Very, very impressed by the Canon 8-15
Started May 16, 2015 | Discussions
Lee Jay Forum Pro • Posts: 56,673
I've loved my Sigma 15mm f/2.8 fisheye, used primarily on my 5D. It's crazy good optically, wide and fast.
But I just got a 7DII, which I'm loving so far. So I decided to get the Canon 8-15.
First, it is a stop slower, but the 7DII is much better at high ISO, so that's a wash.
The 8-15 is actually capable of going a bit wider on the 7DII than the Sigma 15 on the 5D, so that's nice. Oddly, it's a little wider on the 5D than the 7D before the vignette (at around 14mm versus around 9mm). It's not a huge difference, but I don't understand it. Maybe it's because the lens moves in and out a bit.
At longer focal lengths on the 7DII, it's quite good for defishing and/or cropping. That makes it a pretty solid ultrawide rectilinear from just a single click in Lightroom. The Sigma can do that as well, but it needs more cropping and that costs a lot more of the 5D's 12.8MP.
The 8-15 is just flat tack-sharp wide open and up, all the way to the very edges.
And at 8mm on the 5D, well, it's try 180° all the way around.
The hood is mostly for protection, and the lens cap system isn't as goofy or flimsy as some have made it out to be. It's okay.
Fast focusing, small, light, sharp, flexible, I don't know what else you'd want from a lens. Okay, faster would be nice, but I'll be testing my new Sigma 18-35/1.8 next!
Lee Jay
 Lee Jay's gear list:Lee Jay's gear list
Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III +10 more
Canon EF 8-15mm f/4L Fisheye USM Canon EOS 5D Canon EOS 7D Mark II
dgumshu
dgumshu Veteran Member • Posts: 4,623
Re: Very, very impressed by the Canon 8-15
Where are the pictures???
I've thought about that lens every once in a while.
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
rowlandw Regular Member • Posts: 386
If price were no object would you have sprung for the 11-24 instead?
 rowlandw's gear list:rowlandw's gear list
Olympus C-3020 Zoom Canon PowerShot S100 Canon PowerShot SX40 HS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ70 +5 more
OP Lee Jay Forum Pro • Posts: 56,673
Not even for half the price.
Lee Jay
Interesting - your reason?  The 11-24 is out of my league but I've mulled over getting the 8-15.
Well, I got a 17-40L when I was shooting my 10D. It was my standard zoom (no EF-s at the time). It wasn't very wide so I bought the Sigma 15mm fisheye. When I got the 5D+24-105, that became my standard zoom and the 17-40L became my rectilinear ultrawide. I thought I would never use the fisheye on full-frame. But it didn't work out that way.
As you get wider and wider, it becomes harder and harder to find subjects that don't looks really crazy in the corners when shooting fully rectilinear. I think the cutoff is around 16-18mm before things start to get really tough. Some of the DPReview 5Ds examples, many of which were shot with the 11-24, show this problem. Like this one:
And this one:
Look at the stuff in the top and top corners.
So, I got a little tired of shooting messed up looking shots like those with the 17-40L. Some things are fine, a lot of things aren't. Like this one:
Looks a lot better in fisheye projection, don't you think?
The more I shot with the fisheye, the more I got used to it. The more I got used to it, the more I liked it.
The more I liked it, the more I shot with it.
On the last major vacation I went on, I shot 42% of my shots with the 15mm fisheye on full-frame.
And I even crop and defish a few of them.  With the 8-15, I can do that a lot more, and use it just like a rectilinear ultrawide in the 14-24 range.  I could use it all the way to 11mm equivalent, but like I said, I don't really like those shots, usually.
Lee Jay
Tnx for that - I prefer wide angle and have the Canon 15 fisheye, Canon 17-40, Sigma 8-16 for crop, Rokinon 14 and now the Tamron 15-30 which is good at avoiding distortion and flare, and is very sharp. (One reason I got the Tammy is it has the best handholdability in low light (15mm-IS-f/2.8) and it feels like holding onto a fixed object.) I too thought the wide end of the 11-14 was a bit extreme re: the corner distortion you mention (as well as the cost). Based on your post I'll probably rent the 8-15 for a better look.
On crop, think of it like this (these are approximate):
  • 8mm=8mm rectilinear
  • 9mm=10mm rectilinear
  • 10mm=12mm rectilinear
  • 11mm=14mm rectilinear
  • 12mm=16mm rectilinear
  • 13mm=18mm rectilinear
  • 14mm=20mm rectilinear
  • 15mm=22mm rectilinear
As I said, 16-18mm is about my limit for rectilinear, so I'd try not to fully defish if I'm below 12mm on a crop camera.
Another thing I've been doing a lot lately is using Lightroom's geometric distortion slider in the profile.  You can set it to anything from 0 (no correction) to 200 (twice the nominal correction, which is 100).  I've routinely found that full-frame fisheye shots look best in the 20-70 range which is notably not at 0 and not at 100, which are the two ways most people think of a lens (fisheye or rectilinear).  Yes, some shots are best at full rectilinear, but not at 15mm on full-frame or 9-10mm on crop.
Lee Jay
carnac
carnac Regular Member • Posts: 433
I got one of these lenses as a CPS loaner. I was very impressed. I used it on my 5D mk II. Fun lens. Might have to buy one to have in my bag.
Jim
Canon 8-15 at 8 mm
Canon 8-15 at 15 mm
Jim 'Carnac' Carnahan
 carnac's gear list:carnac's gear list
Canon EOS 5D Mark II Canon EF 50mm f/1.2L USM Canon EF 16-35mm F2.8L II USM Canon EF 24-70mm f/2.8L USM Canon EF 100mm F2.8L Macro IS USM +4 more
Again, thanks for this analysys.  I've never seen this "perspective" on UWA rectilinear vs fisheye and the limitations and compensations for both.
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
Thanks for your user report. Now that I have acquired an EOS M3, and the EF-to-M adapter, I have developed a new interest in this EF Fisheye. EOS M cameras do have rather slow AF when using the adapter, but this Fisheye has a relatively short amount of travel during AF.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
Jay Brookstone Regular Member • Posts: 487
Excellent lens when played to its strengths
Performs well with no surprises, great optical and mechanical quality, and make points like no other.
It's basically an effects lens, not a rectilinear wide-angle substitute.
I've used this lens for sailing regattas to capture the boat crew at work close up with fish-eye distortion adding a sense of intimacy.  Have done the same for corporate clients highlighting close-clustered at-work shots of teams in the heat of the moment brainstorming from both low and high angles.
Peter Read Miller, retired head photographer at Sports Illustrated shot "The Flip", a well known photo of the coin flip by a referee just before a pro football game with this lens and a 1Ds Mark III.  A spectacular full fish-eye circular shot looking up from the ground at the referee and both teams surrounding the coin flip with the stadium skylight in the center.
ed rader Veteran Member • Posts: 9,068
good choice if you shoot crop and FF....
but I just shoot FF and I also need the extra stop.  I spent a little extra (okay double) and got the 14L II instead and kept the sigma 15mm FE.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
MAC Forum Pro • Posts: 18,502
I'm jealous!
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Re: Excellent lens when played to its strengths
I hate that term.  Fisheye is not an effect and I usually shoot my fisheye shots so you can't easily tell it was taken with a fisheye.  And it can be a rectilinear ultrawide substitute.  I just finished comparing the 8-15 at the long end to my 17-40L on full frame.  Very similar.
Lee Jay
Hmmmm....
By its nature, a fish-eye is a specialty effects lens - no avoiding it.  Same as a tilt-and-shift or soft focus lens.  By definition and design it features a specific, repeatable optical distortion, which is an effect, and photographers manipulate and use this distortion to emphasize the subject or an aspect of the subject in interesting ways.
Per your observations, images made with a fish-eye lens can be post processed to make them more rectilinear, but resolution will always be sacrificed in the process.  The wider and more circular the initial image, the poorer the post-processed rectilinear image will be.  Its generally better to start with a good optically rectilinear lens in the first place.
I'm a little surprised that you only value the 8-15mm fish-eye as a post-processed rectilinear lens.
Re: Hmmmm....
No.
I defish less than 1% of my fisheye shots.
And fisheye isn't distortion any more than rectilinear is distortion. Both are projections of a spherical world onto a flat plane and so both introduce a distorted view of that spherical world.
The 8-15 will largely be used as a fisheye because I don't like rectilinear distortion when wide angles of view are used. There are times I'll use it as a wide rectilinear at its long end for 16-18mm equivalent rectilinear images, but I suspect this will be under 5% of its usage.
My fisheye shots are hardly ever used as "effects" shots. If my undefished fisheye shots jump out at you as fisheye images, then I didn't shoot them correctly. Some are obviously fisheye, but that should not be the most obvious thing about the images. Some you can't tell are fisheye at all.
Lee Jay
Glad you enjoy your fisheye - as a fisheye, after all (nt)
nt
ShutterMan West Junior Member • Posts: 26
Re: Hmmmm....
Wow!  Great discussion.
How do you use a fish-eye to make flat pictures, other than Photoshop?  And why?  I know that if you hold the camera level it minimizes distortion with a fish-eye, pretty much.  Are you using a full frame fish-eye? What special "look" are you going for?
I'd love to learn your technique and try it out with my Samyang 14mm.  I haven't had too much luck with it so far - the focus scale does not seem to work and it takes a lot of fiddling to get a good photo, and I'm not there yet.
Thanks for the advice, in advance
