I tried to print photographs on my color laser HP m476dw, but the output was not satisfactory enough.
The printer has 24bit depth of color and 600 dpi resolution, better than a typical photolab (300dpi).
Some pictures, for example resolution diagram, come out better than from photolab (because of better resolution?), some color images are of similar quality.
Many color pictures come out worse though, showing a sort of grainy areas, not visible on the same copies from photolab.
I tried aligning cartriges, different setups including recommended settings for printing photograps I found in the manual.
The output got a little bit better but still not so good as I expected.
Anybody here tried to print photos on laser printer? could you share your experience?
