GH4 time lapse aperture issue
Started May 1, 2015 | Discussions
skies Forum Member • Posts: 77
I use the GH4 regularly for a time lapse, but there is a problem with it. Even though I am in manual mode, there is flicker in the time lapse.
The reason this happens, is that the aperture is opening and closing with every shot, as seen in this short video I made: https://youtu.be/nIM4zgFjvLM
Apparently, the aperture of the Lumix 12-32 can't move this fast or is inaccurate. So I end up doing time lapses with aperture full open. If I do that, there is no flicker.
When I use the EF mount Sigma 17-70 with a Metabones adapter, there is almost no visible flicker.
Is there any way this aperture behavior can be disabled? Not without a firmware update I'm affraid...
'Constant preview' is on by the way, I see not reason why you would want that off at all (especially in time lapse mode). When off, obviously shutter only closes at the shot. I don't know if this would make a difference, I will try this now.
Update: I just did a test and there is no difference with 'Constant preview' on or off.
Panasonic Lumix DMC-GH4
aljudy Senior Member • Posts: 1,208
Re: GH4 time lapse aperture issue
Perhaps add a shutter delay? I think there is one. Too bad about that lens giving this problem, but then it is a kit lens. I just thought maybe manual focus might make a difference?  Al
Amateur Photographer of family mainly
 aljudy's gear list:aljudy's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +9 more
uRebel Rob Senior Member • Posts: 1,537
As aljudy mentioned, it's lens dependent, and can occur on any brand/mount. It's known as aperture flicker in time lapse crowds. Some lenses are more susceptible to this flicker than others. I think it's partially based on that having the aperture off by ~1/6 of a stop for still photos isn't that noticeable, so most lenses are built that way. (But as you see, very noticeable in time lapse)
Canon users even have the trick to "fix" the aperture by partially unmounting the lens while in preview mode, so the contacts aren't engaged. m43 doesn't have the trick, though.
Also most lenses show more flicker at the smaller (f11 to f22) end, as being slightly bigger/smaller (the aperture blades off) by a fraction of a mm at f22 is a larger percentage than off by the same mm would be at f4. As the blades aren't moved at a lens's wide open point, you don't get aperture flicker.
See if you can find other m43 time lapse people, and what they get from different lenses. My panny 14-42 rII is pretty good at controlling aperture flicker up to at least f8, but my 100-300 isn't as clean except wide open (but usable with PP, see next PP). I haven't used my other lenses in time lapse enough yet, as I usually leave my nikon D5100 to time lapse and my GX7 for taking-photos-while-waiting-for-the-time-lapse-to-end.
You also might want to look into PP software to manage the flicker. Even free apps like GoPro's have anti-flicker features. I use LRTimelapse ($$) or VirtualDub + an anti-flicker addon (free), but there are many other options.
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
OP skies Forum Member • Posts: 77
Thank you so much Rob for the clear answer!
So it's a common issue, I didn't even know that.
Well let's hope for a future update for the GH4 where aperture doesn't move while the time lapse is going on. Also saves the mechanics of the lens. (Actually it already shouldn't move when 'constant preview' is enabled, since aperture remains the same. Looks like a software glitch to me.)
Is there any kind of feedback possibility for the GH4? I've searched for that but the Panasonic site just leaves you with a dead end.
I made my first time lapses with a Minolta Dimage 7i using an external shutter timer cord. Never had these problems. That was a good camera for the time
Just a small update on this:
The lens-unscrew-trick does actually work with Canon EF-mount lens on Metabones adapter (tried with the Sigma 17-70)
Still the same with the GH5 firmware 2.2... I don't understand why this is not fixed, and why I land on my own topic when Googling it...
All they have to do is write a little code so the aperture does not move during time lapse... It should be so easy and would solve tons of flickering problems for tons of people...
Unfortunately I can't see how I could contact the developers to request this feature.
Anybody ?
