Hacking VSCO E-M5 Camera Profiles for Olympus E-PL5 or E-PM2
Started Apr 29, 2015 | Discussions
Tech160 New Member • Posts: 2
Re: Making copies of all VSCO profiles that work with any kind of camera with similar sensor
Please discuss this script here:
http://www.dpreview.com/forums/post/57826305
Adding to above post I would like to share a little powershell script that is able to change the camera model on adobe camera profiles to any camera you would like to use it with.
In my case I wanted to use camera profiles originaly for the Fujifilm X100T with my X70.
You have to put a copy of your original camera profiles to the path mentioned as $TargetDir in the script. The dcptool.exe goes into the folder mentioned as $dcptooldir.
As $Originalcamera you set the text string to look out for in the camera profile ("X100T" in my case). As $Targetcamera you set the text string that will be replacing the string in $Originalcamera ("X70" in my case).
The script will convert each .dcp file to .xml. Then it parses the text in the xml searching for the string you put in $Originalcamera and replaces it with $Targetcamera.
It then converts the .xml back to .dcp replacing the original file.
I would change the file name to something useful for you and copy it back to the adobe camera profiles folder.
After that you will have the profiles available for the camera type you changed the profiles to. This is useful for new cameras that probably do not have profiles available right now but there are profiles from a camera with the same sensor around.
http://pastebin.com/zp60d0Xt
Thanks to Sandy for his dcptool that can be downloaded here : http://dcptool.sourceforge.net/Introduction.html
