NX 18-55mm reverse lens hack.
Started May 12, 2015 | Discussions
ExFisherman New Member • Posts: 5
I like extreme macro photography, and I have the Canon MPE-65 with the macro twin flash. I went the NX system route not too long ago for the compactness and light weight. I got the NX210 1st, then the NX20. Both of these bodies came with 18-55mm lens. I don't need two lenses of the same type, so I turn one of them into an extreme macro lens by reverse mounting it. I also wanted full lens control, so I basically hacked it. It works pretty well, and it's much much lighter than the Canon setup. I can handle it all day without strain on my wrist.
Here are some photos of the hack: https://www.flickr.com/photos/sinh_phun/sets/72157652194830509
Here are some examples of the images taken:https://www.flickr.com/photos/sinh_phun/sets/72157651936224585
Olympus Stylus 1s Samsung NX20 Samsung NX210
nopicleftbehind Forum Member • Posts: 60
Re: NX 18-55mm reverse lens hack.
That is cool but how does it compare to just using a marumi achromat 200 lens filter with that lens?
Also after you mod it, can you attach a clear filter to their rear of that lens?
And does the AF still work afterwards?
 nopicleftbehind's gear list:nopicleftbehind's gear list
Samsung EX2F Fujifilm X100S Samsung NX1000 Samsung NX210 Samsung NX3000 +5 more
PDM Veteran Member • Posts: 3,197
Very nice. One needs the right soldering tools and skill to do that. Want to mod mine for me?
brownie112 Contributing Member • Posts: 502
Damit I came here hoping it would've been an easy hack like 'crack' or 'some extra clicks' and boom you have macro lens.
Soldering and tools look daunting!
 brownie112's gear list:brownie112's gear list
Sony a7 III Sony FE 50mm F1.8 Tamron 28-75mm F2.8 III
OP ExFisherman New Member • Posts: 5
I don't have the Marumi achromat 200 you mentioned.  I did a search, and it's a +5 diopter.  You wont get the magnification any where near the reverse lens method.  Yes, you can attach a 58mm filter to it.  I use the 58mm UV filter, but I took out the glass.  I don't want extra glass.  Auto focus do not work.  It hunts all over the place.  With extreme macro, it's pretty much manual focus.
So, you trust a total stanger to take your lens ?
It does requires some soldering skill.  The spacing is far apart enough that it wont cause solder bridges.  It's not as bad as it looks.
v12nut Regular Member • Posts: 293
What is the type of cable you used for the contacts? is it flat cat5 ? or something a little more flexible?
cheers
cheers
It's CAT5 network cable.  You can use anything that is flexible and have 8 wires.
