You got some great captures, so good that I'm re-thinking getting a telephoto zoom for this great little camera. I'm sure their are others beside myself who would love to see a photo of your Red Dot Sight setup.
Bobby
Chas2 Veteran Member • Posts: 3,715
Re: some technical questions
hifi wrote:
.., For this session, I had on the 100-300 lens and a red dot sight (the camera was buried in there somewhere).
Can you discuss your red dot sight set up and how you calibrate for distance? Or do you need to. i imagine there must be some parallax error and some optimal distance...but maybe it does not matter....
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
nice set
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
hifi
Trevor Carpenter wrote:
nice set
Thanks!
hifi
Re: Shooter or gear first
alcelc wrote:
Well done.
Thanks, appreciate your comments.
I think it is part gear, part photographer skill.  I won't guess at the percentage breakdown
hifi
To calibrate the RDS, I set the 100-300 lens at about 200mm, then focus at something about maybe about 20 or 30 feet away.  I hold the setup away from my face so I can see both the rear LCD and the dot in the sight at the same time, and get the two to match up as close as possible on the target.  To calibrate, my model has two adjustment screws to move the dot horizontally or vertically, but all RDS's should have a similar setup.  Once calibrated, you should not need to do it again, as it will always be setup for that lens.
I have not encountered parallax error.
hifi
pics of my setup (GM5 + 100-300 + RDS)
Zensu11 wrote:
Thanks!
Bobby
I remember on the DXO site, it originally had February 2015 as the expected date for GM5 support, but now just brings you to the suggestion page...  At least they support GM1, and it is easy to change the exif's to GM1 for raw support now.
Here are some pics of the setup:
Considering the very small size of the GM5 body, I actually don't find it uncomfortable to use with this setup.
thank you very much!
RichardGSmith Regular Member • Posts: 320
Very nice!
Rich G Smith
PhotonX30
PhotonX30 Regular Member • Posts: 179
Re: pics of my setup (GM5 + 100-300 + RDS)
Is that Photosolve's " Xtend-a-sight " rail/hot shoe adapter?
 PhotonX30's gear list:PhotonX30's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Rokinon 7.5mm F3.5 UMC Fisheye CS +4 more
