Macro shots with fuji XA1 camera using fuji 35mm lens and Raynox 250 macro lens
Started May 4, 2015 | Discussions
paulholmes Regular Member • Posts: 114
7
hoverfly
Green Shieldbug
Small wild plant frozen
Those of you who like macro photography should check out the raynox 250 macro lens its very cheap and the results when used with fuji 35mm lens are excellent i think you will agree i an sure it would also have great effect with the fuji 18mm lens it also works on all the zoom lenses.
Here are some samples shot between ISO 800 ans ISO 1600
This fly is about the size of a matchstick head
Fujifilm X-A1
baobob
baobob Forum Pro • Posts: 18,248
Re: Macro shots with fuji XA1 camera using fuji 35mm lens and Raynox 250 macro lens
Wonderful dreaming shots!!
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Stoneh Ray
Stoneh Ray Regular Member • Posts: 130
These look amazing. Well done. I'm very interested in this combo too as I have the 35mm. Will auto focus still work? And what is the magnification ratio?
 Stoneh Ray's gear list:Stoneh Ray's gear list
Canon EOS 5D Mark III Fujifilm X-M1 Panasonic Lumix DC-GX9 Fujifilm X-H1 Fujifilm X-T3
OP paulholmes Regular Member • Posts: 114
Hi stoneh thanks.
Auto focus works perfectly the magnification is 2.5x these shots are cropped a bit bit you still end up with a big file the raynox is for sale in B&H photo for 74 dollars I highly recommend it
tri x
tri x Contributing Member • Posts: 756
Top shots Paul, number 4 is just fantastic  as a stand alone image.
Cheers John
https://www.flickr.com/photos/40629145@N02/
 tri x's gear list:tri x's gear list
Fujifilm X100V Sony a7R III OM-1 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 90mm F2.8 macro +3 more
jrk
jrk Veteran Member • Posts: 3,401
Here's another Raynox product for macro photography. A bit more expensive but produces outstanding results!
http://www.bhphotovideo.com/c/search?Ntt=raynox+dcr-5230pro&N=0&InitialSearch=yes&sts=ps
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X100F Fujifilm X-T3 Voigtlander 35mm F1.4 Nokton Fujifilm XF 60mm F2.4 R Macro +14 more
