Lenses on Crop Sensor Cameras and Distortions
Started May 19, 2015 | Questions
hanhasgotqi
hanhasgotqi New Member • Posts: 9
First of all, a big thanks to DPReview for helping newbies like me learn the basics of photography.
I need to take some close-up shots of villagers where I live, for a research on facial deformities and diets. I'd like to avoid distortion of any kind when taking these photos. Ideally the faces in these photos would look very much like how we see them in real life. I'm referring to both the widths of faces and facial features.
I understand that, on a FF camera, a 28mm lens will distort my subject a little (close-up shots), and a 135 mm lens will flatten my subject’s features. My question is: what determines this distorting or flattening effect? Is it angle of view or focal length?
In other words, if I use a crop sensor camera like Canon 70D, and a 28mm EF lens, will faces in close-up shots look slightly distorted, like what we expect a 28mm lens on a FF camera would do, or will the faces look quite normal, like the ones taken with a (hypothetical) 44.8mm EF lens on a FF camera? (I'm under the impression that 40mm-65mm lenses are considered normal lenses on a FF camera - not distorting subjects)
Please correct me if I've got any point wrong. Thank you!
Canon EF 28mm f/1.8 USM Canon EOS 70D
J A C S
J A C S Forum Pro • Posts: 20,544
Re: Lenses on Crop Sensor Cameras and Distortions
The angle of view of the object relative to the axis. Even with a very wide lens, faces close to the center will look normal.
Yes to 44.8mm. BTW, there are distortions at any FL, just less visible. They are not really distortions in the sense that the lens may do a perfect rectilinear projection but the faces will still look distorted to us.
If you want to minimize those distortions, choose longer FL's or do not allow people near the borders. Another option is to use software correcting "volume anamorphic distortions" like DXO's ViewPoint. See this, for example. I use it often and the effect is very nice.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
It's perspective, the distance of the subject from the camera.
28mm on the 70D v. 45mm on full frame:   If the subject is the same distance from the camera, same composition/framing, then then the faces will look quite normal.  Just as shooting from the same distance with a 10mm lens on a compact digital, or 5mm lens on a phone will give normal looking faces.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
The Mad Kiwi Senior Member • Posts: 1,074
Use the standard 18-55 zoom and shoot at 55mm, comes out at 88mm which is pretty much ideal.
I shoot my headshots at 100mm with lights on a full frame and they look pretty neutral. Here's a link. Corporate Headshots so you can see what 100mm looks like. I use an 85mm for natural light. so 55 on a crop will be spot on.
There will be a bit of lens distortion on a zoom, but not enough to worry about, lightroom will take care of it automatically if you're worried about it. It's more the focal length you need to get right.
Don't shoot shorter 55 on a crop, it'll make the noses appear bigger than they actually are due to perspective.
 The Mad Kiwi's gear list:The Mad Kiwi's gear list
Panasonic Lumix DC-G9 Sony a7 III Sony a7R IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +9 more
photonius Veteran Member • Posts: 6,895
As others pointed out, around 50mm on FF (crop: 50/1.6) gives about the look the human eye is used to in terms of angle of view. However, portraits are usually taken with slight tele, i.e. 85, 100, or 135 (FF). As pointed out, they key to perspective is distance. A person imaged with a wide-angle lens at 10meter distance in the center of the frame will have a perfectly fine portrait, but you might be left with a 100x100pixel crop (or whatever) for the portrait.
the key about perspective: closer objects are larger than further distant objects. (i.e. the big nose with wide angle portraits). If the person is very far, the distance to the nose, and to the ears will be virtually the same in relation to the total distance. For scientific purposes, it's better to have little perspective distortion, because that means, you can take a ruler on the image, measure features of the face, and they will be to scale.
Thus, I would recommend to go as long as you can (space, good illumination) to get relatively "flat" images. 100mm, 200mm whatever is feasible. Try to use always the same distance (like mug shots), even with a ruler in the background, then you can compare different shots. Of course, you may then take specific close-ups of particular features in addition.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
msowsun
msowsun Contributing Member • Posts: 740
Here is a simplified answer: Use what ever lens you want, but make sure you stand back at about 10'.
The kind of distortion you are talking about is caused by being too close to the subject.
The focal length or sensor size does not matter. You need to stand farther back to eliminate perspective distortion with any lens or camera. 10' is about the minimum distance you should be.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
BAK Forum Pro • Posts: 26,020
Confused yet?
There's good info here already. Just a couple of thoughts.
Two kinds of "distortion"
There's barrel and pincushion distortion, where the picture is stretched out in the middle of the four sides, or squished in.
This is what makes people at the edges of wide angle frames look are weird.
And there's compression distortion. This is what makes noses look big up close with a wide angle lens, or telephone poles look close together when shot with a telephoto lens.
This second kind is what matters most to you, I gather.
For low budget, the suggestion you use your kit lens at 55mm is a good idea. I do this all the time.
If you had a 18-135, or a 55- 250, you could zoom to 60-70mm for the ideal perspective.
Sigma make a 70mm lens; Canon makes a 60mm lens, as does Tamron. Any 24-70 would be a good choice, but these are either expensive or really expensive.
BAK
photosen Veteran Member • Posts: 6,226
The perspective, which is associated with the angle of view.
Perspective doesn't change with the crop factor, so a 50mm lens still looks like a 50mm lens, it's just that you get a crop of that. So I would choose the best focal length that works for your project, in this case probably an 85mm, just take into account its minimum focusing distance which is about a meter if I recall correctly. A prime would have the advantage that you wouldn't run the risk of taking different subjects at different focal lengths like with a zoom, and be less cumbersome.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
yup
well, focal length does matter, there is no point using an ultrawide at 10' distance if the facial features that are to be recorded become to small on the sensor.
I would actually recommend an even longer distance if space allows.
hanhasgotqi
OP hanhasgotqi New Member • Posts: 9
You guys are the best! Thank you for taking the time to answer my questions.
I searched and read a little more on barrel/pincushion distortions and perspective. As msowsun and BAK pointed out, I’ll back away at least 10’ to make sure perspective distortions are at a minimum. I can always crop down to a headshot for my purpose; the headshots don’t have to be pretty, as long as they show how the faces look.
To JACS, I am guessing the example you linked to is a kind of barrel distortion? Am I right in saying it is inherent in most wide angle lenses?
I’m considering Canon’s EF 35mm f/2 IS USM because I may shoot videos hand-held, and I’d like to have the IS. (I'll be using a crop sensor camera - 70D) But mostly I’d be taking stills. 35mm qualifies as a wide angle lens on a FF; on a crop sensor camera, however, am I mistaken in thinking that, because the crop sensor is essentially recording what’s in the middle of the lens, any obvious barrel distortion at the peripheral wouldn’t register on the crop sensor? (I’m referring to stills)
Anyhow, I like the idea of backing away a distance and taking crops in post. For gathering information that is. Any suggestions will be much appreciated! Thanks!
no, not necessarily. primes tend to be better than zooms, and in zooms it's mostly only the wide-angle end which has barrel distortion, but as you zoom in, it disappears, so you have to look at which focal length you use the lens.
best is to look on web sites (photozone.de,  the digital picture) and others, to see what distortion you get.
STM lenses would be even better if you want to use the automatic focus.
it depends on the nature of the distortion, if it is complex, such as a moustache distortion (e.g. Samyang 14mm), cropping will remove some of the worst effects.
However, if the barrel distortion is a very regular curve, then cropping will only remove it partially.
just check how much resolution you need in the end.
Ember42 Contributing Member • Posts: 697
I think from a technical standpoint the 60mm f2.8 macro would be best here. As a macro prime it has negligible barrel or pincushion distortion, and is a focal length that would get a lot of pixels on the face at 10'. It is also very high resolution so you will have lots of detail to work with.
 Ember42's gear list:Ember42's gear list
Canon EOS M Canon EOS 7D Mark II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Fujifilm X-T1 +13 more
sounds like a good suggestion.  And one doesn't need large aperture lenses for this, since you want to stop down for the purpose anyway.
J A C S
No, it is natural "distortion" most visible with wide lenses near the border. Barrel distortion would actually make it look better!
Line up three bottles, shoot them with a wide lens filling the frame, and even if the lens is perfectly rectilinear, the bottles near the edges will look visibly fatter. Replace the bottles with a picture of three bottles, and they will look the same!
hanhasgotqi
Thank you J A C S. By "natural distortion", do you mean something other than barrel distortion and perspective distortion?
If I use a EF 35mm IS USM on a 70D, do you think I'd see the "natural distortion"s near the borders? Or do you think the smaller sensor would've cropped out the distorted parts?
Thanks!
J A C S
It is usually referred to as perspective distortion.
You will see less, like 50mm on FF. But if you get too close and your object is too close to the borders, you will still see it.
BTW, I am not affiliated with DXO in any way but their View Point can do wonders, you should try it.
hanhasgotqi
Just want to say thank you Ember42. This is a great advice. I'm reading up on this lens and macro lenses in general. Seems like a better fit for my work than the 35mm lens.
