Distortion Correction ALWAYS enabled in NX1 + 16-50S
Started May 5, 2015 | Discussions
ARSPR Regular Member • Posts: 385
Pretty much what the title says. Processing my very first SRWs in Lightroom and comparing them against the in-camera JPGs I've just noticed that NX1 + 16-50S always performs distortion correction over JPGs...
Samsung, this is a pro/semi-pro camera + lens package. THIS IS NOT SERIOUS.
(In fact I had already noticed that the Distortion Correct field was grayed out at "On" in the camera menu, but I just thought it didn't worked because of whatever reason I hadn't investigated yet).
On the other hand, with my cheap 50-200 lens, I can turn Distortion Correction on/off...
Samsung, do you really think this is a coherent design?
 ARSPR's gear list:ARSPR's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Samsung 16-50mm F2.0-2.8 Samsung NX 50-200mm F4-5.6 OIS Samsung NX1
wpstl Senior Member • Posts: 1,251
Re: Distortion Correction ALWAYS enabled in NX1 + 16-50S
If it's "not serious" why do you seem so upset about it?
The ability to turn Distortion Control on or off is dependent on the lens, not the camera. Based on my experiences, the feature is disabled/greyed out for any wide angle prime or zoom (12-24) or any zoom that has wide capabilities (the 16-50 s and 16-50 PZ etc.) You can adjust it for "normal" and telephotos like the 30mm, the 50-200 etc.
What reason do you have for wanting distortion turned off?
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
JGlimmer Forum Member • Posts: 59
Honest question: Why would someone argue in favor of UI limitations?
 JGlimmer's gear list:JGlimmer's gear list
Canon EOS 60D Panasonic Lumix DMC-G6 Samsung NX1 Canon EF 50mm F1.4 USM Sigma 18-35mm F1.8 DC HSM Art +6 more
OP ARSPR Regular Member • Posts: 385
Because any kind if correction (noise, distortion, whatever) kills detail. So the final user should retain control. Specially in the "pro" line of products, more over when it's already offered in the "amateurish" one, don't you think?
(And I really think that you've misunderstood the particular meaning of the word "serious" in my former sentence...)
Please show me where in my post I argued for it.
"Kills" is a strong word. Hyperbole. Please show me a review of the NX1 or the 16-50 S lens where the reviewer mentions the detail being "killed" by the distortion correction. Or examples using your own images.
I understood it. I was commenting on your poorly worded and overly dramatic post.
jennyrae Senior Member • Posts: 2,690
I agree. Poor choice of words.
Ceedjay Regular Member • Posts: 183
Hi
Question is "is it disabled when shooting RAW ?"
If it Is then thats alright.
I discovered that after buying my 12-24 a few weeks ago and it has an effect on the FOV. With distortion correctes You get the FOV of a 14mm more than a 12.
Cheers
Jay
 Ceedjay's gear list:Ceedjay's gear list
Samsung WB150F Samsung NX1000 Samsung NX30 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +2 more
Raws are not corrected but lightroom seems hell bent to apply any and all corrections it knows for any lens it has in its database. To check use something different like raw therapee or raw digger or darktable...
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Is it corrected with ANY raw developer?
Is it corrected in LR when converting the raw to dng, first?
We have to understand if the issue is the camera or LR.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
Hi !
I'll have a look in DxO when shooting RAW with the 12-24mm and compare the FOV with an OOC Jpeg. I'll also have a look if the option is not greyed out when you choose RAW in the camera.
Anyway, this should be "ungreyed" for all lenses, whether shooting RAW or JPEG. The user should have the possibility to choose. I guess this should be doable via a firmware revision.
I also discovered it is the same with the 20-50 : shoot JPEG, distortion correction is greyed out and enabled by default. On the 45, you can choose (but there is not that much distortion).
Cheers.
Jay
tecnoworld
I agree. The option should be...an option!
Hi
Cheers
Jay
It is. It's the same as I mentioned above...wide angle primes and wide angle zooms.
wpstl wrote:
Hi
Cheers
Jay
Hi !
So, it should be possible to have the option available for Jpegs too.
If Samsung reads us......firmware revision
Cheers
Jay
Ceedjay wrote:
wpstl wrote:
Hi
Cheers
Jay
Hi !
Cheers
Jay
I think you misunderstood...The option is "disabled" greyed out for RAW files as well as jpegs.
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
FWIW; for a prime like the 16mm it's always greyed out (set to ON), but if I want to use the whole uncorrected image I open the dng file in Faststone, save as a tiff and then work on that it LR.
It's a workaround in this case, but would be nice to have that control/option in LR from the start.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
The Straw Man Regular Member • Posts: 334
I'm no LR expert, but with LR5 I have to enable profile corrections on individual images with a checkbox, then I select lenses from the make/model/profile drop down menus. Is LR doing anything else beyond that?
 The Straw Man's gear list:The Straw Man's gear list
Samsung NX1 Sony a7R II +1 more
A summary reply to all the posts here.
  • Yes, I agree that I've been a bit over-expressive with my vocabulary. It's not a life-or-death matter...
  • But I still think it's something completely incomprehensible about Samsung decision. I mean, you give the option to turn on/off the distortion correction in a "cheap amateurish" lens (50-200), but you don't give that option with a prime lens (16-50S). Are you nuts?
  • (A bit offtopic but nevertheless... I've seen a quite a number of reviews, dpreview's one as example, where the reviewer complain about NX1 not offering any kind of control about the applied level of noise reduction, which can also "kill" (decrease) available detail. But IIRC nobody has complaint about distortion being on all the time... Aren't they similar processes?)
  • Samsung is (IMO) absurd about the Distortion Correction decision. But they are not stupid (obviously). SRWs are free from this correction and they MUST remain in this way. The Distortion Correction, (like a future hypothetical NR setting), should be only applied to JPGs. If you shoot in RAW is because you want the MAXIMUM and UNADULTERATED information the sensor has received in order to perform whichever post-processing you desire. Applying any kind of in-camera correction to RAW data would be absolutely nonsense. Either shoot in JPG instead, or perform that correction in your post-process.
Kinson Wong
Kinson Wong Forum Member • Posts: 81
in mirrorless market, seems distortion correction is part of lens design, especially in wideangle and m43 system. it is not good approach but is a trend. m43 and sony do it with no options.
LR 6.0 still doesn't offer profiles for Samsung S Lenses...
You have to select the lens profile and then you can correct independently its distortion and its vignetting with a percentage slider. (So if you want you can still set them to 0%). (The profile is supposed to catch all the zoom range of the lens so you can forget about needing either pincushion or barrel distortion correction values depending of the used focal length of the shot).
The problem is that even LR 6.0 doesn't offer but a small set of Samsung lenses... And the S ones are not included.
But I suppose the culprit here is Adobe, not Samsung. I also feel a bit of disappointment because, given the time the S lens have been available in the market, Adobe has not profiled them yet...
