Crazy to sell the Olympus 12-40mm?!
Started May 6, 2015 | Discussions
shamhead Forum Member • Posts: 63
I just recently upgraded from a GM1 and GX7 to the new E-M5 mkii which I really love. The weather sealing, big EVF, centre placement of VF (stronger left eye), 5 axis stabilisation, great controls,all in all it is an excellent camera.
I opted for a kit with the 12-40mm 2.8, which is built like a tank and seems like a great lens however the zoom ring is quite heavy, the weight and general feeling of bulk is a bit off putting in the operation. It's also quite short in FL compared to the Panasonic 14-140 it replaced.
I know this may make some here laugh, it is a pro level 2.8 zoom after all! But coming from the tiny GM1 to this is taking some getting used to and having the 14-140mm as a sunny day walkabout was pretty liberating. Something I didn't realise until I sold it.
I also have the Oly 25mm + 45mm, both of which are brilliant.
So the question is, do you think I should stick it out with the 12-40 and give it another month of use? I've ordered the Olympus version of the superzoom but cannot afford to keep both, was going to give them both some consideration for a while and see what I prefer.
Am I mad to sell the 12-40? Just wanted to hear of others preferred setups, with a leaning toward light, compactness and ease of use. Others who own the 12-40 with a smaller m43 camera, do you not find it very front heavy?
Was thinking the 14-150 would be great for outdoors walks outs, and the tiny primes for indoor, street, portrait and other specialist areas.
Anyhow, first world problems I suppose! Oh and here are a few shots with the new setup...
Cheers!
Olympus 12-40mm F2.8 Pro Olympus E-M5 II Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Re: Crazy to sell the Olympus 12-40mm?!
Your choice.  If the new weather-sealed superzoom suits you better, then go for it.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
Najib Contributing Member • Posts: 701
It's a great lens, but...
I like my primes. 12-40 is fabulous, but even at 2.8 with a m43 sensor, the DOF doesn't satisfy me, so I usually always end up shooting with primes. The 25/1.8 is my most used lens. Plus, the 25/45 make a great combo, as they are tiny. Afterall, that's the whole point of the m43 system. If you want versatility, then yeah, the 12-40 is unbeatable. I just find my best shots are dont with primes.
 Najib's gear list:Najib's gear list
Canon EOS 7D Mark II
BHD2
BHD2 Regular Member • Posts: 104
9
Yes.
 BHD2's gear list:BHD2's gear list
Ricoh GR III Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
I don't think it's crazy.  The Panasonic 12-35mm f/2.8 is a lighter alternative with OIS that you could look into as a replacement if you want a similar lens.  It's got better colors and contrast than the Olympus 12-40mm.  The two lenses have their own strengths and weaknesses, but if you want smaller and lighter and more compatible with Panasonic bodies, I'd go with the 12-35mm.
Other than that, if you are happy with your primes and other zoom lenses, there's certainly no NEED for another lens--it's all about your personal use habits and preferences.  That's why it's great that the micro four thirds system has so many lens options!  Something for everyone.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
(unknown member) Forum Pro • Posts: 11,837
I saw the two Olympus 2.8 zooms live for the first time the other day. I would not swap them for my two Lumix 2.8 lenses as the Olympus lenses are too big for my tastes. You lose all the advantages of M43.
Panasonic were far more intelligent in their design choices, less range, but two very compact lenses.
http://nigelvoak.blogspot.it/
Yeah, I've tested both on my camera in a local store, along with taking sample photographs and doing lots of reading on-line. The Panasonic lens is noticeably smaller and lighter when on the camera. It feels more balanced on E-M1--I can't tell for other bodies. I was set to get the Panasonic 12-35mm for various reasons but ended up with a 12-40mm because of a really great deal. I still have a lot of respect for the 12-35mm, however, and would not hesitate to use either lens (maybe even prefer the 12-35mm).
That said, both lenses are not heavy in DSLR terms.  I'm currently using a four thirds Panasonic 14-150mm, and that weighs as much as my Nikkor 18-200mm VR did, when adding the adapter to m43.  Still quite manageable.  Very heavy when compared to the tiny pancake zooms, but not heavy in absolute interchangeable lens camera terms.
john isaacs Veteran Member • Posts: 8,444
Cheers!
You obviously don't want or need the 12-40, so you should sell it and stick with the 14-150.
Hithertoo Senior Member • Posts: 1,841
Hi,
The weight of the 12-40 when it's attached to a body never satisfied me, it felt like a small DSLR like a Canon 100D or Nikon D3300 and not like a marvel any longer to the ingeniousness of a small and light camera. The depth of field control at F/2.8 on Micro Four Thirds has never satisfied me either. I shoot with the 12mm F/2 and 20mm F/1.7 primarily as a result.
If its not doing it for you then feel free to change something, buy another prime, or perhaps one of the light weight zooms such as the Olympus 40-150 F/4-F/5.6, or alternatively one of the 14-140 or 14-150 lenses from Panasonic, Olympus or Tokina.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
OP shamhead Forum Member • Posts: 63
Re: It's a great lens, but...
This is kind of the way I'm feeling, the primes are just so good in situations where I would try to use the new lens, then get the feeling I'd prefer the primes in terms of handling, and greater dof control. With outdoors and landscapes I'm not as bothered, and the versatility of the super zoom would be nice.
A 17mm / 25mm / 45mm in the bag would be nice!
john isaacs wrote:!
You may be right, I'm possibility just in need of validating my thoughts but it's good to hear others opinions and setups. See if it gives me any other ideas.
MOD Tom Caldwell Forum Pro • Posts: 46,354
Crazy is as crazy does ...
Why did you quit the GM1?
Tom Caldwell
tgutgu Veteran Member • Posts: 4,134
The Image quality of the O 2.8/12-40mm is mostly better than the primes in its range, so I would not consider selling it. Especially compared to any of the super zooms, the IQ extraordinary. Therefore I switched from a one walk around super zoom strategy to a two zoom strategy with better range and much better IQ.
As such my most favorite setup is currently the combination O 2.8/12-40mm plus P 45-175mm.
Thomas
 tgutgu's gear list:tgutgu's gear list
Panasonic Lumix DMC-GX8 Olympus E-PL7 Olympus E-M1 II Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +31 more
Alien from Mars
Alien from Mars Contributing Member • Posts: 580
shamhead wrote:
john isaacs wrote:!
Nothing crazy about it.
I've had 12-40 for a couple of weeks then sent it back. For me it's defeating the very idea of the m43 - compact and lightweight one hand operated camera with a good IQ. But that's my understanding of the system and many think differently.
The fact that the lens was decentered only made my decision easier. Also I was kind of shocked by the level of vignetting on this "pro" lens.
So no, you are not alone and the 12-40 is not a must-have miracle for everyone.
 Alien from Mars's gear list:Alien from Mars's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
bradevans
bradevans Senior Member • Posts: 1,029
  • When the light is good the lenses even out - you generally need to stop down somewhat anyway, and there goes one of the main advantages (speed).
I have the Panny 14-140 II and its pretty tough to beat - if there is enough light. Of course, if you keep going down that slope, you'll end up with a fixed lens superzoom (ie FZ1000).
So get those primes out in low light and you'll appreciate them more. Or scenes where a blurred background adds to the photo
I'm on the fence with this lens, and I really like the Manual focus 'clutch'.  But its not the smallest and its not the cheapest...
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
The same in dslr would still be quite a bit bigger.
I used to have a Canon 450D (a "small" dslr) with the 17-55 f/2.8 IS lens. I recently held a 450D again. I can definitely tell you: the E-M5 with 12-40 lens is a *lot* smaller than the 450D with a similar lens.
The superzoom lenses are not all that much smaller and lighter than the 12-40. They do give you a lot more reach obviously. Which is best is mostly a matter of what you need most: the low light capabilities of the f/2.8 or the reach of a zoom going to 150mm.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
About the GM1, Started missing the view finder, and couldn't get truly comfortable with the one on my GX7 never felt comfortable, I'm left eye dominant so the range finder left side VF is kind of awkward. Tried the Olympus omd in the shop and was hooked.
Kind of wished I saved a bit more and kept hold of the GM1 though! Great little thing.
That is an interesting setup with the 12-40 and 40-175. I will certainly give the 12-40 another few weeks and see how I get on.
Re: The same in dslr would still be quite a bit bigger.
I had exactly the same setup a few years ago and yes I understand it's still a heck of a lot more bulk than the Olympus. I guess it's coming from the gm1, you tend to expect miracles!
Maybe, but this comment is rather facile in nature... There is nothing inherently wrong with most of the primes in terms of image quality except for the Olympus 17mm pancake and the primes by and large are 1 to 1.5 stops faster in terms of light gather and depth of field.
The 12-40 F/1.28 can't do F/1.7 and so it comes up short for a lot of users. You can stop down a lens, but you can't stop a lens up.
