Canon EOS 650D images over exposure (viewfinder vs liveview)
Started May 16, 2015 | Discussions
solaris2k15 Junior Member • Posts: 29
I used to have a Canon 450D with Sigma 17-50mm f:2.8
I was using the camera for family photos and using it in P mode.
I am always shooting RAW since I want to get the best result from my camera. After shooting the photos... I was doing just minor correction in Photoshop. Sometimes I was making no corrections... I was satisfied from the result.
A few days now I sold my 450D and bought 650D (I wanted to have video too)
So I took my camera.... I put almost the same settings I was using with my 450D.
After 2 days I realised the following problem
The images came out over exposured!!! I was surprised since I had to correct ALL the pictures in Photoshop in order to get a correct exposure.
So I started playing with the camera settings to has what was wrong...
As a result.... the camera (when using the viewfinder) gives almost 1 f stop more exposure... the image becomes too bright
I tried shooting with liveview and the camera was able to select correct exposure.
I tried different metering modes but the same problem exists.
The only way to correct the issue is to put -2 in exposure AEB
This corrects my photos but then the liveview becomes too dark!!!!
I googled this issue and find out that many people have this problem...
Any ideas? any fix? I can upload sample images to see what I mean.
By the way... when I use Manual mode I do not have a problem... same image on both viewfinder and liveview.
The problem is that I can not use any AUTO mode
VERY DISSAPOINTED
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
AnthonyL Veteran Member • Posts: 3,686
Check metering mode?
Check what metering mode you are set to.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
OP solaris2k15 Junior Member • Posts: 29
Re: Check metering mode?
I have tried all metering modes... everytime the image I get is over exposured.
I looks like that I can fix this issue if I set the Exposure Comp / AEB at -1 or even more... but then.... liveview pictures become too dark
If I use manual mode the pictures look the same on both...
If I use TV and set the same shutter speed the pictures look the same
If I use AV or P or Auto the pictures using the viewfinder are over exposured... It selects slower shutter speed and the final result is an over exposed image.
I will try an ask Canon Hellas for this issue and if there is a fix available.
Overall... the camera is useless when used in some kind of auto of semi-auto mode
So just to be clear - it doesn't make any difference if you are in Spot metering, or Evaluative etc?
photonius Veteran Member • Posts: 6,895
Re: Canon EOS 650D images over exposure (viewfinder vs liveview)
VERY DISSAPOINTED
I found that exposure metering is something that can be miscalibrated. see old thread:
http://www.dpreview.com/forums/thread/3058780
most "problem" posts are about misfocus, but as my experience shows the exposure metering system can also be off. I think often it's brushed aside as wrong operation, or one simply uses correction, so it's not on people's radar like focus issues.
If you take an image of a grey card (too bad you don't have the old camera anymore) and see what values you get (compared to other body and life view). you can then send it to canon for calibration under warranty.  Check that centering (spot) is also ok, like in my thread.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
