I'm not convinced that Sigma actually wants to sell cameras . .
Started May 7, 2015 | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
. . well after a couple of beers, I'm beginning to wonder!
OK, they take nice pictures but, after playing with my newly acquired DP1s and DP2s, I find it quite cynical that the DP1s comes with a DP1 manual and a scruffy fold-up sheet in a hundred different languages with the English bit spread across several folds to tell us the differences between the DP1s and it's predecessor.
But then, examining a raw histogram, I was amazed to see that the maximum raw level attainable with these two cameras is around 2,300 !!
I mean, the SD9 raw values can be up in the 10,000s the SD10 even higher, then the SD14 more like 9,000 and the SD1M more like a sane 4070 - which almost bears a resemblance to the ADCs output. God knows what the Quattro puts out, something different, I'm sure.
With scaling variations like this, and the X3F format changing with each new model, it is small wonder that so few converter providers have anything to do Sigma's products.
I actually bought these two cameras thinking they would be no different to the SD14 (same sensor, right?). Ha, how naïve can one get?!!
A storm in a tea-cup, you might say - but every time I open an X3F in RawDigger, I now have to set the over/under exposure levels to suit the stupid camera used. Ridiculous!
Not a happy camper at all.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
richard stone Veteran Member • Posts: 3,472
Re: I'm not convinced that Sigma actually wants to sell cameras . .
I certainly am not privy to any internal or even external discussions by Sigma people, but I doubt if Sigma thought that the DP series would be the "hit" that it turned into. For them. In relative terms. As I see it, Sigma wanted to get people to buy a Foveon camera for cheap, as an experiment, and get the system and sensor exposed as a way to get more people aware of the technology and the results. And as a way to show off the quality of their lenses.
It worked. To the point where now the SD1 looks a little unnecessary.
But my recollection at the time was that Sigma was not going to invest a fortune into the DP series. It was supposed to be modestly priced. It was not designed to last for many years or suit all needs. It is a fragile, unexpected classic.
I can understand the frustration with the limitations of the camera and "system." But it didn't happen in a vacuum.
Richard
 richard stone's gear list:richard stone's gear list
Sigma SD10 Sigma sd Quattro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 30mm F1.4 DC HSM Art
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Ted,
Maye you had too many beers. What difference do the values make if the cameras produce decent photos and they all do. Getting bogged down with theory and figures never produced an image and never will.But then. I suppose we all have our own particular interests in the photographic world.
Having said that I wonder if any other camera & sensor type is so endlessly analysed as the various Foveons are.
SPP is a good converter for all X3F files but it would be useful if the later cameras RAW files could be opened in e.g. ACR as they could be up to the SD15. (I know you do not like Adobe). Handy at times and faster than SPP especially SPP 6.2.1 which is excellent but slow especially with SD1 & Quattro files.
Get happy again soon,it's better for all round health.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Tom Zimmer
Tom Zimmer Contributing Member • Posts: 627
Hmm.. I will try to remember to take a look at some of my old "original" DP2 X3F files to see if they show the same limit you are seeing.
Tom Zimmer
http://photobubba.com/
Sigma DP1 Quattro, Fuji X-T1, X-E1, X-M1
And my old friends - Sigma DP2, SD10, SD14
jrtrent Veteran Member • Posts: 6,495
What is a "raw level"?  I recently bought a refurbished DP2s from Sigma and am quite pleased with both it and the software it uses (Sigma Photo Pro 4.2), but have no idea what these numbers mean that you posted for the various cameras.
Tom Zimmer
Ok, I looked at the RAW files from my DP2, and a bit over 2000 appears to be the limit. Sigma is probably using 11 bits of a 12 bit DAC for intensity, or perhaps the DAC is signed instead of unsigned. Though I can't imagine why they would want to use a signed DAC for intensity. Cost?
DAC = Digital to Analog Converter (not for you Ted, but for anyone else that isn't familiar with the term DAC.
Tom Zimmer
xpatUSA
OP xpatUSA Forum Pro • Posts: 23,017
Yes, I will try to explain. When we take a raw shot, which you can do by selecting RAW from the Qs menu on the camera, the in-camera firmware takes all the sensor output values or 'levels', does a bit of scaling and writes the shot as a file of type X3F onto the memory card. In that file, the image data part is called the 'raw' data because nothing has been done to it like applying the white balance and converting the 'raw' data into a JPEG image.
Each sensor pixel location in an image has three 'raw' values or levels, one for each layer. For simplicity, we can say that, in-camera, the level for each layer can be between 0 and 4095 (12 bits), no less and no more. But, the camera does a bit more with that data, including some scaling and writes it to the card so as to fit into 16bits which computers are more comfortable with.
If you look at these numbers with a utility program, you can learn a lot more about how well the camera is exposing the shot - as opposed  to what the color-picker says in SPP 4.2. The trouble is that these ranges of levels from min to max are written to the card differently for just about every camera model that Sigma makes.
So "exposing to the right" means aiming for different raw numbers depending on what camera you're shooting. Aiming for good raw numbers because the in-camera histogram is not always the best guide for a good exposure. So, reasonable goals for your DP2s when opened in RawDigger should show levels (highs) of, say,no more than 2300. But reasonable goals for my SD14 might be around 7,000. And an SD1M, around 4,000.
I'm enjoying my DP2s that I received this very week.
Pedantry is not a felony.
Ted
xpatUSA
Yep, I shot the sky and got 2293, 2302, 2295 and another scene with specular highlights gave 2323, 2320 and 2340.
Laid yourself wide open to the circling sharks, there, Tom
Who'll be first in, I wonder?
Ted
goblin
goblin Veteran Member • Posts: 3,752
xpatUSA wrote:
...reasonable goals for my SD14 might be around 7,000. And an SD1M, around 4,000.
Thanks Ted
How does that translate for users ? Are those numbers an apples for apples comparison (Oy Caramba ! That would mean that compared to the SD1m the SD14 is 1.75 times more... errr... well, it's a bigger number, so it must be more... more... more what actually ? It's more, so it's better, right ??? ), or are those only values to keep in mind when setting each specific camera to obtain results specific to said camera ?
 goblin's gear list:goblin's gear list
Ricoh GXR P10 28-300mm F3.5-5.6 VC Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +73 more
xpatUSA
goblin wrote:
Thanks Ted
Fear not, it only has meaning for pedants like myself. In more sane environs, the camera manufacturers tend to make the so-called raw-data equal to the analog-to-digital converter output which, in turn, is about the same as sensor dark to sensor saturated. So, with a 12 bit converter we could reasonably expect a saturated sensor to cause a raw value of 2^12-1 = 4095. Over-simplified of course, for example, Canon adds 1000 or so to their raw data so that would be 5095. With Sigma, it's just a crap-shoot
For your purposes, it really matters little how the raw data is scaled because SPP makes sure that all you'll see is 0-255 on the color picker and the histogram will be of already-converted raw data into the color space of your choice.
Ted
I appreciate your explanation.  I'm afraid I don't understand it, but I do appreciate it.  Have to admit I'm not familiar with SPP's color picker either, nor have I used the camera's histogram.  The camera's metering system works pretty well, and I also enjoy my uncle's old incident light meter.
Tom Zimmer
Ok, Ted, thank you for the "off line" correction. Smarty me, it's A2D (Analog to Digital converter), not DAC. That's what I get from being away from electronics for so long.
Tom Zimmer
christom
christom Veteran Member • Posts: 3,518
What do you mean by the term "raw values?"
Wouldn't that be the case with any camera? Setting different levels is the essence of shooting in RAW.
Ted
If you troll or flame, I stop responding. Get back on topic, I continue responding. Forums are for freely discussing and debating topics. Don't take it personal if I disagree with you.
christom
I Say Just Enjoy Your Camera, While You Can
I come from a very technical background and I'm shaking my head at the moment. No offense intended but why are you focused on such irrelevancies? I say learn your camera and properly expose your images and move on. Photography isn't rocket science. Sigma cameras take great images. Enjoy your camera, while you still can.
xpatUSA
No problem, Tom.
Ted
Scottelly
Scottelly Forum Pro • Posts: 18,028
I hear that car companies actually use different engines in their cars too.
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
lelf
lelf Junior Member • Posts: 41
I've even heard that other camera producers have been putting different sensors in their cameras since at least 2002!
Roland Karlsson Forum Pro • Posts: 30,033
So, it is an 11.1 bit ADC
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
AGN AGN Regular Member • Posts: 139
Hi Ted, A question for the aside, where did you manage to purchase your new DPs?
xpatUSA
The DP1s was brand new, got it on eBay, see here:
http://www.ebay.com/itm/301601810857
Sears has some for a few dollars more:
http://www.sears.com/sigma-dp1x-14mp-foveon-cmos-sensor-digital-camera/p-SPM12308971419?sid=IDx20140425xECNMPCAM07&sdc_id=1431301576z734305z3e073b0a29342z
I've also seen them up for $399, can't remember where.
The DP2s was a used item on eBay from Japan.
Still getting used to both - a long process because Sigma changed all the controls on the DP2s
Ted
