Dimage 7i firmware 1.11u - anyone still have it?
Started May 16, 2015 | Discussions
John Bau Regular Member • Posts: 135
I know this is a stretch... but I have to ask. Last week I picked up a 7i for next to nothing. After some general cleanup, I tested it and it works fine. It has the original 1.00u firmware in it. I looked around and all I could find for updated firmware is the 1.11e version on KM Europe's website. So I tried updating with it but the camera won't take it.
Does anyone have the 1.11u version file that they could email to me?
I had a D7 for years and always like the lens.
Thanks in advance -
Pentax K-m (K2000)
Mikem65d Regular Member • Posts: 319
Re: Dimage 7i firmware 1.11u - anyone still have it?
I have 3 7i's now that are in perfect order and went thru this same search.
Since then i have bought the act-100 and acw-100 converters that came with the firmware update disc's.
The last firmware version for the 7i is on there in 3 versions to update to 1.20 (e,u and j)
there are 3 files that specify your area. The folder you want to use is the NAMERICA version.
Be glad to send them if you want.
I have updated all 3 of mine to this..............it added the 4th option in the menu to select Converter.
 Mikem65d's gear list:Mikem65d's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Canon EOS 50D Olympus E-PL7 +3 more
OP John Bau Regular Member • Posts: 135
Thank you! PM sent.
What does 1.20u offer over 1.11u ?
John Bau wrote:
Thank you! PM sent.
Other than it contains previous updates it also adds a 4th page in the menu to select "converter"..........what this does is allow you to lock the lens barrel at either end with the macro switch and the camera ignores that "macro" has been selected. Not really needed as the lens barrel on the 7i is not loose enough to move.
There was a (attempted rumor i believe) report that by installing version 1.20u that the MF was no longer functioning properly.
I stayed up a bit late last night putting my parts camera (has ugly CCD performance)back together to see if this was true as it has 1.10 still installed, and found that it and the 7i's with the new firmware operate exactly the same..............i am satisfied that the report was simply a rumor.
AF is fast and accurate.
It's worth it to update to 1.20 though as it does contain what 1.11 has.
I know this is not available on line, but those of us that have the software disc that comes with the converter (includes 1.20 for U,J & E) are willing to share.
My son has a new Canon 70D and was blown away at the photo i printed directly (all default settings and no PP) out of my 7i on a Canon pro-100 at 13x19. Detail is incredible which proves to me that all the Pixel Peeping i use to do was a total waste of time as what i see in prints far exceeds what i see on the puter screen.
I believe that Minolta was ahead of their time, but fell victim to the world of fast pace electronics that made the digital camera tech race a brutal environment.
So like you i now enjoy buying these and other Minolta cameras in excellent to new condition for a fraction of what they sold for.............
I installed the 1.20u yesterday (thank you, Mike!) and took a series of indoor stills that reflect my normal useage. Everything worked fine, including manual focus. Autofocus is definitely faster. Image quality is unchanged.
This is my favorite camera for high-res product shots for the web. Fantastic lens and easily-accessible manual controls gives consistently precise results. Amazing how cheaply these things can be bought for.
Even more amazing is the Macro ability.
I use one with the CL49-200 (sometimes 2 stacked) and also with the Hoya closeup lenses.
Unfortunaly the twin light system doesn't go for the low low price the cameras go for, but fun to use.
Sonolta Shooter
Sonolta Shooter Senior Member • Posts: 1,317
Yes, click the link in my reply
You can get it from here along with other stuff.  Worth adding to your bookmarks/favourites for future reference.
Mark
 Sonolta Shooter's gear list:Sonolta Shooter's gear list
Sony Alpha DSLR-A850 Sigma 10-20mm F3.5 EX DC HSM Nik Sharpener Pro Topaz Adjust Topaz Clean +18 more
Re: Yes, click the link in my reply
Thanks, but that is 1.11E, not 1.11U ... I tried it, didn't work. But 1.20U is doin' fine.
Sonolta Shooter
Very strange!
The E = Europe and the U = USA, so I don't see why it can't be installed and work correctly. After all, if Sony A900 owners in the EU downloaded firmware from the USA, it'll still install and work, so your reply to me seems most odd, but I'm you know better than anyone.
Mark
Re: Very strange!
Mark you may be thinking of the A2 which uses the same firmware file for all regions, U, J & E work off the same file.
The 7i however only uses the firmware file that is for the designated region. U needs "U"....J needs "J" etc.
Sony A900 was a much later era in that firmware would be compatiable with all regions just like the Dimage A2 and A200.
the Dimage 7i simply won't recognize any firmware version that doesn't have the matching region designation letter at the end.
neilt3
neilt3 Veteran Member • Posts: 3,008
Mikem65d wrote:
John Bau wrote:
Thank you! PM sent.
Hi Mike , I would appreciate a copy of that disc , I have both converters and the close up dioptre that I use mainly on my A2 and A200 .
I have a few DiMage 7i and D7's kicking about so would like to update it .
It would be good to have all three versions , U,J and E , can you put a copy in my Dropbox account ?
Many thanks , Neil .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
neilt3 wrote:
Mikem65d wrote:
John Bau wrote:
Thank you! PM sent.
Hi Neil,
Absolutely........i'll be back later tonight and will get them in the box.
-mike
neilt3
Thanks Mike .
neilt3 wrote:
Thanks Mike .
Neil,
check your email
neilt3
Mikem65d wrote:
neilt3 wrote:
Thanks Mike .
Neil,
check your email
Got them , cheers .
Neil.
franchar New Member • Posts: 5
I recently picked up a dimage 7i and would like to upgrade my firmware to ver. 1.20 u.
Currently my firmware is ver. 1.10 u.
If anyone would be willing to send me the file I would be grateful.  Or, a link to where it could be found would be super.
Thank you for your time.
 franchar's gear list:franchar's gear list
Nikon Coolpix S3300
neilt3
I have them , somewhere !
When I find it I will let you know .
I don't think it's downloadable anywhere , it certainly not on Minolta's website .
neilt3
I think I've found it my dropbox account .
P.M me your email address and I'll forward it on to you .
I have it, PM me with your email to send it to.
John,
I could not send you a private message because my Account has not yet been approved.
Please send the file for  firmware for the Dimage 7 i vers. 1.20u to:
franchar@isu.edu
Thank you so much for your response.
Chuck Francis
Nikon Coolpix S3300
