Portrait lens advice
Started May 4, 2015 | Questions
FD Contributing Member • Posts: 549
Re: Portrait lens advice
ktownbill wrote:
I googled "portrait types" and found several that showed the different types of portraits. Click on the link and dispute it if you wish.
When I studied photography in college (1973 most likely before you were born) I was given an assignment to take 5 different types of portraits. I don't know where you got your definition from.
http://artpaintingartist.org/types-of-portraits/
Thanks for the link.
I’m MY 1958, Bill.
and looking at your gallery you missed some lessons way back in 1973
But hey, you started
Then on topic.
google ”portraits” and you get head shots and/or head shots+, at least in my part of the world.
A lens 135 or larger is the way to go on FF.
You know it, I know it, but a lot of people think they can make decent close portraits with a 50mm because of the wonderful bokeh.
This link http://oneslidephotography.com/the-best-lens-for-portrait-photography/ was just to show
people wat a lens and distance to a face can do.
That's all
Cheers.
FD
 FD's gear list:FD's gear list
Canon PowerShot S110 Canon EOS 5DS Canon EOS Rebel SL2 Canon EOS M100 Canon EOS R +24 more
Great Bustard Forum Pro • Posts: 45,641
Consider a macro lens.
3tagebart wrote:
Hi forum,
I like to ask you people's opinion regarding a possible lens purchase of mine. I quite recently bought an EOS 6D as addition to my old trusty EOS 40D. My standard zoom is the 24-70mm f4 I also own a 85mm f1.8 and a 70-200mm f4.
On the 40D I really loved the 85mm giving me an equivalent field of view of a 135mm on FF. The 85mm still is a great portrait lens for bust portraits but i do miss a dedicated lens for head shots. Of course I can use my 70-200mm f4 for that purpose and the results are really nice.
Since the G.A.S.-bug bit me lately I was wondering if a 135mm f2 would be able to produce some even more pleasing (bokehlisious) head shots.
To cut to the chase: Have you personally felt that a 135mm f2 is a sensible addition to the existing 70-200mm f4 or is it plain overkill?
I know it's all about personal taste in the end, nevertheless I would appreciate some shared experiences. Thank you.
David
The Tamron 90 / 2.8 VC, Canon 100 / 2.8L IS, Sigma 105 / 2.8 OS, and Sigma 150 / 2.8 OS macro lenses will let you frame very tightly (if tight framing is something you're looking for) and have IS. The disadvantage is that they're a stop slower than the 135 / 2L, but I think around the same size and weight (the 150 / 2.8 OS is larger and heavier, however).
Here are a few examples with the non-OS Sigma 150 / 2.8 macro on a 5D:
150mm f/4:
150mm f/5.6:
Macros are also good for full body group portraits
150mm f/2.8:
cybergeek Regular Member • Posts: 287
The 135 F2 is pure magic. It's my favorite portrait lens. If you buy it I doubt you would ever sell it. I have the 24-70 mk II, the 70-200 2.8 ML II, the 16-35 F2.8 MK II, 10-22 EFS, 100-400 MK I, 24-105, and the 135 F2 has won me many awards in competitions, and never fails to amaze me.
Just get it!
Enough said!
Great shots !
FD
Thanks!
Tom
treasuringhearts
treasuringhearts New Member • Posts: 19
Hi! I see that you own a 100-200mm as well as the 50mm...which lens would you use for indoor social event photography in a home environment where lighting may be a factor? Thanks so much! I currently use my macro 100mm f2.8L and my original zoom 70-300mm (which I am about to replace)...and I am deciding between the 50mm and the 100-200mm f4 L (non-IS)...with my 5DMkii...which would you go for? Mainly kids' photography/newborns etc. Thanks so much!
 treasuringhearts's gear list:treasuringhearts's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.4 USM Canon EF 70-300mm f/4.5-5.6 DO IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 24-105mm f/4L IS USM
Keith Z Leonard Veteran Member • Posts: 6,134
Hello.  Looking at my lightroom catalog, I use my 24-105 the most, my 50mm second most, and my 135mm is a close third.
The trick here is that for about 1/2 of my 24-105 shots I used a bounce flash, then discount the amount outside and you'll find that much more often than not when shooting with the zoom lens I use a bounce flash.
My 70-200 f4 is next on the lens list, used a bit less than the 135 f2 L prime, but still significantly.  And I use it at the extremes most of the time, either 70mm or 200mm.  Again, more often than not the bounce flash is used for indoor photography.  This is true even though I'm shooting a 5Dmk3 which has pretty excellent ISO performance.
You might note though that I have quite a few flashes/modifiers/triggers, and I like to do lighting setups etc....but for general event shooting I use a 430ex II on the camera and bounce from the ceiling or walls and use a "bounce card" on the flash to avoid dark eye sockets.  This is an excellent investment for any camera and you can easily balance the ambient light vs flash and use gels to match your lighting when necessary.
The 100mm macro should be a pretty useful focal length for portraits.  The 50 I use for full length and small groups, though 35mm is pretty popular these days for that sort of work as well.  Canon has a weakness at 50mm honestly, with the 50 f1.8 II having terrible build, the 50 f1.4 being pretty soft at f1.4 and really has a somewhat fragile AF system, and the 50 f1.2L has focus shifts and is just very expensive (lovely images though).  With the recent announcement of a 7 blade 50 f1.8 STM, I would wait to see how that is reviewed, sounds like a real winner for an inexpensive 50mm!
The 70-200 f4 is an excellent lens, but f4 isn't very fast and if you are going to rely on ISO performance indoors you'll have a lot of noisy images.  Of course if you are taking photos of a few people you may will require f4 (or smaller) anyway, then you really HAVE to add light.
So if you don't have a good bounce flash, I'd invest there first!  Newborns are not generally bothered so much by the flash, but they also don't move, so you can park them near window light and have excellent light for your photograhs, primes are great for this task and there are several good ones that are affordable like the 85 f1.8, and hopefully the new 50 f1.8 STM.  Your 100 f2.8 IS L should be great for this use though, so I'd use it since you already have it.  The 135L f2, 200 f2 L, and the 85 f1.2 L are the portrait lens monsters in the Canon line up.
Hope this helps.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
treasuringhearts
Hope this helps.
Helps? That is the most incredibly thorough, clear, professional answer ever...thank you I have been using my flash and bouncing it, which works beautifully, and have been using my diffuser and Gary Fong a lot with kiddies because it is soft and more even if I don't have a good 'bounce target' Your advice is invaluable...thank you. I will hang five for the new 50mm, I see it was released this week I am not 100% sure of the 100-200 f4 yet, but it will be next on my hotlist Thanks for your honesty about the 50mm...I had picked up on some of the chatter but need SOMETHING in that range...but the new 50mm may the answer. Thank you thank you. have a fantastic weekend xxxxxx
Glad you liked the response.
csista Regular Member • Posts: 426
Coming a little late to this thread, but have to join in to say that the 135L is an amazing lens. There's just something special about the way it renders an image. Nothing a stat based review could properly portray. Best bokeh of any lens I own. Beautiful flare if you're shooting a backlit portrait. Don't worry about a conflict with your 70-200. F/4 bokeh can't compare to what this lens will give you wide open. I have the 70-200 f/2.8 and I still prefer the 135L when I have freedom of movement.
- Chris
 csista's gear list:csista's gear list
Canon PowerShot G7 X Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM Canon EF 100mm F2.8L Macro IS USM +6 more
Fog Maker Senior Member • Posts: 2,733
Hope this helps.
Yep, can't go wrong with any of those
(just make sure you a comfortable with the working distance each lens provide and make your choice accordingly - personally I am in the 85 camp)
 Fog Maker's gear list:Fog Maker's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 24-70mm f/2.8L USM Canon EF 100mm F2.8L Macro IS USM
