Nice little camera but build quality is questionable.
Started May 9, 2015 | User reviews
Glick1 Regular Member • Posts: 277
Re: Calm Down??
Someone expresses their observations about a product and some seem to take it very personal.
Just because the product you own doesn't exhibit the same abnormalities doesn't mean it is an impossibility.
I merely brought to light what is common on all these types of boards and will continue to be so. Individuals that own a product seem to take it personally when someone expresses a negative opinion or points out a fault.
Quite frankly, I don't get it, but it is what it is.
 Glick1's gear list:Glick1's gear list
Canon PowerShot S100 Canon PowerShot ELPH 330 HS Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
blue moose
blue moose Forum Member • Posts: 81
Re: Calm Down??
That happens but I don't think it was the case here.
AdamT
AdamT Forum Pro • Posts: 62,285
Re: Nice little camera but build quality is questionable.
1. The rubber grip is peeling already and the rubber eyecup falls off very easily (I lost mine).
Neither here - the cup is the same as the 550D , I had one do 3 years without falling off
2. The AF, while generally very good, is nothing special and the outer AF points are unusable with fast lenses.
because they`re line sensors - treat this as a centre point only camera
3. The controls are lacking
it`s a "Rebel" class camera what do you expect - a pocket 7D ?
4. The dynamic range of these sensors is rediculous. Period.
it`s OK but the sensor is dated - I can recover quite a lot in C1
6. The battery life is pretty bad.
over 600 shots and still going seems pretty good to me for an EOS-M battery
7. SD card slot is in the batter compartment (some decisions were to be made for the size to stay small)
most cams have this - 90% of Sonys and Panasonics including high end cams - I don`t like it either but the 100D is all about size
8. Dust gets easily on the sensoe and someteimes cannot be cleaned, but I swap lenses very often.
never had that - or with the 550D before it
9. No way to turn off exposure simulation - a real pain for studio work!
use the damn OVF !!
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
ThrillaMozilla Veteran Member • Posts: 7,681
Can we just let this thread drop?  The OP has made his points and others have disagreed.  I think all points of view have been aired at least once.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
