Some Thoughts on ISO 50
Started May 11, 2015 | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
My recently acquired DP1s and DP2s have the so-called 'extended ISO'. Sigma warns about less headroom but also states "ISO50 can provide an exceptional result with fine details and lower noise."
So I tried some shots and checked both the raw histograms and the SPP review images. They showed that, not surprising, the selection of ISO 50 alters the metering so that, for 0.0 EV, you have to set double the exposure than for ISO 100. All well and good. Just as ISO 200 forces half the exposure than for ISO 100.
There is a subtle difference in SPP, though. The review image for a ISO 50 shot is twice as bright as an ISO 100 shot. But an ISO 100 shot is not twice as bright as an ISO 200 shot.
I see eyes glazing over
To me, I see absolutely no difference between shooting a scene at ISO 50 and shooting at ISO 100 + 1 EV both done with appropriate exposure compensation needed by that scene. Both methods produce the same raw histogram (more or less).
So I'm wondering where "an exceptional result with fine details and lower noise" comes from.
Does anyone here habitually use ISO 50 where possible and do they find it noticeably better?
Caveat: I'm talking about non-AFE models here.
Pedantry is not a felony.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Sigma DP1s Sigma DP2s
SigmaChrome Forum Pro • Posts: 15,728
Re: Some Thoughts on ISO 50
Yes.
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
(unknown member) Senior Member • Posts: 1,857
As you say, you can overexpose ISO 100 by one stop, or use ISO 50. Both produce cleaner files compared to ISO 100 without exposure correction. And cleaner files means more detailed files.
xpatUSA
OP xpatUSA Forum Pro • Posts: 23,017
SigmaChrome wrote:
Yes.
Ta.
Ted
xpatUSA
Ah, I see. Less noise by means of "pushing" the exposure resulting in a) brighter shadows and b) more tones or levels in the shot. And, I suppose, less NR in post then leads to more detail or micro-contrast.
Ted
mike earussi Veteran Member • Posts: 9,440
Because there is no AFE (analog front end) in the older SDs and DPs, the iso setting is software driven (i.e. SPP reads the iso setting and adjusts the exposure on your monitor accordingly). AFE was added in the SD15 and later DPs resulting in the iso setting telling the camera to actually amplify the RAW signal before recording to the SD card. This had the effect of slightly lowering the noise at higher ISOs but at the expense of lowering the overall DR, a tradeoff not everyone was happy about.
And to further add to the confusion the Merrills don't have AFE and the Quattros do.
IMHO, the SD14 at iso 50 produces the most noise free skies of any Sigma camera. And if you can get the color balance correct, can produce better looking images than the SD15.
http://www.pbase.com/mikeearussi/sd14_iso_50
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art +2 more
xpatUSA
mike earussi wrote:
Because there is no AFE (analog front end) in the older SDs and DPs, the ISO setting is software driven (i.e. SPP reads the ISO setting and adjusts the exposure on your monitor accordingly).
One difference I found is that, ISO 50 shots do not have their exposure on the monitor adjusted - as I tried to explain in the OP. In other words, the adjustment factor for ISO 100 is 1, for 200 is 2, etc but, for ISO 50, the adjustment factor remains at 1, not 0.5 which one might have expected.
AFE was added in the SD15 and later DPs resulting in the ISO setting telling the camera to actually amplify the [sensor] signal before recording to the SD card. This had the effect of slightly lowering the noise at higher ISOs but at the expense of lowering the overall DR, a trade-off that not everyone was happy about.
And to further add to the confusion, the Merrills don't have AFE and the Quattros do.
Excellent shots there, of course . . . I blame the photographer, not the camera settings
Ted
Nice shots there, of course. I blame the photographer, not the camera settings
The shots aren't meant to be artistic, of course, but they do demonstrate the noise free skies the SD14 is capable of producing at iso 50.
xpatUSA
Yes, did notice the skies, Mike. I do like the SD14 in spite of what "they" say. Sold my first one as fast as I could (was going to shoot JPEGs with it at the time). But they do grow on you.
Ted
BarrytheB Veteran Member • Posts: 3,616
Big advantage of ISO 50...
Longer shutter times for capturing motion along with low noise.
Waterfalls, leaf motion blur etc.
Barry Byrd
http://www.pbase.com/barryb
http://www.pbase.com/sigmadslr
'Liking it ain't required'
Gary Hale
1952-2008
 BarrytheB's gear list:BarrytheB's gear list
Sigma DP1 Sigma dp3 Quattro Sigma SD9 Sigma SD14 Sigma SD15 +8 more
target5
target5 Contributing Member • Posts: 813
The ISO 50 is amazing I've used it many times on my previous SD14 and after on the SD15.
 target5's gear list:target5's gear list
Sigma DP2 Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD15 +4 more
xpatUSA
Re: Big advantage of ISO 50...
Yes, but the same longer shutter time can be set in ISO 100 and the resulting image is the same for a given scene and lighting.
I do see the point, though, if one's procedure is to simply adjust the ISO and then shoot with the same metering, e.g. zero on the meter with the same compensation.
The oft-mentioned low noise comes from the higher exposure, does it not? The same as claimed for ETTR?
Ted
For the SD14, since it does not have the AFE, that's correct.
Yes, the greater the signal the lower the noise.
Ted
